Air con not working - Page 2 - Mitsubishi Lancer Register Forum
Old 10-07-2019, 10:04   #16
Dave-Cee
Climate Changer
Dave-Cee's Avatar
Car: MAD forged 2.2 IX FQ 340 PLG Leccy Bloo
Originally Posted by Juttie View Post
All of it
You have a spare clutch assembly now?
Dave-Cee is online now   Reply With Quote
Old 10-07-2019, 10:18   #17
Juttie
Car: Evo 8 fq320 mr
I do
Juttie is offline   Reply With Quote
Old 10-07-2019, 15:27   #18
TrickyDick
Very Senior User
TrickyDick's Avatar
Car: VII FQ-300x2
Just had a quick look and if I run a positive from battery to.pulley it operates so guess next thing is to see what voltage I have at relay I guess.
Good news, some progress The relay has permanent 12V to its coil and other end of the coil is "pulled" to ground by the ECU.
There are two fuses, one for the compresser feed (one of those in main fuse box in engine bay, #4 10A) and another for the relay (multipurpose #5 - they are the bank of plug in fuses in the J/B fuse box under dash). (hope I've read those correctly !)
TrickyDick is offline   Reply With Quote
Old 10-07-2019, 16:52   #19
Juttie
Car: Evo 8 fq320 mr
Thanks for the drawing I've got someone checking ECU settings for me so hopefully they will.be able to re configure something but will check voltage at relay once I get home.
Old 11-07-2019, 09:40   #20
TrickyDick
Very Senior User
TrickyDick's Avatar
Car: VII FQ-300x2
I remember it was tricky to find the right ECU drive pin because I found different info in various documents and the ECU manual was also incorrect.
However the wiring diagram above shows pin 8 correctly (on EVO7 at least):
(looking into ECU, ie wire side of connectors)
Old 11-07-2019, 10:54   #21
Juttie
Car: Evo 8 fq320 mr
Thanks for the info, the map on the syvecs has been checked and the ac switch as not been assigned so hoping it's just a simple.job of setting this up.
The Following User Says Thank You to Juttie For This Useful Post:
Rampant (11-07-2019)
Old 11-07-2019, 16:02   #22
TrickyDick
Very Senior User
TrickyDick's Avatar
Car: VII FQ-300x2
That should certainly help
Sounds like the weather is about to change
Old 15-07-2019, 19:57   #23
Juttie
Car: Evo 8 fq320 mr
Thanks for all the help now sorted just needed the syvecs configured.
