Project TME - Page 3 - Mitsubishi Lancer Register Forum
Old 19-03-2019, 20:29   #31
gordonm
Regional Organiser
Car: Voltex 9 GT
Good work
gordonm is offline   Reply With Quote
Old 19-03-2019, 21:17   #32
oliverash
oliverash's Avatar
Car: Evo VI TME Canal Blue. Yamaha R1 powered Mini. 2011 ZX6R
Originally Posted by Rampant View Post
What are your thoughts on the MeisterR coilovers? I had GT1s on my old IX, but was thinking of the less expensive ones for my VI for the time being (I think Meister can possibly upgrade them to GT1s at a future time, which means it isn't a total loss to buy the cheaper ones first?)
Keep up the good work
I think they are fine to be honest. Better than running lowering springs in terms of ride and composure and against the TME springs (which felt very soft in comparison) they are a marked improvement in that the whole things feels a lot sharper.
Iíve no experience of anything higher speccíd so Iím none the wiser in that respect but these coil-overs work for me and seem decent quality for the price.
oliverash is offline   Reply With Quote
The Following User Says Thank You to oliverash For This Useful Post:
RichW (22-03-2019)
Old 20-03-2019, 21:22   #33
oliverash
oliverash's Avatar
White wheels - they really are a pain but on the Evo I wouldnt have any other colour. To begin with i thought they cleaned up alright but once you really start to get in there with some compound polish you find that white can be much much whiter.
After maybe a few months of ownership the wheels had to come off.
Rinse, bit of Dragons Breath, nice soapy wash and then another rinse off.
After which they still looked terrible!
Old 20-03-2019, 21:42   #34
oliverash
oliverash's Avatar
The end result of some proper invested time. I remember spending nearly 2 hours per wheel once I realised the yellow tinge actually polished out
Started with a traffic film remover and then a citrus cleaner. Following that a wipe over with a panel prep spray.
I had some old tube of scratch remover which I thought I'd try first, just to see. Once I saw the yellow turned back to white I slapped more on and worked it in fairly hard with a conical sponge attachment for the drill. I followed this up with a less aggressive polish, again using the drill attachment and ended with a finishing polish.
This was then wiped back over with panel prep and finally a ceramic coating applied.
They turned out loads better than I originally expected but it was a lot of work - I wouldnt do it again. Be easier just to send them away to be repainted!
The Following 5 Users Say Thank You to oliverash For This Useful Post:
Dereksti (20-03-2019), evolover21 (23-06-2019), M3 ROB (21-03-2019), RichW (22-03-2019), squeakyclean32 (20-03-2019)
Old 20-03-2019, 21:55   #35
Dereksti
Dereksti's Avatar
Car: Scotia white tommi mak.
Look great ,terrible to keep clean Iíve tried almost everything on the market .
Dereksti is offline   Reply With Quote
Old 20-03-2019, 22:11   #36
squeakyclean32
Regional Organiser
squeakyclean32's Avatar
Car: Evo 6 TME
Such a big improvement...Def worth the time spent on them ...
squeakyclean32 is offline   Reply With Quote
Old 21-03-2019, 17:15   #37
Kieron Watson
Car: Evo 6 TME
Mine stay lovely and clean with Gteknic wheel armour C4 I think it is... Don't get me wrong, I don't use the brakes very often which helps too.... let the car do the cornering work
TME - Pink
Kieron Watson is offline   Reply With Quote
Old 22-03-2019, 16:33   #38
oliverash
oliverash's Avatar
I mentioned that after getting the naca duct back the paint was a bit off and it stood out against the rest of the bonnet.
I thought a carbon version would look quite good as a replacement and I'm sure it would have been had all the ones I tried not been total rubbish.
The two piece OEM style one I purchased first was a hopeless fit as the bolts were bonded in the wrong positions. One half ended in the bin after I lost patience with it!
The next one I bought which cost even more than the first but was only a single piece item was again affected with One Eyed Willy precision - bolts didn't line up and the overall shape was terrible. So I sent it back and they gave me another, which I also sent back.
So as more of a temporary measure I decided to have a go at vinyl wrapping it.
Now as a first attempt at this I'd picked a pretty challenging shape and it did give me a fair bit of grief. The inside top corners were a nightmare to cover as one piece because they go against the direction of the surrounding edges meaning you either have too much excess or not enough material.
Anyway after a couple of failed attempts I did end up with a not perfect but suitable finish.
It actually looked alright and I liked the matt carbon effect.
evolover21 (23-06-2019), M3 ROB (22-03-2019), RichW (22-03-2019), squeakyclean32 (27-03-2019), Uzumaki (23-03-2019)
Old 22-03-2019, 19:19   #39
M3 ROB
M3 ROB's Avatar
Car: Evo 6 TME,
You are quite the Artist Ollie looks great mate well done
M3 ROB is offline   Reply With Quote
Old 22-03-2019, 19:39   #40
oliverash
oliverash's Avatar
Cheers Rob. Obviously most of this is old hat now as it was a while ago - wheels need more work and the naca duct went back to being painted - but that story comes a bit later...
M3 ROB (22-03-2019)
Old 26-03-2019, 11:45   #41
oliverash
oliverash's Avatar
The all important Tommi boot sticker was past its best. This was the first thing I bought for the car but took ages to getting around to fit it. Itís not exactly the same but looks good now that itís done.
The original
Removing the old one
AutoGlym tar remover to clean off the old glue
The finished article - subtle differences but overall same design.
The Following 3 Users Say Thank You to oliverash For This Useful Post:
evolover21 (23-06-2019), M3 ROB (27-03-2019), squeakyclean32 (27-03-2019)
Old 26-03-2019, 22:59   #42
suzukito
User
Great job with the sticker, where did you bought?. Look nice
suzukito is offline   Reply With Quote
Old 27-03-2019, 07:09   #43
oliverash
oliverash's Avatar
Got the boot sticker from FCM motorsport
suzukito (27-03-2019)
Old 30-03-2019, 09:45   #44
oliverash
oliverash's Avatar
Saw one of these on a lovely yellow V and decided I wanted one too.
Tegiwa carbon cooling plate
Before
After
evolover21 (23-06-2019), M3 ROB (30-03-2019), na208 (30-03-2019), RichW (30-03-2019), squeakyclean32 (30-03-2019)
Old 04-04-2019, 15:16   #45
oliverash
oliverash's Avatar
Keeping with the engine I replaced the underbonnet heat shield. Seeing it hang down at the corners everytime the bonnet was lifted started to annoy me as it really let the engine bay down.
The original one
The new one. A marked improvement
squeakyclean32 (04-04-2019)
Similar Threads
98 Lancer to Evo 6.5 TME Project BCspeed34 Picture & Video Gallery 371 01-04-2015 23:31
Project Mu Review DaveG Brakes 8 03-04-2009 13:13
Evo 6 tme bits job lot wilsongsr Private Sales - Parts 28 06-03-2009 17:44
Red TME Photoshop project 3gan Picture & Video Gallery 9 08-01-2009 21:03
