Scotia White Evo Tommi Makenin edition restoration and Engine rebuild - Page 9 - Mitsubishi Lancer Register Forum
Old 26-05-2019, 12:39   #121
MHR Evolution
Car: Evo 6.5 TME Edition
Originally Posted by costas View Post
Get the brakes anodised black.
Noooo
Have to stay red
Sent from my D6503 using Tapatalk
MHR Evolution is offline   Reply With Quote
Old 02-07-2019, 22:34   #122
MHR Evolution
Calipers done, will get some better pictures. These dont do them justice Name:  DSC_2071.jpg
Old 02-07-2019, 22:37   #123
MHR Evolution
Bumpers, arch trims, sideskirts all painted and refitted
I rebuilt the door trims, rust bullet and painted metal brackets, tigersealed them on, new rivets, new clips and the metal clips
Still dont pull tight on the bottom of door!
But there on and not rotting so its all good
Reused the silver trim, just took them off carefully removed the double sided tape and put new on Name:  DSC_2066.jpg
Old 03-07-2019, 09:07   #124
MHR Evolution
Originally Posted by Mita View Post
Isnít making the oil feeds bigger going to drop the pressure? I bet it was a nightmare getting that engine back in!!
24psi on 1000rpm and hits 90psi by 4000
No issues with pressure
The Following User Says Thank You to MHR Evolution For This Useful Post:
Mita (03-07-2019)
Old 13-07-2019, 20:36   #125
MHR Evolution
Calipers all rebuilt and fitted
Size:  36.2 KBName:  DSC_2114.jpg
Size:  41.3 KBName:  DSC_2117.jpg
Size:  38.2 KBName:  DSC_2116.jpg
Old 13-07-2019, 20:37   #126
MHR Evolution
First time its been outside in a long timeName:  DSC_2118.jpg
Size:  65.0 KBName:  DSC_2119.jpg
Size:  59.6 KBName:  DSC_2120.jpg
Old 13-07-2019, 20:39   #127
MHR Evolution
Catchtank all fitted
-10x2 from rocker
-12 out, will be adding a -12 line over the gearbox and down behind gearbox/under car. That should keep any crank pressures at bay Name:  DSC_2140.jpg
Old 13-07-2019, 20:40   #128
MHR Evolution
Defi advance zd and aem afr gauge all hooked up.
Got a little worried when oil temp went upto 180
Then i relised this is in fahrenheit lol
Old 15-07-2019, 20:19   #129
MHR Evolution
Nearly 2 years of dirt and dust.Name:  _20190714_203045.jpg
Size:  54.5 KBName:  _20190714_203017.jpg
Size:  39.4 KBName:  DSC_2145.jpg
Old 15-07-2019, 20:20   #130
MHR Evolution
Snowfoam doing its thingName:  _20190714_202944.jpg
Size:  52.3 KBName:  DSC_2147.jpg
Old 15-07-2019, 20:22   #131
MHR Evolution
Iron out doing its thing, as expected lots of reactionName:  DSC_2150.jpg
Size:  30.7 KBName:  DSC_2151.jpg
Size:  32.4 KBName:  DSC_2153.jpg
Size:  38.0 KBName:  DSC_2156.jpg
Size:  42.7 KBName:  DSC_2157.jpg
Old 15-07-2019, 20:26   #132
MHR Evolution
And now all cleaned, does need a little bit of polishing.
Quite happy with the paintmatch on bumpers And plastic trims Name:  _20190714_202757.jpg
Size:  42.6 KBName:  DSC_2161.jpg
Size:  43.2 KBName:  _20190714_202723.jpg
Size:  46.6 KBName:  _20190714_202642.jpg
Size:  62.6 KBName:  DSC_2158.jpg
Size:  18.0 KBName:  DSC_2163.jpg
The Following 3 Users Say Thank You to MHR Evolution For This Useful Post:
evolover21 (16-07-2019), Gg3001 (15-07-2019), mattymr2 (15-07-2019)
Old 17-07-2019, 06:43   #133
patta
patta's Avatar
Looks fresh does that, I certainly need a cooling panel in my bay it cleans it up a lot
Evolution Virgin
patta is offline   Reply With Quote
