Bilstein suspension kits & replacment dampers - Mitsubishi Lancer Register Forum
Go Back   Mitsubishi Lancer Register Forum > Marketplace > MLR Platinum Option Trader: CPP Motor Developments
Thread Tools Rating: Thread Rating: 2 votes, 3.50 average. Display Modes
Old 16-02-2012, 14:18   #1
[email protected]
Moderator
gaz@cpp's Avatar
Location: (Cheshire) Crossing the finish line ahead of everyone else or parked in a ditch
Car: E6 RS Sprint No 1 (Now under going rebuild) R35 GTR
Evo 8MR/9MR Bilstein front struts £we will beat any genuine advertised price
Evo 8MR/9MR Bilstein Rear damper £" "
Bilstein B14 coil over kit height adjustable to fit Evo 7,8,9 £949.00
Bilstein B16 coil over kit height & adjustable damping to fit Evo 7,8,9 £1499.00
Fitting kit to allow fitment of the above onto E4,5,6 £66.00 per car set
Ralliart top mounts £52.00 each when purchased with any of the above
All prices + vat & delivery.
Visit Cpp motor developments forum section
Visit Cpp motor developments face book page
gaz@cpp is offline   Reply With Quote
Old 16-02-2012, 14:58   #2
[email protected]
Moderator
gaz@cpp's Avatar
Special offer on B14 coilover kits while current stocks last......
Buy a B14 kit from Cpp & we will fit your new kit, set your ride heights & carryout a full four wheel alignment to Cpp fast road or track settings for £250 all in
Call 01477 500895 to book in or ask any questions
Old 16-02-2012, 15:46   #3
[email protected]
Moderator
gaz@cpp's Avatar
B14 product info
BILSTEIN B14
Sport makes you flexible.
With the BILSTEIN B14 threaded ride height adjustable kit, we’re bringing technology from the race track onto the street.
The product benefits at a glance:
•Threaded body adjustable range of 20 mm at both axles, while installed
•Lowering of approx. 30-50 mm at front and rear
•Road-tested by BILSTEIN under motor sports conditions and fine-tuned
•Spring plates and lock nuts made from a special aluminium alloy
•Surface coating using Triple-C-Technology® for long-lasting corrosion resistance
•Round threads for ease of adjustment
•Quality sport springs made from highly durable material
•BILSTEIN gas pressure technology
•BILSTEIN mono-tube/Upside-Down technology, made in Germany
•German TÜV certificate
Round threads, Triple-C-Technology®
BILSTEIN round threads
To ensure that you can fine-tune your vehicle exactly how you want it, our threaded ride height adjustable kits are easy to adjust – even when they’re installed. Allowing you to find the perfect balance for your vehicle.
•The special thread has no sharp edges that could be open to aggressive environmental influences
•The secured aluminium spring plates ensure the utmost level of safety
•The right hook spanners are provided in the scope of supply
BILSTEIN-Triple-C-Technology®
Our 3-layer coating system, developed especially with threaded ride height adjustable kits in mind, guarantees high-quality, enduring corrosion protection.
Coating 1: The special zinc alloy ensures excellent adherence to the base material, and forms the basis for longlasting corrosion protection.
Coating 2: The middle coating transforms the zinc layer into a closed-formation, homogenous surface.
Coating 3: Not only is the top coat aesthetically pleasing, it also provides additional, long-term protection against mechanical wear and corrosion. Endurance tests to DIN 50021 SS also testify to this:
Old 16-02-2012, 21:37   #4
Captain Carling
Captain Carling's Avatar
Car: Evo X RS 400/400
Anything for the Evo X mate?
Work Hard, Play Harder and never steal another mans rhubarb
Captain Carling is offline   Reply With Quote
Old 16-02-2012, 23:10   #5
patselby
Car: EVO VI eXtreme
These look a good bit of kit WITH some nice coatings to
keep the cr4p at bay
Cheers Pat
patselby is offline   Reply With Quote
The Following User Says Thank You to patselby For This Useful Post:
MOONDUST FRST (06-05-2015)
Old 18-02-2012, 01:03   #6
michty_me
michty_me's Avatar
Car: Forged Evo X CT-500
May be interested in this too.
michty_me is offline   Reply With Quote
Old 18-02-2012, 18:13   #7
Andy RS
Can you please Pm me a price Gaz for everything I need for an evo 6.
Andy RS is offline   Reply With Quote
Old 26-02-2012, 20:30   #8
R'ace'R
Which are front and rear spring rates for B14?
R'ace'R is offline   Reply With Quote
Old 27-02-2012, 01:46   #9
mr prawn
How much for b14.. Fitted , set up ,, and everything??
BABY SHRIMP WILL ALWAYS MISS YOU........
14/5/02-21/11/06
mr prawn is offline   Reply With Quote
Old 01-05-2012, 15:21   #10
Noddy
Car: V GSR
Could you please advise if the 4/5/6 fitting kit requires the holes in the hubs to be drilled out or will it accept the oem diameter bolts?
Many thanks.
Noddy is offline   Reply With Quote
Old 30-12-2012, 18:10   #11
leecavturbo
leecavturbo's Avatar
Car: Evo8 MG Full Cosworth 2.2L/r stroker,Blouch xtr760,syvecs 9.8sec 30-130
mr billys still available gaz?
leecavturbo is offline   Reply With Quote
Old 19-04-2013, 14:33   #12
patselby
Car: EVO VI eXtreme
Big thanks to Olly and Gaz
Drives lovely thanks
Cheers Pat
Old 17-06-2013, 18:39   #13
tofulo
tofulo's Avatar
Car: Evo 6 GSR
Send a message via MSN to tofulo
Do you have two rear bilstein dampers for a 9 in stock?
How much for both delivered?
Thanks.
tofulo is offline   Reply With Quote
Old 14-11-2013, 14:54   #14
evo 666
Car: evo 8 340 mr
Hi could you pm me a price for b6 evo 9 suspension front and rear plus new standard springs aswell please
evo 666 is offline   Reply With Quote
Old 26-06-2014, 23:46   #15
smithyl23
smithyl23's Avatar
Car: ND 900bhp engine, Clive W RS Gearbox and Diffs, stage 3 Transfer Box with Wavetrac,
Can you get hold of the Bilstein stickers that go around the shocks? Want to strip mine and repaint them.
Smithy
smithyl23 is offline   Reply With Quote
The Following User Says Thank You to smithyl23 For This Useful Post:
CJP93 (03-03-2016)
