Evo 8 fq 300 full strip and rebuild - Page 11 - Mitsubishi Lancer Register Forum
Thread Tools Rating: Thread Rating: 6 votes, 4.33 average. Display Modes
Old 13-12-2014, 11:11   #151
richyx
Ii took calipers apart to remove the shim plates, which bolts need heat
Left Pistons and seals in, and used gaffer tape to protect Pistons as you can see in pic, left bleed nipples in and got two bolts same thread for banjo holes, to stop any media getting inside caliper
I then had them blasted using garnet but recommend bead blasting just no one here does it
I used a proper etch primer with two coats, flatted then a high build flatted, then the colours then lacquer, ideally apply stickers before laquer mine just haven't turned up yet
I got all new seals bleed nipples and covers and screws from Godspeed for 62 delivered, dealer wanted over 200 and everywhere else for two dust shields is 30 godspeed can't beat on price and help
This is just fears, I already have a big brake kit for front anyhow
richyx is offline   Reply With Quote
Old 13-12-2014, 11:59   #152
Mita
Thanks mate that's great, just what I wanted to hear. I was considering rubbing them down myself?! I have really clean 9 calipers so not that bad, but from what I have read it's a pita to do. Maybe the beed blast is a good shout
Old 13-12-2014, 14:39   #153
Mike_s
Mike_s's Avatar
Do you have a zinc coating kit or do you get the bolts sent away to be done?
"Money can't buy happiness, but it can buy horse power. And that's pretty much the same thing"
Mike_s is offline   Reply With Quote
Old 13-12-2014, 14:57   #154
ray671984
Car: Mitsubishi Evo Vll GT-A
Awsome rich mate said it more then once and still following your facebook
Mitsubishi Evo 7 GT-A
ray671984 is offline   Reply With Quote
The Following User Says Thank You to ray671984 For This Useful Post:
richyx (13-12-2014)
Old 13-12-2014, 18:26   #155
richyx
Send them away, I de rust as much as I can to make it better, but didn't bother with some I knew would be replaced with new bolts
Old 18-12-2014, 18:15   #156
richyx
Bit more done
Roll bar fitted, adjustable, new superpro bushes and bolts etc
Ayc pump has been tested and fully working after rebuild, it was then sealed with a spray on wax laquer to stop any moisture getting into it to stop corrosion
New mount bushes
All fitted and braided lines as well
Just have to cable tie these together
Also got my arms powdercoated, fitted all ball joints, new clips and bushes today, will upload pics later as doing some more work on car at min
The Following 4 Users Say Thank You to richyx For This Useful Post:
Bava (18-12-2014), dearsman (18-12-2014), evo5d (18-12-2014), Mr Ralliart (19-12-2014)
Old 19-12-2014, 01:21   #157
richyx
Bit more done, rear end is getting there slowly
So ball joints and clips installed into all arms
Poly bushes as well
Next was to re grease the joints and using new boots
New bolts for top arms
Lower arm finished
Toe arm ready
Shock arm, poly bushed and new outer and inner bushes
All fitted
Shock ready to install
How I held the shock in as on my own lol
All installed
Other side all finished
Fuel neck shield
Used the wax from ayc pump onto filler neck to protect it also in the arch as well
This I forgot to do up what a pain but done now lol
All fitted
Next rebuild driveshafts if I gt my cv joints back tomorrow, then hubs and brakes can go on and the rear end is finished
The Following 3 Users Say Thank You to richyx For This Useful Post:
evo5d (19-12-2014), Mr Ralliart (19-12-2014), ray671984 (21-12-2014)
Old 19-12-2014, 10:44   #158
OVE VIII
Excellent work! Thank you for the updates.
OVE VIII is offline   Reply With Quote
Old 20-12-2014, 10:18   #159
richyx
No probs, work has stopped at mo
Driveshafts were are but one needed a smack but I missed and hit my knee which I may have done damage to, at the min I can bend down on it lol, gutted as its only hubs and brakes and the rear end is finished
Old 21-12-2014, 05:51   #160
Ads9
Ads9's Avatar
Car: EVO IX FQ320, 2.2 Cosworth, TT S214b, Link G4+ Geekmapped by me (hasn’t gone bang. Yet.)
Looking really good, been following your build since the start and it's seriously impressive how much you done in such a short space of time, at home!
Out of interest, what is the spray on wax lacquer you've used?
Ads9 is offline   Reply With Quote
Old 21-12-2014, 11:02   #161
richyx
Is just an engine laquer, but is waxed based and seals up stuff
Old 22-12-2014, 15:24   #162
richyx
Got my driveshafts rebuilt
Hubs fitted
New speed sensors fitted
Hand brake cables all done
Stickers on calipers and relaquered
Discs fitted
Drop links being fitted
Caliper rebuild with new seals
Shims and Piston seal fitted
Half complete
Finished
And fitted
Carbon brake lines fitted
Need to get pad plates and pins but can't find them at reasonable prices so I'll clean mine up then can fit pads, handbrake has been adjusted as well
Just waiting on fuel line, two arm nuts and sensor brackets and the rear end is finished
Then I need to buy wheels and start the front with buying a gearbox and clutch
Old 23-12-2014, 15:04   #163
Mike_s
Mike_s's Avatar
Very jealous of your spraying skills!
Moar updates!
Old 23-12-2014, 15:23   #164
richyx
Not bad for a rattle can lol
No updates at mo now, can only just do a bit of tidying, as need to save for wheels, gearbox and clutch now
Old 23-12-2014, 15:50   #165
Triple L
Not sure I'm loving the Katie Perry edition Pink calipers but everything else is very impressive - you should be proud
Triple L is offline   Reply With Quote
