700BHP+ Evo IX FQ360 MR – FULLY LOADED - Page 2 - Mitsubishi Lancer Register Forum
Thread Tools Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
Old 14-11-2012, 21:28   #16
l2esk
Originally Posted by No_Evo View Post
After 5 years of ownership and owning from new, I am considering selling my pride and joy. I’ve had my ups and downs with this car, but in its current form, it’s been the best it’s EVER been. Not a single penny has been sparred on this car. Just ask the likes of Mat @ MG Autos / Gary @ APT / Ross @ Ross Sport.
The car in its standard form was an Evo IX FQ360 MR By HKS in Gunmetal Grey, however, over the years has been heavily modified.
The spec list is massive, so i am likely to add to this as time passes.
Engine Specification:
• 2.3 Stroker built by Gary @ APT
• 100mm Billet Crank
• Steel I-Beam Rods
• ARP 625 Bolt Upgrade
• Wiesco HD Pistons
• Mild Head Port
• ARP L19 Head studs
• Fluidamper Harmonic Damper
• Jun 272 Camshafts
• HKS Adjustable Exhaust Pulley
• HKS Cambelt
• Balancer Shaft Delete Kit
• Ross Sport Turbo Kit
• 35GTX Turbocharger
• 46mm Precision Turbo External Wastegate
• Apexi Boost Solenoid
• Tial BOV
• Ross Sport Intercooler Piping
• AMS Oil Cooler Kit
• AMS Front Mount Intercooler
• Mishimoto Radiator + Large Slimline Fan
• Spoolin COPs
• NGK Heat Range 8 Race Plugs
• Miltek Exhaust
• K&N Large Filter
• Magnus Intake Manifold
• Boomba Throttle Body
This engine has currently around 5000 miles on it. The first 2000 of which were the running in miles. The total mileage of the car is just a shade under 35,000 miles, but will likely increase as i am using it every other day. The engine starts up first time, idles at 1000rpm and runs perfectly. I’ve been through a few engines, and as has been said, this is one solid engine. It never missed a beat pull after pull on the Dyno and still drives home immaculately.
In its current state the car makes anything between 500BHP to 700BHP depending on boost, which is adjustable via a Motec Rotary Switch.
ECU:
The car has been mapped by Dave Rowe. The car has seen a few turbo / housing combinations, but in the end we decided on a 35GTX with the 0.82 Tial Housing.
• Motec M800
• Motec Cam Control Module
• Motec Anti-Knock Module
• Motec Anti-Lag Module
• Motec Adjustable Rotary Switch
Gearbox:
• 5 Speed Medium RS Box – Top Speed of around 160MPH
• RS Rear Differential
• Exedy Triple Plate Clutch + Flywheel Combo
• Braided Clutch Lines
Suspension:
By far the best modification i have done. This suspension inspires so much confident to the point you can get ****y pushing it into a corner. Coupled with the RS Diff and the below Wheel/Tyre setup, your almost untouchable (if you know how to drive).
• Nitron 3-Way Adjustable Suspension
• Perrin Adjustable Rear Anti-Roll Bar
Brakes:
Again this brake setup inspires confidence. The brake pads are spot on for road use too. Little dust, no squeal and work excellent from cold.
• K-Sport 356mm 8 Pot Fronts
• K-Sport 330mm 6 Pot Rears
• EBC BlueStuff Brake Pads
Fuel System:
• OEM In-Tank Pump
• Bosch 044 Motorsport External Pump
• Aeromotive Fuel Filters
• Aeromotive Fuel Rail
• Bosch 1000cc Injectors
Wheels / Tyres:
• Advan RS 18 x 9
• Michelin Pilot Sports (245/40/18)
ICE:
Professional Install done by Platinum-In Car in Coventry. Again went through a few setups, and this one is by far the best sounding and aesthetically pleasing.
• Pioneer Double Din Screen
• Phoenix Gold Front Speakers
• 12” Fi Subwoofer in Infinite Baffle
• Hertz HDP4 Digital Amplifier
Bodywork:
The bodywork is in excellent condition. Currently a few minor scratches here and there, however, the car is booked in for a detail and all these minor blemishes will be resolved.
Extras:
If i get my asking price i am willing to throw in the following:
• Carbotech XP10 Brake Pads – Still 50% life left in them
• Spare RS Gearbox with 4.11 Final Drive
• 0.63 Tial Housing
• NGK Heat Range 9 Race Plugs
• Racelogic GPS Performance Box
As has been said, the car needs nothing done to it. It has a long MOT and Tax. The car is religiously serviced between 2000-3000 miles without fail, only using OEM filters and Motul Oil. The last change also saw all the diff oil changed and gearbox oil.
All receipts, documentation is available on request.
Pictures shall be added shortly, once the detail is complete.
Any viewing welcome, i am based just outside of Coventry, however all viewing will be done at a colleagues garage.
You'd be hard pushed to find a more complete car than this one. It has everything, comfort, nice sound system, excellent road manners, handling, braking, decent economy (dedicated fuel economy map) and the best bit - TOTAL BRUTALITY.
Test drives will be carried out by myself ONLY.
£26,995
[email protected]
you,ve sold it for e m8,great add sounds a mental bit of kit glwts
556hp Norris design tuned evo 8
l2esk is offline   Reply With Quote
Old 23-11-2012, 16:58   #17
No_Evo
Updated with pictures
No_Evo is offline   Reply With Quote
Old 23-11-2012, 17:08   #18
staffi
TOO many posts.......
staffi's Avatar
WOW,
That,s simply stunning pal, best I,ve seen it look
GLWTS, Someone,s going to get a lovely car
staffi is offline   Reply With Quote
Old 23-11-2012, 17:20   #19
Kezzo80
Car: German Family Saloon oil burner!
Seen this at an Mg open day a few years ago when it had a 'mere' 600 bhp. Monster car and quite a sleeper too!
GLWTS
Missing the boost
Kezzo80 is offline   Reply With Quote
Old 23-11-2012, 17:37   #20
A12DY B
All things Evo
Car: EVO IX MR
Stunning
A12DY B is offline   Reply With Quote
Old 23-11-2012, 19:13   #21
MOSSY
Car: EVO IX FQ360 MR No.164
Does that plate mean anything to you???
Just wondering if you would let it go
cheers
MOSSY is offline   Reply With Quote
Old 23-11-2012, 19:17   #22
Ads9
Ads9's Avatar
Car: EVO IX FQ320, 2.2 Cosworth, TT S214b, Link G4+ Geekmapped by me (hasn’t gone bang. Yet.)
** SEX WEE **
Stunning car buddy, shame it's so far out of my price range
Ads9 is offline   Reply With Quote
Old 24-11-2012, 16:42   #23
leecavturbo
leecavturbo's Avatar
Car: Evo8 MG Full Cosworth 2.2L/r stroker,Blouch xtr760,syvecs 9.8sec 30-130
Immense that is. Right looks and top spec
leecavturbo is offline   Reply With Quote
Old 24-11-2012, 16:50   #24
spikem
Car: Darton'd sleeved 2.2ltr, 617bhp/525lbft
stunning car that mate
spikem is offline   Reply With Quote
Old 26-11-2012, 12:43   #25
No_Evo
cheers
Yes - but will sell it after the car is sold.
Interested?
The Following User Says Thank You to No_Evo For This Useful Post:
MOSSY (30-11-2012)
Old 28-11-2012, 03:33   #26
p23rab
Car: Very clean white dcy 5 with mods.
Stunning car you have there mate. The spec is top quality.
Have you thought about breaking the car or even putting it to standard as no body is buying at the moment and tbh you would get more money and faster if you did.
p23rab is offline   Reply With Quote
Old 28-11-2012, 13:27   #27
KrissJ
WOW! In my opinion, this is close to the perfect Evo. It's definitely one of the best looking too.
Good luck with the sale.
KrissJ is offline   Reply With Quote
Old 28-11-2012, 14:01   #28
Wardo84
Stunning mate, GLWTS
Wardo84 is offline   Reply With Quote
The Following User Says Thank You to Wardo84 For This Useful Post:
c8coj (03-01-2013)
Old 30-11-2012, 19:04   #29
MOSSY
Interested?
Yes if the price is right....
Old 30-11-2012, 20:07   #30
evo ash
stunning. glwts
evo ash is offline   Reply With Quote
