List your MAX bhp/torque running on standard blocks here - Page 12 - Mitsubishi Lancer Register Forum
Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
Old 09-10-2019, 10:55   #166
madmatt
madmatt's Avatar
Originally Posted by Mr Ralliart View Post
If you're running a cam profile that is no more than 270 degrees total duration then it can be done, if less than 265 degrees duration it's easy, and the best way for these engines anyway. My torque peak with the TME Turbo was under 4000 and even with the RS 16G it was still at 3900 rpm with 380hp atw.
This is all with factory turbos that is, obviously it's easier with ball bearing turbos.
Flowing the factory exhaust manifold in the right way can help a little too.
Fair enough. He didn't mention cams, so I assumed they were std. Std cams have low duration anyway (below 260 if I remember correctl), or thereabout.
I still find strange how he gets peak torque 400rpm earlier than many of us with similar engine. I'm interested in engine response and low-rpm torque, that's why I'm interested.
The Following User Says Thank You to madmatt For This Useful Post:
Mr Ralliart (10-10-2019)
Old 09-10-2019, 12:35   #167
Mita
Is your engine standard cams?
Old 09-10-2019, 12:36   #168
kikiturbo
Car: EVO 9 GSR
you can always play with cam timing to move the tq peak about..
Old 09-10-2019, 13:50   #169
sonetts
Yes, standard cams on standard cam timing.
sonetts is offline   Reply With Quote
The Following User Says Thank You to sonetts For This Useful Post:
Mita (09-10-2019)
Old 09-10-2019, 13:50   #170
madmatt
madmatt's Avatar
Below is dyno plot (power in bhp on the left, torque in Nm on the right). Engine 100% stock, except K&N panel filter.
Peak torque 4350rpm. Car is an Evo 6 TME with GSR turbo. Test was done in 4th gear.
Mita (09-10-2019)
Old 09-10-2019, 14:43   #171
Mita
That seems a bit late to me?
Old 09-10-2019, 14:47   #172
kikiturbo
Car: EVO 9 GSR
I did map a e9 for a friend that seemed really late to boost.. in the end it was the wastegate flapper that was to blame.. it had just the smallest bend in it and that was enough... we swapped turbos and problem solved..
Old 09-10-2019, 15:31   #173
grants
grants's Avatar
Has anyone got a GrpN rally car dyno print out ?
It would make interesting viewing !!!
The Following User Says Thank You to grants For This Useful Post:
Mita (09-10-2019)
Old 09-10-2019, 19:35   #174
sonetts
I have a dyno plot of my red tme and the black tme with the mods as listed. The red tme is standard and how it came in from Japan, I got it on the rollers mainly to check fuelling etc.
Old 10-10-2019, 05:56   #175
madmatt
madmatt's Avatar
Ah thanks a lot for the graphs! Goes to show I was right! You don't really get peak torque before 4000rpm on factory 6s, yours is another example. But hell, your car spools early with the mods!
Old 10-10-2019, 08:21   #176
Mr Ralliart
Anthony
Mr Ralliart's Avatar
Car: Evolution 6 TME Ralliart Edition (JDM)
Your turbo is probably a little tired also, when I replaced mine I was shocked at how tired it was despite looking still fairly good.
My TME progress & track day thread: https://www.lancerregister.com/showthread.php?t=462309
Mr Ralliart is offline   Reply With Quote
Old 10-10-2019, 08:40   #177
Mr Ralliart
Anthony
Have probably posted this somewhere in this thread already, but anyway..
Spec at the time was: new Evo VI RS turbo
J-Speed Turbo Dump (twin pipe) + 3" Front pipe
EXAS Evo tune 80mm stainless cat back and muffler
BLITZ EBC running 1.5 Bar boost
TOMEI Poncam 260 Camshafts
HKS Adjustable Cam Gears
HKS SuperFire Racing plugs (9 heat range)
HPI Pod Air Filterin airbox.
Rest standard. Engine had something like 70,000 klms on it IIRC.
If running a more standard exhaust and cams the power would come on way sooner, but of course there'd be a lot less of it.
We could have got the power in a fraction earlier but I was more than happy with this so we left it.
Later on when I added Okada Plasma direct coils it was even stronger.
The Following User Says Thank You to Mr Ralliart For This Useful Post:
Mita (10-10-2019)
Old 10-10-2019, 09:43   #178
sonetts
[QUOTE Later on when I added Okada Plasma direct coils it was even stronger.[/QUOTE]
Do you have a graph when you added the coils?
Old 10-10-2019, 10:11   #179
madmatt
madmatt's Avatar
I think so too. Looks tired even from the outside! But thanks guys for the inputs! Nice to see some graphs.
Old 10-10-2019, 10:26   #180
Mr Ralliart
Anthony
No unfortunately I never got around to it, but the difference was clear. I was actually surprised because Mitsubishi electrics are good (much better than other JDM) and the coils I replaced were only maybe 20000 klms old, and while I expected an improvement, I wasn't expecting one that I could feel.
Similar Threads
max boost for standard ecu with avc-r prova355 Engine / Turbo 3 24-07-2004 14:41
whats the max bhp u can get with standard evo 6 injectors moses Engine / Turbo 10 22-11-2002 08:26
What's the standard max turbo boost pressure for an evo1 Roger C Technical Questions 3 13-07-2002 21:46
Max Boost with standard turbo Chuck Technical Questions 12 23-08-2001 19:59
Max Power emails Heave Ho Six Lancer Chat 1 22-01-2001 22:34
