Evo 6 headlights - woeful - Mitsubishi Lancer Register Forum
Go Back   Mitsubishi Lancer Register Forum > General Stuff > Lancer Chat
Old 04-12-2018, 06:20   #1
Rampant
Profound thinker
Rampant's Avatar
Car: Evo VI GSR Import (& '16 WRX STI & gen1.5 997 Turbo)
Headlights on my Evo 6 are very poor and so dim that I am getting the impression, at times, that my lights aren't even working and have to click them off and on to check they are actually lit.
What, if anything, do early Evo owners do to improve this and with what results, please?
I've installed a road legal upgraded Philips bulb set (Racing Vision) last night, but haven't driven with them yet, but can't see there's much improvement when I tested them against the fence on my driveway...
Yours Aye
Mark H
Je cherche l'orgasme d'auto
J'ai trouve l'orgasme d'auto
Old 04-12-2018, 06:29   #2
evosmudge
evosmudge's Avatar
I got a set of led lights from lighting the way on facebook and it made
A huge differance
evosmudge is offline   Reply With Quote
The Following User Says Thank You to evosmudge For This Useful Post:
Rampant (04-12-2018)
Old 04-12-2018, 07:03   #3
madmatt
madmatt's Avatar
I have ordered some Osram Night Breaker Laser bulbs, but haven't fitted them yet. They seem to be the best solution for conventional light (no led, no hid, etc.). Will fit them when I get them and report here.
The Following User Says Thank You to madmatt For This Useful Post:
Old 04-12-2018, 08:17   #4
infamous pa
Car: Evo 6 tme
It might be worth checking that your getting alternator voltage at your lights (14V + with the engine running) and checking both of the earths have a low resistance as that will cause an rim light
infamous pa is offline   Reply With Quote
The Following 2 Users Say Thank You to infamous pa For This Useful Post:
Mr Ralliart (05-12-2018), Rampant (04-12-2018)
Old 04-12-2018, 09:58   #5
kes205
Car: EVO VI GSR
I was the same the Evo 6 lights are terrible and I found it didn't matter what bulbs I put in them they were never very good. But then I put some Led bulbs in and they are amazing. Don't seem to dazzle oncoming traffic as they make a nice beam pattern and they are beyond bright and can now actually see the road. The issue is there are so many different LED bulbs available. I bought mine a couple of years ago and they look similar to the expensive ones phillips (ultinon) now sell but mine were nowhere near that price.
kes205 is offline   Reply With Quote
The Following User Says Thank You to kes205 For This Useful Post:
Old 04-12-2018, 10:06   #6
Shakey_Jake188
Shakey_Jake188's Avatar
Car: BRSCC Mazda mx5 Race Car #188, Evo 6 Tommi Makinen Edition and Evo 5 GSR
These. Loads better than standard lights.
Sent from my SM-G950F using Tapatalk
600bhp+++ Evo 6 TME Road & Sprint Beast
Shakey_Jake188 is offline   Reply With Quote
Old 04-12-2018, 10:55   #7
zestyfesty
I replaced the 19yr old lights and bulbs with Philips white or night vision or similar and marked improvement
zestyfesty is offline   Reply With Quote
Old 04-12-2018, 12:17   #8
RichW
Moderator
RichW's Avatar
Car: E6 GSR -> E9GT -> e46 M3 -> M3 CSL -> E6 RSII / M-Sport BMW / GIXXER 750 K5
I am currently using some Philips +130% ones which made a difference, I fitted them in both the Colt and Evo. However the lifespan is very poor and so I am using the Osram Night Breaker in the Colt now and they seem just as good but *alot* longer life span, so would recommend those over the Philips. The Evo hasn't been used though I imagine the lifespan would be the same as they are the same H4 bulbs, though the stop start doesn't help lifespan of bulbs IMO and the colt does have that, the Evo obviously doesn't.
LED's in the colt looked nice and white but dazzled other drivers and the high beam was no better than the low beam, they didn't stay in even a day, sent them back to Amazon and got a refund.
RichW is offline   Reply With Quote
The Following User Says Thank You to RichW For This Useful Post:
Trev-the-Rev (04-12-2018)
Old 04-12-2018, 13:27   #9
Trev-the-Rev
Car: V1 RS450 Extreme.
Just ordered a set of Osram Night Breakers for the Evo, so shall post up my findings once installed.
Never run out of track, grip and ideas at the same time
Trev-the-Rev is offline   Reply With Quote
Old 04-12-2018, 13:38   #10
154073
Little point wasting time and money on bulbs or cheap HID add on kits imo. Try and find a place that does Xenon projector retrofits into the existing lights....Will be night and day, literally.
I recently changed from a oem halogen light to a xenon projector and the difference was astounding.
154073 is offline   Reply With Quote
Old 04-12-2018, 14:14   #11
grants
grants's Avatar
One of the reasons for crap headlights is down to the Mitsi design
Name:  e6 headlights.JPG
With a "kiss" description the wires from the headlight bulbs eventually go to the column switch and then to earth/ground
What is not shown is length of the wires. It's between 15 to 20ft which causes a volt drop in the order of 1Volt and 20%(ish) light output
Why did Mitsi do this??
Solution, without wiring changes, is higher output bulbs or LED Try searching for Philips H4 LED, they seam to have overcome the asymmetrical dip beam issue albeit at a cost of £70/pr (peanuts in Evo money)
HTH
Grant
The Following 5 Users Say Thank You to grants For This Useful Post:
Clivew (05-12-2018), Mita (04-12-2018), Mr Ralliart (05-12-2018), RichW (05-12-2018), Tom Dick (05-12-2018)
Old 04-12-2018, 15:16   #12
UTH
Car: VI Extreme RS450
I also have the one piece headlights in my Evo 6.....with the PIAA Night Tech bulbs.....also these bulbs in my foglights as well, so on full beam I have 3 different sets of lights on, with good bulbs, so VASTLY better than the poxy standard ones.
Bulbs here: http://www.piaa.co.uk/bulbs/bulbshow.asp?ID=nighttech
UTH is offline   Reply With Quote
Old 04-12-2018, 15:32   #13
grants
grants's Avatar
https://evoshop.co.uk/collections/pi...mance-products
Old 04-12-2018, 16:19   #14
Ali2000
Car: EVO 5
Another reason I'd like to add is "someone" said to me is that it's also due to the design, in that a narrow lens just doesn't put out as much as other bigger lens.
Ali2000 is offline   Reply With Quote
Old 04-12-2018, 16:29   #15
grants
grants's Avatar
Not a helpful load of ********
