ND long rod "drop in" job Evo 4 to 9 - Drive in/Drive Out - Mitsubishi Lancer Register Forum
Go Back   Mitsubishi Lancer Register Forum > Marketplace > MLR Platinum Option Trader: Norris Designs
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 03-09-2013, 13:53   #1
Norris Designs
Norris Designs's Avatar
Car: 12 BMW 1M, 14 Audi Q7, Motec CBR600RR, Gallardo Spyder, LT 4WD Project, 1100hp+ E9 SWB
As per title we have been offering the conventional length rod (150mm) drop in with ND spec JE forged pistons for some time. We have had 156mm long rod ND spec compatible pistons made using the latest JE forging a while back. Just hadn't put a thread up due to time constraints.
So our MLR offer is for £2999 Inc Vat, you "drive your car in" (So long as the engine is in good running order already) we then strip, measure, hone and fit the below parts, run in the engine and fill with premium grade synthetic oil. Afterwhich you "drive it out" again.
Parts we fit as part of this deal are as below;
ND spec JE forged piston set 85mm bore
Manley H beam 156mm steel forged con rods
ND uprated metal head gasket
ND H11/L19 head stud kit
New cambelt and balance belt
Running in oil and filter
Titan race 15/50 fully synthetic oil and oil filter
Full run in procedure completed prior to pick up also
We can also offer the Manley I Beam rod for those wanting to go close to or over 600Hp. This incurs extra cost of the premium version rod (+£330 + Vat extra). The bottom end would then be rated in excess of 800Hp (Would advise fitting ARP main studs at this stage also).
We need the car for approx 1 working week but some vehicles may be needed for 2 working weeks, dependant on our workload at the time and if other work is requested or not.
Enquiries by PM, email or phone please.
Si
ND E9 SWB Best times;
Best 1/4: 8.22 Sec (Pod Sept 2014) - Best 1/4: 171.3 Mph (Shakey Oct 2013) - Best 30-130: 4.15 Seconds (Pod Sept 2014) - Best 0-60mph: 1.71 seconds - Best 0-100mph: 3.35 seconds - Best 0-150mph: 6.72 seconds - Top Speed: 201.42Mph (Marham 2008) - Standing Km: 195.5Mph (TOTB 2014)
Former World Drag record holder: 8.22
TOTB V Overall champion 2006
TOTB XII Overall runner up 2013
TOTB XIII Overall runner up 2014
TOTB XIII Handling Shootout winner and FTD
Norris Designs is offline   Reply With Quote
The Following 3 Users Say Thank You to Norris Designs For This Useful Post:
bennydavis (13-11-2013), Kevin Troy (19-10-2016), L19KEY (12-05-2014)
Old 10-09-2013, 17:34   #2
rob2.2
Car: Evo 6 Track Car.
Send a message via MSN to rob2.2
Hi
how much for just the parts as my cars at veysport with a bent conrod so I need all the above parts
thanks Rob
2.3 stroker evo 8 engine, tts205b, sd mapped by Lee5, stripped out, safety device cage, race seat and harnesses.
rob2.2 is offline   Reply With Quote
Old 11-09-2013, 17:05   #3
Norris Designs
Give me a call at work tomorrow Rob, parts are in stock and will work you out a price. (01225) 700748, been off today.
Si
Old 11-09-2013, 22:16   #4
Babylon6
Chief Nerf Herder
Babylon6's Avatar
Car: VII GT-A
If the engine needed a rebore, how much extra would that add?
Babylon6 is offline   Reply With Quote
Old 12-09-2013, 11:06   #5
Norris Designs
It's a bit of a game changer that one, costs much more as the engine has to be taken out, fully stripped down, machinined, blueprinted and fully built before being re-fitted. Take a look at the below thread to see the sort of result that yields.
https://www.lancerregister.com/showthread.php?t=436614
Si
Old 12-09-2013, 12:10   #6
2+barplease
2+barplease's Avatar
Car: Porsche 911 C4S + Evo 5 + SL350
I have a drop in job from Si Norris, (well it was meant to be a rod job but I had a cracked piston, so a set of pistons was fitted) its done 5000 miles and doesn't use a drop of oil. Runs like a sewing machine
Evo 5 as yet unmodded.....
2+barplease is offline   Reply With Quote
The Following 3 Users Say Thank You to 2+barplease For This Useful Post:
ChrisT (13-11-2013), Evo4dav (06-12-2013), Norris Designs (12-09-2013)
Old 12-11-2013, 22:08   #7
rob2.2
this offer still available Simon?
if so will be calling you later in the week
Old 13-11-2013, 10:26   #8
Norris Designs
It sure is Sir!
Si
Old 13-11-2013, 15:54   #9
CRABBY21
CRABBY21's Avatar
Car: EVO 9 FQ 360
Just out of curiosity... what does this give in relation to the performance - other than improved wear and tear?
My IX is currently at 395 / 395 and at some point I would like to get that up to around the 450bhp mark.
Might need to spend a bit more to do that though
LIFE'S A GAME...... PLAY THE GAME OR IT PLAYS YOU!
CRABBY21 is offline   Reply With Quote
Old 13-11-2013, 16:13   #10
Norris Designs
In reality this conversion offers little to no extra hp in itself, but it makes the engine stronger and more capable of holding higher hp. If you try to run 450Hp on the stock engine you are likely to snap a rod. Some people get away with it and others don't. We would not be prepared to take that risk.
Once done the engine will be fine for approx 550Hp using H beam con rods and way over that figure over using I beam con rods.
Hope that helps?
Si
The Following User Says Thank You to Norris Designs For This Useful Post:
Old 13-11-2013, 16:17   #11
CRABBY21
CRABBY21's Avatar
Car: EVO 9 FQ 360
Hope that helps?
Si
Thanks for the quick reply Si.
I definately need to do a bit more research reagarding what to do with the engine, i'm not that technically minded.
Old 13-11-2013, 16:42   #12
Norris Designs
No problem, very welcome! Send me an email [email protected] if you want to discuss the best route for your car.
Si
CRABBY21 (13-11-2013)
Old 03-01-2014, 13:39   #13
Norris Designs
Done a fair few of these now guys! On our third stock order of pistons since design! Call to book in.
Si
Old 25-01-2014, 10:47   #14
rob800
the price is 2499 with vat what would be the price for i beam rods and arp studs? as i live in the channel islands i dont pay vat?
rob800 is offline   Reply With Quote
Old 27-01-2014, 11:09   #15
Norris Designs
Hi Rob
Price breaks down as below;
ND long rod drop in job £2415.83 Vat Exempt
I Beam rod upgrade £300.00 Vat Exempt
ARP main studs and fitting £118.00 Vat Exempt
Total £2833.83 Vat Exempt
Let me know if you want to book in?
Si
ChrisT (09-03-2018)
