Uprated actuator needed...? - Mitsubishi Lancer Register Forum
Old 28-05-2020, 22:53   #1
Thebooosh
Car: Scotia White 5 GSR
Hi All,
When running an 80 series turbo at higher boost is an uprated actuator needed?
Regards
Ben
Thebooosh is offline   Reply With Quote
Old 29-05-2020, 03:17   #2
Phil2333
Tarmac Tyre Shredder
Phil2333's Avatar
Car: Evo 6, Forged 2ltr 8MR engine...405/400
I run 1.9 bar peak on my 80 series. No issues with the standard 9 actuator.
Some recommend the turbo smart ones, but I've no experience with them.
My Evo 6 resto thread...
Phil2333 is offline   Reply With Quote
The Following User Says Thank You to Phil2333 For This Useful Post:
Thebooosh (29-05-2020)
Old 29-05-2020, 07:17   #3
stu8
stu8's Avatar
Car: Evo V - geekmapped.com
Nope, standard actuator is fine for anything the standard turbo can throw at it, assuming the boost control is good. The right boost solenoid or boost controller is far more important
Stu
CPP Motor Developments -
RG Motorsport -
The Following User Says Thank You to stu8 For This Useful Post:
Old 29-05-2020, 14:15   #4
Thebooosh
Thanks for the replies.
@phil2333 I dont think I will be going much higher than 1.8 bar so that's great.
@stu8 good news, I run a 3 port boost solenoid controlled via the stock ecu
Old 29-05-2020, 17:46   #5
stu8
stu8's Avatar
SO long as its good enough quality and mapped correctly then all good
Stu
RG Motorsport -
Old 30-05-2020, 07:01   #6
sebas-chan
Car: EVO VI
what stu8 said.
I had to upgrade my actuator since the HKS EVC V boost controller only managed 1.2bar at 100 duty cycle... but that might also have been a worn out actuator.
With the upgraded one 60% duty cycle on the BC is enough to reach 1.5bar
sebas-chan is offline   Reply With Quote
Old 02-06-2020, 21:04   #7
Sparksgsr
Sparksgsr's Avatar
Car: viii fq320 & vi gsr
Originally Posted by sebas-chan View Post
what stu8 said.
What actuator did you go for bud? Have the same issue with mine avcr @89% holding 1.4bar on an 80 series
Sent from my SM-G960F using Tapatalk
VIII GSR - MEDIUM PURPLE PEARL
VI GSR - RED +
STICKERS
Sparksgsr is offline   Reply With Quote
