Help wanted,front diff failure? - Page 4 - Mitsubishi Lancer Register Forum
Thread Tools Rating: Thread Rating: 19 votes, 4.89 average. Display Modes
Old 18-07-2002, 08:13   #46
scoobymike
So you must be Chris then.
I wanted to come to the slalom (only watching as for the price to competet there you can drive 12 laps on the Ring, I know what I chose). On the same morning I was picking up my new suspension but unfortunately I took me more than 1 hour more than planned so skipped the slalom. In the end this was a good decision then till I would have arrived the others have already left the place.
Regarding Sports ECU and PE remap. I had the Sports ECU and then went for the PE, so nuff said.
Mike
scoobymike is offline   Reply With Quote
Old 18-07-2002, 11:04   #47
Rallyman
dutchEvo6,
Goeie Morgen! I'm in the same situation as you concerning the ECU upgrade.
My Dawes Device is on its way, and I'd like to upgrade the ECU to be able to run 1.4-1.5 bar safely.
Not sure whether to go for the Ralliart Sports ECU or the PE re-map. I have heard the Sports ECU makes the engine a bit more revvy, but I'm actully looking for mid-range boost.
Rallyman is offline   Reply With Quote
Old 18-07-2002, 11:10   #48
Rallyman
I forgot to ask about the delta dash.
What is it exactly?
Old 18-07-2002, 11:12   #49
Rallyman
Ignore the previous post.
I found the info at www.ecutek.com
Old 18-07-2002, 23:22   #50
dutchEVO6
diff
Mike,
On my next visit later this year I will be visiting the guys again so maybe we can meet then.
Do you have an air/fuelratio gauge on the car? Is the car still running rich enough.Have you got any idea till what boostlevel the PE has got fuel maps.
Do you have an uprated fuelpump too?
I do want to play safe!
Rallyman ,I tried the dawes and did not like it.
When i have changed the ECU I want to set the boostlevel by mounting another jet , I have a larger one on the car now too, otherwise the fuelcuts drive me crazy.
Dawes keeps the wastegate closed till the boostlevel has been reached to open it ,but on half throttle situations and changing gears before the redline all was goiing very rough ,it is all or nothing with the dawes.
I think with the standard setup it all goes a it more smooth.
But I am no expert ,it was the feeling I had and did not like.
bye chris
dutchEVO6 is offline   Reply With Quote
Old 10-10-2002, 16:53   #51
AndyF_RSX
Underground mapper
AndyF_RSX's Avatar
Car: E3 GSR (geek special racer!!) & E9 MR FQ340
Heave Ho,
It may appear you have another member to the knackered front LSD club.
Pulling into work this morning, right hand turn, full lock I got a loud clunking coming from the front of the car.
Only happens on right hand turns at very slow speeds (less than about 15mph)
Put the car up on the ramps tonight and got Su to spin the wheels while on full lock and they appear to get stuck and require extra force to move and then free up for the next rotation.
Does this sound like the same problem?
Andy
AndyF_RSX is offline   Reply With Quote
Old 11-10-2002, 12:30   #52
Heave Ho Six
Sounds like it, if the knocking/clunking can only be felt or feels strongest on the driveshaft then it points to the diff case bolt failure...as long as it is not a CV joint gone but you should be able to tell that.
I will sort out some info for you and email it.
Heave Ho Six is offline   Reply With Quote
Old 25-10-2002, 08:42   #53
AndyF_RSX
Underground mapper
AndyF_RSX's Avatar
HH6,
You have E-mail again. Can't view the pdf you sent me
Probably going to give this a go this weekend. Will let you know how I get on.
Andy
Old 28-10-2002, 07:37   #54
AndyF_RSX
Underground mapper
AndyF_RSX's Avatar
Thumbs up
Well,
I finally managed it.
Pictures will follow when I get chance to download them from my camera (bit crappy but it gives a reasonable impression)
Big thanks to HH6 for all the info and to [email protected] for the bits and being on the end of the phone when I needed it
Procedure is fairly straight forward although it would have helped if I had 2 people working on it instead of just me.
Remove exhaust front pipe
Drain gearbox and transfer box oil
Pop out both driveshafts (easier to do if you undo the hubs from the suspension strut)
Screw a 8mm nut into the hole on the output shaft on the transfer box side and then use a slide hammer to pop the shaft out.
Undo all the transfer box mounting bolts (including those on the top of the box that you can't see from underneath )
Slowly edge the transfer box away from the g/box
It will come out so far and then seem not to move..... The best option at this point is to insert a pry bar (or similar) into the hole in the middle of the transfer box and gently tap the centre shaft towards the g/box.
The transfer box will then come free and can be lowered to the floor. As it comes free and you lower it down, remove the propshaft from the rear of the t/box. BE careful. When the transfer box is free it is quite heavy for one person to hold
Once out, you can then remove the bolts holding the 2 halves of the box together and separate the halves by levering them gently with a screwdriver.
Then remove the diff assembly and remove the 14mm bolts holding the front diff inside. As you remove these, the ring gear will separate from the assembly and can be removed.
Inside you will find your front diff and probably a few bolt heads (I had 2 sheared off and 2 still in place)
Remove any bolts still in place and the diff will separate into 2 halves. Be careful that you don't tip up one half and have all the cogs fall onto the floor (not that I'd do anything like that of course )
Replace the bolts with new ones (with a bit of Loctite) and then put everything back together again in the right order and refill the fluids. It's a lot easier to raise the transfer box with 2 people and the assistance of a trolley jack (thank you Mrs RSX for the help )
Pretty simple really. No more loud clinking noises when turning and car feels a lot sharper on turn in.
Andy
The Following User Says Thank You to AndyF_RSX For This Useful Post:
James5 (05-02-2014)
Old 30-10-2002, 12:22   #55
Pete-TME
Very interesting thread. I'm having an identical problem on my E6 TME 2001. A more recent car, but it's been in to Mitsubishi three times, they replaced the left suspension assembly, but to no avail. This thread and diagrams from HH6 will help enormously, thanks guys.
Thank god for warranties.
Pete
Pete-TME is offline   Reply With Quote
Old 04-03-2005, 11:04   #56
itmustbejock
itmustbejock's Avatar
Car: Lancer Evo 6 GSR, FRST crashed, 1990 bmw m5
ME 2 , Having just owned the car less than a week , also sounds like a wheel bearing is away on the left front!!!, cud these two problems be related??? also does anyone have any of these diff bolts for sale????
itmustbejock is offline   Reply With Quote
Old 05-05-2005, 22:23   #57
FoZzY
FoZzY's Avatar
Car: Vw dubTransporter T5 Giant ,X1 Full susser,Yamaha XTZ660Z Tenere a ktm 200exc and a few Kayaks!
Send a message via MSN to FoZzY
Got the same problem with my Evo 6 GSr this info is priceless thanks for the informative info, ive allready spent £50 having it looked at to no avail.
FoZzY is offline   Reply With Quote
Old 06-05-2005, 07:12   #58
FoZzY
FoZzY's Avatar
Im trying to find some M8 bolts today and do the job saturday, anybody what oil i will need for the Diff/transfer box?
Old 07-05-2005, 23:31   #59
FoZzY
FoZzY's Avatar
Stripped the trensfer box down today and the bolts were fine, put it back together, still scratching my head anymore ideas?
When people mention top mounts are they referring to engine mount's or to shock mounts?
Old 23-08-2007, 13:19   #60
nutcase9
nutcase9's Avatar
i live near a place that sells bolts to nearly every place in the world....and if enough people want these bolts...12.9 then i will buy them,keep a few and sell the rest at cost....
nutcase9 is offline   Reply With Quote
