rotational noise when corner is loaded - Mitsubishi Lancer Register Forum
Old 13-03-2020, 20:49   #1
Sparksgsr
Sparksgsr's Avatar
Car: viii fq320 & vi gsr
Evo 6 making a rotational noise when corner is loaded like a clicking/knocking increasing with load and speed when right hand down noise is coming from front near side
Have just swapped engine for a forged unit and changed the ns driveshaft as there is a faint rotational noise that I thought was the driveshaft but seems that is a separate issue
Hardly noticeable when straight seems to get worse with higher speeds and taking corners tighter
Just got back I did check the wheel nuts while out earlier
VIII GSR - MEDIUM PURPLE PEARL
VI GSR - RED + STICKERS
Sparksgsr is offline   Reply With Quote
Old 14-03-2020, 07:42   #2
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
Aren't those the regular symptoms of broken diff pins - or something like that? There's been plenty of threads on this in the past.
Phil
Old 14-03-2020, 10:42   #3
Sparksgsr
Sparksgsr's Avatar
Not sure, I had a search but didn't find much on the forum, I am thinking possibly the common diff bolt issue
I wonder if the evo 4 & 6 front diffs are different as i used a new supposed 6 driveshaft opposed to a evo 4 driveshaft
Old 14-03-2020, 11:20   #4
McGoo60
Have you read this one?
https://www.lancerregister.com/showthread.php?t=4037
The Following User Says Thank You to McGoo60 For This Useful Post:
plip1953 (14-03-2020)
Old 18-03-2020, 07:56   #5
Sparksgsr
Sparksgsr's Avatar
Was the driveshaft, bought it from a member on here last august, 15mm in and out play garage said something like a circlip is missing inside the boot
Stuck my old one back on and noise cured
better check the other at some point as I bought a pair that were in good condition supposedly
still got a possible diff noise rotational regardless of steering angle or clutch engaged/disengaged
The Following User Says Thank You to Sparksgsr For This Useful Post:
plip1953 (18-03-2020)
