Oil Quantity, Grade and Specification for Evo Transmissions - Mitsubishi Lancer Register Forum
Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 24-09-2016, 19:03   #1
Clivew
Transmission Dynamics
Clivew's Avatar
Oil Quantity, grade and specification information for the Evo Transmission.
5 speed gearbox - GL4/GL5** spec 75w90 - 2.8 litre
6 speed gearbox - GL4/GL5** spec 75w90 - 2.2 litre
Evo X 5 speed gearbox - GL4/GL5** spec 75w90 - 2.5 litre
Evo X SST transmission - SSTF-1 fluid - 5.5 litre
E4/5/6
Transfer box - GL5 spec 75w90 - 0.62 litre
AYC diff gear oil - GL5 spec 75w90 - 0.41 litre
AYC clutch bath - ATF-SPIII - 0.70 litre
AYC Hydraulic system + pipes to AYC - ATF-SPIII - 1.0 litre
RS rear diff - GL5 spec LS 75w90 - 0.55 litre
E7/E8 260
Non ACD Transfer box - GL5 spec 75w90 - 0.55 litre
ACD Transfer box - GL5 spec LS 75w90 - 0.60 litre
AYC diff gear oil - GL5 spec 75w90 - 0.55 litre
AYC clutch bath - ATF-SPIII - 0.65-0.70 litre
AYC & ACD Hydraulic system + pipes to ACD and AYC - ATF-SPIII - 1.9 litre
E8/9
AYC/SAYC diff gear oil - GL5 spec LS 75w90 - 0.55 litre
SAYC clutch bath - ATF-SPIII - 0.65-0.70 litre
SAYC & ACD Hydraulic system + pipes to ACD and SAYC - ATF-SPIII - 1.9 litre
ACD Hydraulic system + pipes to ACD - ATF-SPIII - 1.5 litre (E9 GT Model using
RS Rear diff)
E10
ACD Transfer box - GL5 spec LS 75w90 - 0.9 litre
SAYC clutch bath - ATF-SPIII - 0.55-0.60 litre
ACD Hydraulic system + pipes to ACD - ATF-SPIII - 1.5 litre (RS Model using
RS Rear diff)
Standard oil weight specification is 75w90 for the Gearbox, transfer box and rear differential. A 75w140 weight oil can be used to give better protection when oil temps are high, such as on track, or in high powered cars. The negatives of this are higher transmission losses at normal temperatures, and possible stiffness in the gearchange when the oil is cold.
AYC and SAYC - AYC used on E4-7/E8 260 uses a NON LS GL5 gear oil to lubricate the differential part (Left side casing) - AYC and SAYC used on E8/9 uses an LS gear oil to lubricate the differential (Left side casing)
LS = Limited Slip gear oil for plated limited slip differentials, or non LS gear oil with a friction modifier added, such as Redline Friction Modifier.
ATF-SPIII is Automatic Transmission Fluid with special additives such as friction modifiers.
ATF oils such as Millermatic ATF-SPIII-WS exceeds Mitsubishi diaqueen SPII, III & IIII specs.
GL4 spec oils are required for gearboxes. **Some GL5 spec oils such as Millers CRX NT or CRX LS NT can be used in gearboxes to give extra protection, but **some GL5 oils are corrosive to syncros so must not be used. Check the manufacturers recommendations.
GL5 spec oils have extreme pressure additives which are required to protect hypoid CWP gears that are in transfer boxes and rear differentials.
If using a plated front limited slip differential in an E4/5/6/7/8/9 transfer box, an LS oil must be used in the gearbox to correctly protect the metal clutch plates in the front differential. Some LS oils are too slippery for the gearbox, but Millers CRX LS oils work very well in the Evo gearbox.
The gearbox oil system pumps oil into the centre bell of the transfer box lubricating the front differential. This oil is separate from the transfer box oil.
An LS oil must not be used in the gearbox if a helical 'TORSEN' diff is used in the gearbox (centre diff) or transfer box (front diff) These types of differential include the standard helical, Quaife and Wavetrac. Helical differentials require internal friction to enable torque transfer. If the oil is too slippery as with LS oils, the torque transfer bias will be reduced.
[email protected]
The Following 54 Users Say Thank You to Clivew For This Useful Post:
4G63EvO (01-12-2017), Ads9 (24-09-2016), Andrew B (24-09-2016), andymrfq320 (29-10-2016), ant1 (24-09-2016), Bava (24-09-2016), Benbo (24-09-2016), D2 (23-09-2017), Dan ep3 turbo (25-09-2016), darrenevo123 (25-09-2016), David86C (17-03-2017), denboy (05-08-2018), djmisio85 (15-11-2018), EDK (28-01-2018), Edkeo (29-08-2018), feeblebob (24-10-2017), Goginawa (24-09-2016), Gscott (28-09-2016), GUM EVO (03-02-2020), irv0fran (26-10-2017), katadikos (26-09-2016), Kevin Troy (24-09-2016), Kevo1876 (12-02-2017), leeslancer8 (24-09-2016), Lolo la Torche (16-05-2018), Lynmorganevo (26-09-2018), [email protected] (23-02-2020), michty_me (27-06-2018), Mita (24-09-2016), mlau1294 (24-09-2016), MrEvo665 (24-09-2016), nickyd150 (17-07-2017), Parkur MR-SST (25-01-2019), peeler (15-05-2017), R33TWIST (12-09-2017), Realbadman (20-08-2017), RichW (24-09-2016), river evo 6 (24-09-2016), Robbo777 (25-09-2016), Scooby-93 (24-09-2016), Sephiro (15-05-2017), shellis (04-12-2016), squeakyclean32 (30-05-2018), Stallion (24-09-2016), strange_days_uk (12-09-2017), stu8 (25-09-2016), SUSHILUVA (30-04-2019), TimC (25-09-2016), tont2002 (24-09-2016), top gun (09-12-2016), Verstegutta (13-12-2017), W13NTD (20-08-2017), will2 (17-07-2017), zestyfesty (23-06-2017)
Old 24-09-2016, 19:42   #2
Ads9
Ads9's Avatar
Car: EVO IX FQ320, 2.2 Cosworth, TT S214b, Link G4+ Geekmapped by me (hasn’t gone bang. Yet.)
Thank you for spending the time to put this up, top man
Ads9 is offline   Reply With Quote
Old 24-09-2016, 20:16   #3
Clivew
Clivew's Avatar
No problem, I'll add Evo X soon!
[email protected]
The Following 5 Users Say Thank You to Clivew For This Useful Post:
Ads9 (25-09-2016), MrEvo665 (24-09-2016), nickyd150 (25-09-2016), Robbo777 (25-09-2016), Stallion (24-09-2016)
Old 24-09-2016, 20:24   #4
river evo 6
river evo 6's Avatar
Thanks mate,
Evo6 gsr, mapped by evotune.
Power = full
Torque = sometimes.
river evo 6 is offline   Reply With Quote
Old 24-09-2016, 21:22   #5
Xmn777
Xmn777's Avatar
Car: Evo 8 GSR
Thanks for this
Xmn777 is offline   Reply With Quote
Old 24-09-2016, 21:30   #6
Clivew
Clivew's Avatar
Evo 10 info added.
[email protected]
stu8 (25-09-2016)
Old 24-09-2016, 21:36   #7
MrEvo665
MrEvo665's Avatar
Car: Evo X FQ400 (By WRC Developments)
Originally Posted by Clivew View Post
Evo 10 info added.
Great write up, many thanks.
MrEvo665 is offline   Reply With Quote
Old 24-09-2016, 21:50   #8
Goginawa
Zero Fighter
Goginawa's Avatar
Car: EVO IX FQ 320
Brilliant info Clive,thank you !
MAPPED BY ORACLE
evoless ,now something on a different Note
Goginawa is offline   Reply With Quote
Old 24-09-2016, 23:26   #9
Benbo
Much appreciated ����
Benbo is offline   Reply With Quote
Old 25-09-2016, 05:54   #10
sean e5 red
Any info regarding the Evo 1/2/3?
sean e5 red is offline   Reply With Quote
Old 15-05-2017, 15:46   #11
JOHNDQ
JOHNDQ's Avatar
Car: Evo VII RS SPRINT... Ex Evo IX GT and Evo IX FQ320
Clive do you have any recommendation on any make of oils for the RS drive train or are they ok as long as spec is correct take it you dont sell the oil as im close to you in Bedford? You did advise me a while back when you welded a coolant sensor take off for me on my MG but i cant remember now Evo is a 7 RS Sprint, thanks for any info
JOHNDQ is offline   Reply With Quote
Old 17-07-2017, 16:25   #12
Christopher
Car: Evo 5 468ATW(meths map)408ATW(optimax)
Good afternoon,Clive
I Recently bought Jamies (Tonks)5 RS,which you rebuilt the gearbox for,and,if you can remember,what gearbox oil did you recommend to be used?
Thanks,in advance,for your help.
Chris
Hope this one costs me less
Christopher is offline   Reply With Quote
Old 12-09-2017, 14:10   #13
Ryan1985
Car: Evo VIII FQ-300 & EP3 CTR
Clive, I have a Evo 8 FQ-300. Is the following all I need?
Ryan1985 is offline   Reply With Quote
Old 23-09-2017, 15:43   #14
Ryan1985
Anyone?
Old 23-09-2017, 16:46   #15
D2
North Scotland R.O
D2's Avatar
Car: 2001 Evo VII GSR, 1999 Evo VI GSR, 2007 Evo IX MR FQ360, 2013 RRS Overfinch GTS, Golf 7 GTD DSG,
Anyone?
If it's a service and you are doing all the oils then you'll also need -
D2 is offline   Reply With Quote
