Another Evo 4 Restoration Thread - Page 2 - Mitsubishi Lancer Register Forum
Old 20-06-2020, 13:54   #16
McGoo60
Awesome work!
The Following User Says Thank You to McGoo60 For This Useful Post:
Pushpex (01-07-2020)
Old 01-07-2020, 12:55   #17
Pushpex
Stripping the driveshafts
Coat of rust converter and then paint
Cut back the lip on the rear brake sheild for the brembos
Knuckles back from powder coating
Powder coaters got powder in the tapered joint so made a 7 degree reamer to clean them out
Turbo before and after nickel plating the pipes
Cusco mounts were starting to rust and underneath the paint was soft where they had been in contact with the seam sealer
Repainted Poseidon blue
M2 turbo elbow
Pushpex is offline   Reply With Quote
The Following User Says Thank You to Pushpex For This Useful Post:
evo5d (01-07-2020)
Old 01-07-2020, 15:33   #18
Dave-Cee
Climate Changer
Dave-Cee's Avatar
Car: MAD forged 2.2 IX FQ 340 PLG Leccy Bloo
What are you doing with the old O2 housing
Dave-Cee is offline   Reply With Quote
Old 01-07-2020, 19:00   #19
Andy1986
Andy1986's Avatar
Car: Evo 8 (260)
In the pictures where you have painted with the epoxy did you just take the rust patches down to bare metal and repaint or did you do the entire area back to bare metal?
Andy1986 is offline   Reply With Quote
Old 01-07-2020, 20:52   #20
Pushpex
I took as much of it back to bare metal as I could and made sure that any paint left was solid and scuffed up by the wire wheel
Old 02-07-2020, 17:05   #21
vocoleil
Can't wait to see how it turns out.
vocoleil is offline   Reply With Quote
Old 02-07-2020, 17:50   #22
Pushpex
New wheel bearings mounted on the knuckles
Delivery from Rosssport
Fitting the knuckles
And the ohlins shocks
Had to drill the powdercoat out of the holes
The brace seems to have crushed the seam sealer a little
Brembos mounted
McGoo60 (02-07-2020)
Old 02-07-2020, 19:05   #23
Dave-Cee
Climate Changer
Dave-Cee's Avatar
Driveshaft looks interesting
Old 02-07-2020, 19:14   #24
Pushpex
In what way I hadn't taken all the masking tape off if that's what you meant
Old 06-07-2020, 18:20   #25
Pushpex
Cleaning up the AYC, it works but it isn't pretty
Managed to snap a valve
New valve stem
Pump apart, had to grind off the top bolt
Nut welded onto the bolt
Cleaning and painting
Valves
Opening the valve carefully with a hammer
More spray painting
After removing as much rust as I could from the motor housing I treated the pitted steel with rust converter from rust.co.uk, it seems like the same stuff as hammerite krust, I'm not that impressed by the finish as it dries with cracks, anyone got advice on using this? or Phos-kleen?
Old 06-07-2020, 18:31   #26
Mita
Use Phoskleen B mate it will phosphate it . Then wash it with Chlor X DTS prior to paint . Use Scotch Brite for both procedures
Pushpex (07-07-2020)
Old 06-07-2020, 18:35   #27
Pushpex
Originally Posted by EvoIVCed View Post
I’d def like to know as I jus had to replace my driver side arch, after it being crappy for a while.
Looks like later evos have a support brace for them, might make one up for mine, look at this pic by Dave-cee
Old 06-07-2020, 21:59   #28
Pushpex
Unfortunately some of the bolts sheared in the turbo exhaust housing
Too much torque I guess
So I mounted it up on the mill at work
Back on
Old 06-07-2020, 23:37   #29
Dave-Cee
Climate Changer
Dave-Cee's Avatar
Oh yes by Dave Cee, on Flickr
The Following User Says Thank You to Dave-Cee For This Useful Post:
scottr89 (05-08-2020)
Old 07-07-2020, 12:34   #30
Pushpex
Perfect, just what I was looking for!
