Used parts clear out **updated 26/09/13** - Mitsubishi Lancer Register Forum
Go Back   Mitsubishi Lancer Register Forum > Marketplace > MLR Platinum Option Trader: CPP Motor Developments
Closed Thread
Old 18-08-2013, 14:29   #1
[email protected]
Moderator
gaz@cpp's Avatar
Location: (Cheshire) Crossing the finish line ahead of everyone else or parked in a ditch
Car: E6 RS Sprint No 1 (Now under going rebuild) R35 GTR
Massive price reductions just added, Grab a bargain
Here we have a few used parts to clear, all items are clean and tested where possible and come with a warranty where needed. Prices are all + Vat and shipping unless you would like to collect in person.
Evo 7,8,9 turbo technics elbow fits 80 series, mr turbo, S205/S209 £80
Set of brand new Evo 8/9 genuine Bilstein lowering springs, designed by Bilstein themselves for 8/9's fitted with Bilstein dampers for fast road use £sold
New style HKS VTA BOV £65.00
Gems Evo 8 3 plug ECU with Map sensor and air temp sensor £450
Autronic Evo 7 pnp ECU £500
Evo 7/8/9 5 speed engine and gear box mounts fitted with Poly bushes £60
Fuel swirl pot with 3x -6 fittings and 1x -8 fitting perfect for in boot pump upgrade £45
Varley Red top 30 battery in very good condition fully charged and tested £40
Original Evo 9 Carbon dash trims 2 piece with vents and switchs £80
Evo 7/8/9 Ralliart clock set £45
Evo 9 o/e rear spoiler has carbon wrap on blade to cover laquer (good upgrade for 260 models) £180
Evo 8 GSR 3 plug Ecu in case with loom and connectors for conversion £80
Evo 6 rocker cover in blue unmarked with pipe fitting welded in rear for breather, comes with carbon plu cover and stainless fittings £100
Evo 8 Mag rocker cover clean and standard £100
Forge recirc valve £45
Sard FPR with gauge £45
Evo 8 HKS turbo snail £45
2x SPA gauges with all wiring and sensors for oil temp and oil pressure (see demon tweeks or Spa web site for details of all features) will leave them in the mounting incase your fitting them in a E4,5,6 £100 also have SPA matching boost gauge when i find where i put it. all 3 gauges £150
Forge split VTA/Recirc valve looks new £60
Evo 4,5,6 rear boot garnish lights £25 pair
Evo 4 original front bumper lights no chips in lenses £45 pair
Evo 7,8,9 Turbo elbow autobahn88 £35
Evo 7/8/9 carbon air box £150
Pair of Evo 9 rear Bilstein dampers in good working order £80 pair
Evo 6 pair of silicone water hoses top and bottom £25 pair
Evo 6 RSX short/medium gear box with only 7000 miles from new. The box has been stored since removal 9 years ago and still looks new with no corrosion to the casing £700
Apexi AVCR complete with all wiring and sensors £170
Norris designs oil cooler removed from Evo 8 £100
OMP twin 52mm gauge pod universal £10
Autronic CDI comes with a free set of coils less than 1000 miles use £200
Evo 6 black Samco top and bottom water hoses £35
Evo 5/6 real carbon mirrors by Rallytech good unmarked condition £180 Sold Al
JMF manifold under 2000 miles use £380 Sold
GT35 Twin scroll HTA Turbo kit with twin wastegates and down pipe £Sold E70
Motec M800 3 plug Evo 8 ECU (will fit E9 with Mivec function enabled) £960 Sold bb
Evo 6 Rocker cover correctly refurbed (no sand blasting here) comes complete with Carbon Ralliart plug cover and oil cap and fitted with 2 -10 fittngs for breather system £150 Sold B/M
Turbo to air filter pipe fitted with HKS filter, taking up space £45 sold
Pair of standard Evo 9 rear lights in good condition £150 pair sold Al
Pair of Do-luck Evo 9 top and bottom water hoses in purple £25 sold
Carbon look battery box for "Battery in boot conversion" £20 soldbb
RS diff rear mounting bar delete kit and solid bushes for ears £100 sold ap
Tegiwa Exhaust manifold £250 Sold EP
Evo 456 B&M quick shift £30 Sold ken
Evo 4,5,6 Turbo elbow no cracks, never welded, looks like HKS item? £45 sold B/M
Evo 4,5,6 2 piece hose kit turbo to Maf & intercooler pipe to TB pipe connector £45 pair sold E/J
Evo 9 standard metal re circ valve £45 Sold
Evo 4,5,6 NR front brake ducts £45 sold tony
Evo 9 Greedy full Titaniumn cat back system in mint condition 4 months old £500 Sold Adam
HKS VTA £45 sold CG
Evo 4,5,6 black alloy radiator brackets with bushes £20 sold bb
Set of standard Evo 9 wheels with 4 legal Avon tyres need refurb cheap to clear £100 sold baz
Evo 7/8 carbon exhaust heat shield £20 sold stal
Evo 6 carbon slam panel blingy £20 Sold B/M
Rallytech Evo 5/6 carbon rear spoiler top blade £200 sold B/M
E8 carbon slam panel cover £45 Sold
Evo 4,5,6 black alloy hard pipe with black genuine tial bov (has air temp sensor fitted which will be removed) £70 sold CG
HKS 7460Kai again under 2000 miles use £995 Sold Mario
Evo 9 80 series turbo with oil feed and water lines 33k miles £380 Sold
Evo 4,5,6 AMS battery relocation kit with light weight dry cell battery fully tested £150 Sold
"Evo 5 to 9 used body panels in stock many priced to clear"
Please don't call asking for Evo 9 bumpers or headlamps at clearance prices all panels will be on a cash on collection basis no shipping.
Evo 5 front bumpers from only £50
Evo 6 front bumper from ony £80
Evo 5,6,8,9 front splitters from £70
Evo 5/6 rear splitters from £70
Evo 5 to 8 rear bumpers from £45
Evo 5 to 7 bonnets from £150
Evo 5-9 front wings from £150
Evo 5-9 rear spoilers from £100
Evo 5-9 boot lids from £50
Evo 5-9 side skirts from £25
Evo 4-9 doors from £30
Call on 01477500895
Email [email protected]
Or private message me
Visit Cpp motor developments forum section Here
Visit Cpp motor developments face book page
Here
gaz@cpp is offline
Old 18-08-2013, 15:55   #2
[email protected]
Moderator
gaz@cpp's Avatar
Swirl pot and engine mounts still available
Here
gaz@cpp is offline
Old 18-08-2013, 16:04   #3
[email protected]
Moderator
gaz@cpp's Avatar
Battery still available
Here
gaz@cpp is offline
Old 18-08-2013, 17:39   #4
[email protected]
Moderator
gaz@cpp's Avatar
Carbon E7,8,9 dash trims o/e
Clock set available
E9 rear spoiler available
Evo 8 Ecu with loom plugs available
Here
gaz@cpp is offline
Old 18-08-2013, 17:49   #5
[email protected]
Moderator
gaz@cpp's Avatar
Rocker covers available
Here
gaz@cpp is offline
Old 18-08-2013, 19:49   #6
[email protected]
Moderator
gaz@cpp's Avatar
All items still available on this post
Here
gaz@cpp is offline
Old 19-08-2013, 12:01   #7
[email protected]
Moderator
gaz@cpp's Avatar
Forge Recirc + VTA all in one available
Evo 4,5,6 HKS RS pipe Sold
Evo4,5,6 garnish lights available
Evo 4 front bumper lights available
Here
gaz@cpp is offline
Old 19-08-2013, 12:04   #8
[email protected]
Moderator
gaz@cpp's Avatar
7,8,9 Autobahn elbow available
Carbon air box E7,8,9 available
Here
gaz@cpp is offline
Old 19-08-2013, 18:08   #9
[email protected]
Moderator
gaz@cpp's Avatar
Rear bilstien dampers available
Evo 6 samco water pipes available
Evo 7,8,9 HKS hard pipe kit available
AVCR available
Here
gaz@cpp is offline
Old 21-08-2013, 18:54   #10
[email protected]
Moderator
gaz@cpp's Avatar
Evo 7/8 Carbon exhaust heat shield sold
"Dorris" designs up grade oil cooler removed from a Evo 8MR
Here
gaz@cpp is offline
Old 23-08-2013, 18:33   #11
[email protected]
Moderator
gaz@cpp's Avatar
Autronic CDI comes with a free set of coils less than 1000 miles use.
Here
gaz@cpp is offline
Old 26-08-2013, 14:55   #12
[email protected]
Moderator
gaz@cpp's Avatar
Genuine new Bilstein sport springs Evo 8/9
Here
gaz@cpp is offline
Old 26-09-2013, 17:34   #13
[email protected]
Moderator
gaz@cpp's Avatar
Updated 26/09/13
Here
gaz@cpp is offline
Closed Thread
