Evo VII-IX Caution - Electrics! - Page 4 - Mitsubishi Lancer Register Forum
Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 17-01-2011, 22:49   #46
Dave-Cee
Climate Changer
Dave-Cee's Avatar
Car: MAD forged 2.2 IX FQ 340 PLG Leccy Bloo
Originally Posted by neverneverman View Post
Thats not looking good
Those pins look corroded.
Even if they are not broken electrical contact will suffer through the corrosion.
Dave-Cee is offline   Reply With Quote
Old 17-01-2011, 23:34   #47
T18JRE
Car: viii fq300
Send a message via MSN to T18JRE
a job for the weekend i think, cheers for the heads up, great threads, again, stevolutions thread should be a sticky, great information
T18JRE is offline   Reply With Quote
Old 17-01-2011, 23:41   #48
stef jones
Car: evo 8, re-mapped pops and bangs, 9 bumpers, exhaust, filter dv etc etc
Originally Posted by EVL View Post
I've had the same problem on my VII. I didn't realise there was a problem until my lights refused to switch off!
i had the exact same thing happen on my 8. could smell burning and smoke coming from under the dash
stef jones is offline   Reply With Quote
Old 18-01-2011, 09:24   #49
Stevolution
Car: Vii FQ300
Originally Posted by Rab & Helena View Post
Here's a pic of the plug, the wire looks solid white to me. Any idea what this one is?
Arrow pointing to brocken pin.
Attachment 176011
Thats the plug that goes out to the wheel arch and i'm certain you will have to seal the loom like i did otherwise the water will return.
Here's my thread on how i did it https://www.lancerregister.com/showth...ght=ACD+lights
By the way If anyone has followed my thread and repaired there loom can you stick some pictures up on my thread please as mine aren't the best. Befores, during and afters
Stevolution is offline   Reply With Quote
Old 18-01-2011, 21:37   #50
Rab & Helena
Car: Evo 7 RalliArt ECU, 8mr Turbo, Hks super dragger, Hks induction kit,Mishimoto alloy rad,
Yeah i traced it by reading your thread .
Anyony know what all the wires in that loom are for? Or does anyone know where i can find a wiring diagram for the 7?
See This Evo Fear This Evo
Rab & Helena is offline   Reply With Quote
Old 18-01-2011, 23:00   #51
Dave-Cee
Climate Changer
Dave-Cee's Avatar
Checked mine today and they are bone dry.
I am still going to do the mod on the loom though.
Just a thought.. how many that have this problem still have the wheel arch liners in place?
Old 18-01-2011, 23:24   #52
nigwerwig
Car: evo 7
had look at mine last week and they were wet
it was dry 3 months back when look them
one of the pins had snapped off and the car would not start
i got it sorted i clean it up as much as i could for a sunday and needed the car for work monday
i all so put some grease on the back of the plug till i can get it sorted like above
im putting it down to the snow we had
nigwerwig is offline   Reply With Quote
Old 19-01-2011, 08:19   #53
Stevolution
Car: Vii FQ300
I've got mine fitted but the spray off the wheels still gets in between the inner arch and bodywork. This combined with our lovely british weather we get makes it a recipe for disaster.
Old 19-01-2011, 10:28   #54
Rab & Helena
What plug had a pin snapped off in your car?
Old 19-01-2011, 17:53   #55
Rab & Helena
I have been cleaning up the wires today & i would also take a look at your indicator wires in the wing. The protector sleeve was full of water so i cut the sleeve at its lowest point & left a little gap for the water to run out. Oh & i still have my wheel liners in place.
A little pic of the wires now.
Old 19-01-2011, 19:05   #56
GAZ5EVO
Car: None at mo
Indigo-GT 01495 719720
I am who I am
GAZ5EVO is offline   Reply With Quote
Old 20-01-2011, 11:44   #57
Rampant
Profound thinker
Rampant's Avatar
Had my wiring modified at NR Autosport on Tuesday.
The fix entailed removing the bottom-most wires from the affected connector blocks and using aftermarket waterproof connector blocks to reconnect those wires. The new connectors were then resecured above the original connector blocks...
A top job by NR and looks very professional indeed
But posting this has just got me thinking....
The wires that now remain in the original connector blocks have now just become the bottom-most wires. So now I'm wondering whether I will have similar problems with those wires!
Cheerz
Mark H
Je cherche l'orgasme d'auto
J'ai trouve l'orgasme d'auto
Old 20-01-2011, 12:07   #58
NR Autosport
NR Autosport's Avatar
Car: Evo X FQ360 & Lancer Turbo 1800 GSR
Cheerz
Mark H
No you won't have any further issues as the affected connector block was also re secured above the original connector blocks...
NR Autosport is offline   Reply With Quote
Old 21-01-2011, 06:45   #59
PJS
Right side indicators front and side failing
Hi guys my ix has a fault that comes and goes it's the driver side indicators front and side repeater not flashing and inside car fast flashing rear indicator working .it's like a bulb has failed but when I arm the alarm all indicators flash as normal? Could it be the footwell plug do any of these wires control front indicators
PJS is offline   Reply With Quote
Old 21-01-2011, 11:31   #60
Stevolution
Car: Vii FQ300
Sounds like a blown bulb or faulty relay.
Its worth checking the plugs in the footwell just to be sure. Let us know how you get on.
Similar Threads
Model Differences / Specifications youngsyr Lancer Chat 238 09-10-2019 22:15
Ross Sport - Used Parts Bargain Bonanza (updated regularly) Ross W Private Sales - Parts 146 11-01-2012 11:02
Brake and Clutch Lines By HEL Performance BHP MLR Group Buys 455 06-11-2011 06:47
Evo 5/6 Breaking parts full parts list itemsfrom £6 Xenonshop Private Sales - Parts 120 03-06-2011 12:06
US= Sport Compact Car - First Drive: Evo 9 Jakeg97 Lancer Chat 5 24-03-2005 09:29
