ACD lights - Corroded plugs in footwell - Mitsubishi Lancer Register Forum
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 05-01-2011, 18:22   #1
Stevolution
Car: Vii FQ300
After having numerous problems with the ACD system lights all coming on i've put this thread together to show how water has been working its way from outside inside. (behind kick panel)
Issues i've had in the past are: Uncontrollable wipers, Fuel pump failure, AYC pump failure but other members have had Faulty lights,Intercooler spray issues etc etc. All of these due to corroded pins/terminals within the passenger footwell (Plug C135)
Today i traced the wires from the suspect plug through the body and into the wheel arch.
I removed the wheel and inner arch to expose the loom which continues down under the arch and out to the front of the car up to the ECU.
Whilst under the wheel arch i noticed the loom going through a black box?
I peeled back the clips to find the wires are not sealled within the loom and to my suprise they were soaked in water and covered in grit and dirt.
The black box has no water tight seal so water can easily penertrate it and get between the wires causing a capillary effect!
From what i could see the only reason for it being there is to suspend to loom to prevent it hanging down on the inner arch.
The black box is attached by two push clips which go through the inner wing so i popped it off so i could make the loom water tight.
I cleaned and dried the loom then wrapped the exposed wires to seal them in.
There are some other wires in this area one of which is for the side repeater so i wrapped that up within the loom to keep it tidy
I did away with the black box as it would only start to hold water again and suspended the loom using some alternative fixing methods.
To finish off i've smeared silicon grease all over the loom and coated rubber gromet going into the car to aid water protection. Fingers crossed this will keep the water out.
Stevolution is offline   Reply With Quote
The Following 4 Users Say Thank You to Stevolution For This Useful Post:
Davy_tarbert (09-11-2014), purenirvana (06-09-2013), rutthenut (12-03-2016), zenwahwong56 (24-06-2013)
Old 05-01-2011, 19:11   #2
neverneverman
Life after Evo= Elise
neverneverman's Avatar
Car: The money pit has gone ! Lotus Elise now
Nice one Steve , Looks like that where the water is coming in ..
neverneverman is offline   Reply With Quote
Old 05-01-2011, 20:18   #3
Andy_8
Car: Evo VIII 260 "Standard".... tee hee
Nice one, hopefully that is the end of the chase
Nice to meet you toady over at Pauls
Andy.
Ex-Evo VIII 500+
Andy_8 is offline   Reply With Quote
Old 05-01-2011, 21:52   #4
evilpob
Car: Evo IX FQ360
How hard was it to take the wheel arch linner off?
evilpob is offline   Reply With Quote
Old 05-01-2011, 23:58   #5
Stevolution
Car: Vii FQ300
Dead easy mate, It's held on with numerous plastic insert clips and a couple of 10mm bolts. Start at one end and work your way to te other till its loose.
Old 06-01-2011, 00:01   #6
Stevolution
Car: Vii FQ300
Andy.
You too mate, Enjoy your new mods
Old 06-01-2011, 23:21   #7
Dave-Cee
Climate Changer
Dave-Cee's Avatar
Car: MAD forged 2.2 IX FQ 340 PLG Leccy Bloo
Very good info Steve.
I will check mine now.. Water ingress into those wires will have a capillary effect where it travels down to the plug..
Sealing it off at source where you have pointed it out should stop it but you will still have water from there down to the plug.
It would be worth taking off the electrical tape, drying it all out, then wrapping it all back up again to make it nice and dry.
Dave-Cee is offline   Reply With Quote
Old 06-01-2011, 23:29   #8
Stevolution
Car: Vii FQ300
Yeah you're absolutely right, That did cross my mind but i didn't have enough tape. Doh!
I've had a heater in the car overnight to dry the wires inside the car and have coated the loom/wires in silicon grease to help protect it.
Old 07-01-2011, 11:02   #9
Wolves FC
Car: Mitsubishi Evo IX FQ 360, 57 Reg-NOW SOLD! Looking for a Blue X FQ360 If anyone has one for sale???
Excellent guide!!! This is the cause of many,many Evo problems but Mitsubishi themselves don't seem to know about it.Some people even have to spend £500+ on new ACD pumps thinking their pumps gone but really its the ACD plug in the foot well that's corroded.
This should be made a sticky or at least bumped up every week so everyone see's it. Nice one Steve for taking the time to explain & photograph it all.
Wolves FC is offline   Reply With Quote
Old 07-01-2011, 14:27   #10
youngsyr
youngsyr's Avatar
Car: Evo VIII FQ 330 Sold, now in a BMW M3 (V8)
Definitely should be stickied - also traders should offer this as an additional option at service time, hint, hint.
youngsyr is offline   Reply With Quote
The Following User Says Thank You to youngsyr For This Useful Post:
Leigh_EvoIX (08-08-2012)
Old 08-01-2011, 16:48   #11
wip
Car: 88570008
Originally Posted by youngsyr View Post
Definitely should be stickied...
Agreed
...Having just had a close call myself
Found this thread linked from here.
wip is offline   Reply With Quote
Old 08-01-2011, 18:13   #12
Sider
Sider's Avatar
Good thread
Poor design fault
Sider is offline   Reply With Quote
Old 09-01-2011, 21:48   #13
evilpob
Car: Evo IX FQ360
Done mine... now we will see if the error comes back..
https://www.lancerregister.com/showth...=351877&page=4
STEVOLUTION any updates with all this rain we have had!
Old 09-01-2011, 22:43   #14
Stevolution
Car: Vii FQ300
Fingers crossed you'll be fine from now on mate.
Old 19-01-2011, 00:44   #15
Randolf
Randolf's Avatar
Car: Black 8 FQ 380
Thank god i found this thread as i was away to buy an ayc pump cause of the lights being on!!
but a few months back i had the front seats out of the car and passenger front carpet up and found some dampness but put it down to wet shoes on the carpet but now im thinking this could well be the culprit because i have the front arch liners and wings off and i think the bottom half of my black box is missing thus letting in the water!!!
So i now know what im checking for and will post up my findings tommorow night
Thanks for this info
Randolf is offline   Reply With Quote
The Following User Says Thank You to Randolf For This Useful Post:
dave69690139 (01-02-2016)
Similar Threads
Acd lights MR FQ300MR Technical Questions 12 02-01-2011 11:46
ABS / ACD - AYC lights code 11,13,14,82 rob2006 Gearbox / Clutch / Transmission 6 21-06-2009 19:45
ACD - all 3 lights on Bleesh Gearbox / Clutch / Transmission 0 19-06-2003 20:54
All 3 ACD lights On?!? Darkness Technical Questions 5 29-04-2003 19:26
Help! Acd showing 3 lights on my 7! chopper7 Technical Questions 2 13-01-2003 16:35
