Recommended Full Brake Setup For Evo 6 - Mitsubishi Lancer Register Forum
Go Back   Mitsubishi Lancer Register Forum > Technical > Brakes
Old 04-01-2021, 21:43   #1
Mr.H
User
Car: Evo 6
Hi all,
The time has come to change my pads and discs on my Evo 6. I don't think the discs have been changed since the production of the car.
The car has just hit 65k and is running 350bhp/350ft-lb and used for fast road and maybe around 3-4 track days this year (lockdown dependent).
I'm looking to use the below setup:
Discs: Rosssport Plain Discs, Grooved Discs
Pads: Project MU Type NS400, Pagid RS4.2, Ferodo DS2500/DS3000
Brake Lines: Hel Braided Brake Lines
Brake Fluid: Motul RBF600
Please let me know if this may be overkill for the power I'm running along with any recommendations.
Thanks,
H.
Mr.H is offline   Reply With Quote
Old 04-01-2021, 22:31   #2
LEGNUMVR4
I use plain discs with carbotech xp10s on my 4 and
couldn't fault them on track.
They can howl at times which might not be the best on the road
LEGNUMVR4 is offline   Reply With Quote
Old 04-01-2021, 23:29   #3
Goginawa
Zero Fighter
Goginawa's Avatar
Car: EVO IX FQ 320
Weíve run oem brembos and few cars but with aftermarket discs, pads, braided hoses and better fluid, it worked a treat. I personally donít rate Ferodo brake pads due to bad experience, havenít tried others but heard good feedback on project Mu. Iíve always used Carbotech ( XP8 and XP10 ) and have been more than happy with it. Power wise, it was on Evos ranging from 360bhp up to 500.
MAPPED BY ORACLE
evoless ,now something on a different Note
Goginawa is offline   Reply With Quote
Old 05-01-2021, 08:32   #4
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
I'm a big fan of the Carbotech range, but for your purposes I'd recommend Project Mu HC+800s.
Phil
Old 05-01-2021, 16:32   #5
mlau1294
mlau1294's Avatar
...or Performance Friction Z.11 pads; good stopping power, low dust and low noise.
Have them currently on my 6RS and work great on the road and on the occasional track session...
Dynotech
The Following User Says Thank You to mlau1294 For This Useful Post:
evo/nut (05-01-2021)
Old 06-01-2021, 06:04   #6
TimC
TimC's Avatar
Car: Evo IX GT
Consider spending a bit more on discs too. Whilst the RossSport plain/grooved discs are a great price, they become more consumable with higher coefficient pads and track days. Perhaps consider spending a bit more on something like DBA discs.
Tim
TimC is offline   Reply With Quote
Old 12-01-2021, 10:22   #7
Mr.H
User
Car: Evo 6
Thanks for the responses. I don't want pads which squeal tbh and it seems the ProjectMU's are mostly sold on Japan so not sure if they're worth shipping over with import tax etc. But will still take them into consideration.
Anymore recommendations from anyone?
Then I will have finally made a decision lol.
Thanks.
Old 12-01-2021, 10:26   #8
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
Thanks.
It shouldn't be an issue getting Project Mu from a UK stockist....
https://www.tegiwaimports.com/brands...mu/hc-800.html
Phil
Old 12-01-2021, 10:40   #9
Mr.H
User
Car: Evo 6
Just spoke to them and they cant seem to get hold of them.
Have you ever purchased from the below:
https://www.torqen.uk/mitsubishi/lan...s-ps4f506.html
I believe the brake pads for Evo 6 are the same for 8/9?
Old 12-01-2021, 11:36   #10
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
Not used or even heard of that company. I bought Project Mu for an MX5 a year or two back from these people.
https://www.hendyeshop.co.uk/project-mu-28-w.asp
Phil
Old 12-01-2021, 12:02   #11
Mr.H
User
Car: Evo 6
Spoke to Hendyeshop last week and they said they don't supply them pads anymore.
The Following User Says Thank You to Mr.H For This Useful Post:
notenoughtime (12-01-2021)
Old 12-01-2021, 20:29   #12
McGoo60
I use these, so far so good!
https://pbs-brakes.com/collections/m...ce-pads-8017pr
Old 30-01-2021, 21:46   #13
Evoboy
Evoboy's Avatar
Car: 1999 VI GSR ,Veilside 90mm Titanium exhaust & 380 bhp , 650 BHP motor build started !
Brake fluid is important too, you mentioned some track day use so I would advise using high temp brake fluid and change it at least once a year, even twice to be safe.
Also, braided brake lines, no need to go for hyped up brands as they all use the same hose, the only difference is appearance. Do go for stainless fittings though.
Use The Force ------ Drive An EVO !!!
Evoboy is offline   Reply With Quote
Old 31-01-2021, 07:05   #14
kikiturbo
Car: EVO 9 GSR
avoid ferodo ds2500
I prefer carbotech but they do squeal.. option is to switch pads for trackday...
as for fluid change.. you will need to bleed a bit before and after the trackday.. keep that in mind..
ACD/AYC pump repair video
Old 31-01-2021, 13:45   #15
Arronevo8
Ferodo I Dsduo pads and for fast road on Alcon front disc setup are very good and no fade so far. I run std rear calipers but hard PF and they work well. The DS 2500 are crap. The dust is easy to was off.
