Alcon ADex Rear brakes - Mitsubishi Lancer Register Forum
Go Back   Mitsubishi Lancer Register Forum > Technical > Brakes
Old 28-12-2020, 14:27   #1
JamesCarter
User
JamesCarter's Avatar
Anyone running Alcon rear brakes on their road Evos?
Just ordered a set and curious to see weather people noticed much of a difference
James
JamesCarter is offline   Reply With Quote
Old 28-12-2020, 14:57   #2
leeslancer8
leeslancer8's Avatar
Car: EVO 8 260 - EVO 7 RSII - EVO 8 FQ320 MR - EVO 4 GSR- EVO X JRM RS360
James
Got some cash you
Doubt they make tonnes of difference if honest I’d have said it’s like most things down to pad choice.
leeslancer8 is offline   Reply With Quote
Old 28-12-2020, 17:05   #3
JamesCarter
User
Originally Posted by leeslancer8 View Post
Got some cash you
Bread and water for me now
According to people who are in the know they've said
When using a 6 pot front caliper, Fitting decent 4 pot rear callipers will give a more progressive braking force at the rear, thus better utilising rear grip before lock-up
The standard rears have less overall power and will be easier to lock-up with 6 pot fronts due to the different master cylinder piston area to caliper piston area ratio.
The Following 2 Users Say Thank You to JamesCarter For This Useful Post:
plip1953 (29-12-2020), squeakyclean32 (30-12-2020)
Old 29-12-2020, 10:47   #4
Arronevo8
I run Alcon on the front and std rear but with aggressive pads on the rear and they work well.
Old 29-12-2020, 17:27   #5
dreMR
dreMR's Avatar
I didn’t notice much difference in overall stopping power after I fitted the Alcon rears. I did notice straight away that the rear of the car sits down now under braking instead of the nose diving down. On track the standard rear brembos went brown with heat but the rear Alcons don’t get hot in comparison they don’t even register on the Alcon temperature strips I’ve got fitted.
dreMR is offline   Reply With Quote
Old 30-12-2020, 10:28   #6
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
Thing you always need to be wary of, and ideally to avoid, (especially on non-abs equipped cars) is rear locking. This can generally be achieved by making sure you don't run an especially aggressive rear pad compound, but fitting a proportioning valve will very likely achieve the same purpose but without compromising on the initial phase of rear application - ie initial bite and pressure ramp up rate. Of course, on cars with abs, you can get away with a non-optimal arrangement, but it's not really the right way to do things.
Phil
Old 30-12-2020, 21:22   #7
-Snowball-
-HKS GTII Abuser-
-Snowball-'s Avatar
Car: Evolution IX GSR , Saab 9-3 2.8 V6 AERO TS , Audi A4 Turbo Quattro
James
I have front and rear set. Same pads on every corner.
Cant say is it worth at street but on track makes difference.
"Can I Feel your Boost , please ?....."
-Snowball- is offline   Reply With Quote
Old 30-12-2020, 21:52   #8
Phil2333
Tarmac Tyre Shredder
Phil2333's Avatar
Car: Evo 6, Forged 2ltr 8MR engine...405/400
Yep front and rear alcons on mine....on the road a bit pointless,but on the track...different league!
Pad choice is crucial. ..ds2500 feel utter shyte, like blocks of wood on the road after using something like carbotech xp10
My Evo 6 resto thread...
Phil2333 is offline   Reply With Quote
