Idle and EGR question - Mitsubishi Lancer Register Forum
Go Back   Mitsubishi Lancer Register Forum > General Stuff > Lancer Chat
Old 08-09-2020, 07:58   #1
Jez3062
Morning everyone!
Quick question that I hope doesn't come across as stupid. Do Evo 8s (UK models) have EGR? The reason I ask is on idle my car sounds like it has more aggressive cams fitted (sounds like cam lope) but to my knowledge still has stock cams (will check at the weekend). Idle is stable at 800rpm and isn't hunting but there is definite cam lope sound.
Any ideas? Was thinking its either EGR issue (if even fitted!) or it has aftermarket cams fitted.
Jez3062 is offline   Reply With Quote
Old 08-09-2020, 10:36   #2
kikiturbo
Car: EVO 9 GSR
Do you have OE intake?
ACD/AYC pump repair video
Old 08-09-2020, 10:39   #3
Jez3062
Its got a blitz power CAI. MAF is still connected.
Old 08-09-2020, 14:01   #4
grants
grants's Avatar
Jez
Which Evo 8 do you have?
An Evo 8 260 which is EU compliant and has EGR but no SAS
Or a JDM car which does not have EGR
Look under the bonnet at the exhaust manifold, if it has two metal pipes going towards the inlet manifold it's a JDM car
Old 08-09-2020, 15:33   #5
Jez3062
Its a 260 UK model. I was pretty sure I found the EGR valve last night. Couldn't find the EGR solenoid though.....think this is behind the Intake Mani on the firewall?
Could just be a loose Vac line that I haven't found but I believe deleting the EGR saves any hassle in the future. Cant find any UK stockist of EGR delete plates though.
