AIM MXL wiring for Evo VIII fuel gauge sender - Mitsubishi Lancer Register Forum
Old 18-05-2016, 18:28   #1
cra1g.b
User
cra1g.b's Avatar
Car: Norris Designs Evo VIII MR RS
Installing MXL dash into my Evo VIII, want to input fuel gauge sender to an analogue channel, but need to convert resistance to voltage as far as i'm aware, has anyone previously done this, and if so what resistors and dash settings did they use?
Have read that a pull up resistor is required in the circuit?
Also does anyone have a pinout for the original Evo VIII instrument cluster connectors?
Any useful advice would be appreciated
cra1g.b is offline   Reply With Quote
Old 18-05-2016, 20:23   #2
Sir Marcus
Sir Marcus's Avatar
Car: Evo 6 RS Sprint, JAM 2.3, AMS GT850R
Yep, will dig out the info for wiring when back at home & post it up for ya
Sir Marcus is offline   Reply With Quote
The Following User Says Thank You to Sir Marcus For This Useful Post:
cra1g.b (18-05-2016)
Old 19-05-2016, 20:27   #3
Sir Marcus
Sir Marcus's Avatar
Here ya go, any questions mate, just post on this thread
The wiring is for an Evo 6 dash...
For an Evo 8, the fuel level wire is Green on C108(dash connector behind speedo) pin51 (the end pin)
The Following 3 Users Say Thank You to Sir Marcus For This Useful Post:
carpe (22-08-2020), cra1g.b (23-05-2016), river evo 6 (19-05-2016)
Old 22-08-2020, 03:20   #4
carpe
carpe's Avatar
Hi sorry to dig up an old thread, what did you do for the Speedo wiring?
carpe is offline   Reply With Quote
Old 22-08-2020, 12:55   #5
Sir Marcus
Sir Marcus's Avatar
No wiring required for the speedo as it takes the speed from the ECU over the serial cable RS232
Old 22-08-2020, 13:23   #6
carpe
carpe's Avatar
Thank you for the reply.
After fitting the Link MXS Iíve lost the speed signal to the engine ECU, looks like terminal 51 of the combination meter needs a 12v supply.
Just wondered if you had the same issue?
