Evo VII-IX Caution - Electrics! - Page 5 - Mitsubishi Lancer Register Forum
Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 21-01-2011, 12:08   #61
Rampant
Profound thinker
Rampant's Avatar
Originally Posted by NR Autosport View Post
No you won't have any further issues as the affected connector block was also re secured above the original connector blocks...
Cheerz Nick
Trying to find the time to give you a call...
Je cherche l'orgasme d'auto
J'ai trouve l'orgasme d'auto
Old 21-01-2011, 13:00   #62
AP
I will be checking this problem on every 7,8,9 that comes in for service in the future! Great thread and a great heads up for all 7,8,9 owners
AP is offline   Reply With Quote
Old 21-01-2011, 17:09   #63
MR FQ300MR
Car: Gunmetal grey viii FQ300MR !
I posted this same problem up a while ago now , and have had the one block cut out . All the cables were then soldered together , and I an happy to say , no more problems !!!
MR FQ300MR is offline   Reply With Quote
Old 19-03-2011, 03:30   #64
gl1
Car: Evo VIII MR FQ-340
I was trying to fit a sub & making a mess taking plastics off & carpets up while trying to find the gromet through the firewall. Then i noticed my passenger foorwell is soaking wet. I will have to check these plugs tomorrow too now, no electrical faults yet, just happened across this & this thread is very useful as no doubt if this isnt fixed i would of had.
gl1 is offline   Reply With Quote
Old 19-03-2011, 12:24   #65
abc123
dont use wd40...if your connector block is clean and dry, do the wiring loom under the wheel arch as described but use electrical connector silicon on the block this will seal the block and keep out any moisture.
EVO 8MR BREAKING SEE HERE>
abc123 is offline   Reply With Quote
Old 25-03-2011, 09:53   #66
Zonta
Car: Black VII GSR (show&shine winner)...bumble bee VII run about...white evo v... magic fiat coupe..
Interesting read, will be checking mine out today sometime
Zonta is offline   Reply With Quote
Old 06-04-2011, 18:44   #67
Leigh_EvoIX
Oh dear. Just discovered this today.
Anyone know what the missing wires were??
Leigh_EvoIX is offline   Reply With Quote
Old 06-04-2011, 20:23   #68
c_maguire
The wires are related to windscreen wiper/washer functionality, but from your picture those wires look like they have been soldered or crimped up now to resolve the problem anyway.
c_maguire is offline   Reply With Quote
Old 07-04-2011, 00:14   #69
Leigh_EvoIX
Thanks for your reply. I did a little more investigating and it looks lime they have been soldered onto extended new wire and the joins have been shrink wrapped. Looms like a good job by whoever did it. There is no moisture anywhere so Im hoping that it's going to be no further worry. Will keep an eye on it.
Some more pics of the repair....
Old 07-04-2011, 09:44   #70
Stevolution
Car: Vii FQ300
Water got in there once, It will get in there again!
Only way to stop is to seal the loom in the wheel arch
Stevolution is offline   Reply With Quote
Old 21-07-2011, 06:19   #71
evo9mart
Excellent thread very helpful. As soon as i pick mine up this wil be my first check.
Are there any other main problems like this worth checking just so i know?
evo9mart is offline   Reply With Quote
Old 21-07-2011, 10:55   #72
EddieIrvine
This happened to me a year or so ago during the first bad winter with heavy snow. My wipers started coming on by themselves then the intercooler spray was going by itself.
Took it to The Garage Motherwell and Marc traced it to the multiplug and main pwoer wire through the passengers footwell. When he called martin at AA Autiobreakers for a loom he instantly asked if it was for the passengers loom. Marc did a great job diagnosing then individually soldering all the connection and sealing up the hole where the wire passes through the arch/bulkhead.
I have pics of the damaged plug i'll try and upload. I would urge everyone to check theirs as it is a potential fire risk. Would be worth making this a sticky thread.
As said above mine happened during the heavy snow where the snow must have been kicking up into the arches.
Rule the Bends
Bend the rules
EddieIrvine is offline   Reply With Quote
Old 12-09-2011, 16:33   #73
Mntl
Hi!
I've got some issues with my 7, windshield wipers wont work at all... well they might work fine but then suddenly they dont and there is nothing happening, no washer, no wipers in any position. any help? fuses are all ok.
Mntl is offline   Reply With Quote
Old 12-09-2011, 17:26   #74
GAZ5EVO
Car: None at mo
id say its the plug in the passenger kick panel, water damaged
Indigo-GT 01495 719720
I am who I am
GAZ5EVO is offline   Reply With Quote
Old 12-09-2011, 17:48   #75
Mntl
Will check that tomorrow!
Similar Threads
Model Differences / Specifications youngsyr Lancer Chat 238 09-10-2019 21:15
Ross Sport - Used Parts Bargain Bonanza (updated regularly) Ross W Private Sales - Parts 146 11-01-2012 10:02
Brake and Clutch Lines By HEL Performance BHP MLR Group Buys 455 06-11-2011 05:47
Evo 5/6 Breaking parts full parts list itemsfrom £6 Xenonshop Private Sales - Parts 120 03-06-2011 11:06
US= Sport Compact Car - First Drive: Evo 9 Jakeg97 Lancer Chat 5 24-03-2005 08:29
