Evo VII-IX Caution - Electrics! - Page 3 - Mitsubishi Lancer Register Forum
Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 09-01-2011, 19:18   #31
JCE EVO
JCE EVO's Avatar
Car: black evo 6 & silver evo 9 mr 360
have a look here lads it might be of some help .
https://www.lancerregister.com/showthread.php?t=176467
JCE EVO is offline   Reply With Quote
Old 10-01-2011, 16:45   #32
ANT-EVO
Car: evo 7
I removed both my kick panels yesterday to check for the damp plugs fearing the worst, but all is dry and sound, so wd 40 them, i think the main cause for any damp around this area would be down to people feeding cables through the bulhead and disturbing the bulhead grommets, or poss windscreen, Ant!
ANT-EVO is offline   Reply With Quote
Old 14-01-2011, 10:15   #33
AP
Newbee here , just want to thank you guys for saving my car! Long story but I have an 8 fq300 , last night heard a noise coming from the car went to check and the intercooler spray pump was running , checked switch everything ok, started car still everything fine but pump still running , then remembered this thread and went to check the connectors on the kick panel as I pulled panel off smoke started coming out, thankfully panel just pulls off and low and behold there was a short on the connector dissconnected them just in time. Seems to be exactly what has previously been discribed water on the connector that caused a short. I would strongly recomend people get this checked. Once again thanks to the great info on this site one evo saved!!!!!!!!!
AP is offline   Reply With Quote
Old 14-01-2011, 10:45   #34
Steve220
Steve220's Avatar
Car: Audi A4 Quattro
Send a message via Skype™ to Steve220
Lucky find!! Glad all is ok though and you can get it sorted now
Evo-less
Steve220 is offline   Reply With Quote
Old 14-01-2011, 14:34   #35
Wolves FC
Car: Mitsubishi Evo IX FQ 360, 57 Reg-NOW SOLD! Looking for a Blue X FQ360 If anyone has one for sale???
Agreed mate,this is a great thread & very,very helpful.
Wolves FC is offline   Reply With Quote
Old 15-01-2011, 17:08   #36
wip
Car: 88570008
Well, finally got time to sort mine today...
One and a half mile into the journey to my mates garage, my car cut out. Luckily I was only doing 30 at light throttle.
Pulled over and immediately had to disconnect the battery as the intercooler spray was stuck on.
Checked the connector, and guess what....
One wire fell off when I unplugged it.
Bridged it with some spare wire, and hey presto, my fuel pump worked.
Tried to dry everything out so I could drive the remaining two miles. Get halfway there and I had 'the three lights'.
Spent most of the day cleaning, sealing and soldering. Took it out for a drive, and now all is fine
I'd urge EVERYONE to check their connector as if I'd been giving it a bit of throttle when that happened, I may still have been crying now...
wip is offline   Reply With Quote
Old 15-01-2011, 17:39   #37
mattler
Car: Evo 7 XT330 again!!
Originally Posted by Rampant View Post
Quite a few VII-IX afflicted by this then - hence the reason I said it might be a good idea to check!
Cheerz
Mark H
Excellent thread this and thanks for taking the time highlight it!
I will check mine tomorrow but isn`t it time we had a sticky with links to threads such as this named "common problems and safety checks"
This is not the only issue that could be easily avoided if the knowledge was put in one place for people to check!!
Just a thought
CHANCE FAVOURS THE PREPARED MIND
mattler is offline   Reply With Quote
Old 15-01-2011, 17:44   #38
mattler
Originally Posted by Stevolution View Post
These are the ones.
Mostly its this plug that causes the issue as this is the one that goes out into the wheel arch.
I traced the water source to inside of the wheel arch. Here's a thread i did on it https://www.lancerregister.com/showth...ght=acd+lights
So just to be clear on this, the first port of call is the passenger footwell inside just ahead of the door hinge?
Old 15-01-2011, 19:24   #39
Wolves FC
Just a thought
I'll second that. Most of us would only come by a thread like this & the similar ACD 3 LIGHTS thread by accident as not everyone has the time to sit down at their PC & read everything on here back to front on a daily basis.
This set of plugs in the footwell/under wheel arch seems to be the source of a A LOT of problems which can very easily be reckified. Imagine the bill it would cost to go to a garage & have everything checked out,they'd be changing pumps & alsorts before they found the problem-if at all.The labour bill would be hundreds of pounds.
Someone from MLR staff should make Stevolutions thread a sticky.
Old 16-01-2011, 16:04   #40
Stevolution
Car: Vii FQ300
Yes mate, the plugs down there are the main offenders.
The source of water is under the inner arch where the loom is NOT sealed properly due to a Mitsubishi design fault.
May i just point out that cleaning and drying the plugs will NOT repair the corrosion issues forever, The only way to truly fix the problem is to seal the loom.
Stevolution is offline   Reply With Quote
Old 16-01-2011, 20:43   #41
Rab & Helena
Car: Evo 7 RalliArt ECU, 8mr Turbo, Hks super dragger, Hks induction kit,Mishimoto alloy rad,
Just checked mine & i have the corrosion. My top left plug (that's in the block of 4 that is pictured in this thread) has one of the pins snapped off. It is the 4th pin up (there is 1 thick pin the 3 thin pins, it's the 3rd thin pin) on the right hand side.
Does anyone know what this pin does?
See This Evo Fear This Evo
Rab & Helena is offline   Reply With Quote
Old 16-01-2011, 20:45   #42
mattler
Christ!! I didn`t get chance to check today!
Too busy filing my pads down to fit the new godspeed to part disks!!!!
Very nice by the way LOL
Old 17-01-2011, 14:19   #43
c_maguire
I presume you are looking at the connector from the wire side. If so the thick wire is pale green, next wire blue/gray, next wire brown, and the wire broken is blue/yellow (C135, pin 22). If so it is one of three wires going to the clock.
c_maguire is offline   Reply With Quote
Old 17-01-2011, 21:34   #44
Rab & Helena
Here's a pic of the plug, the wire looks solid white to me. Any idea what this one is?
Arrow pointing to brocken pin.
Old 17-01-2011, 21:41   #45
neverneverman
Life after Evo= Elise
neverneverman's Avatar
Car: The money pit has gone ! Lotus Elise now
Thats not looking good
neverneverman is offline   Reply With Quote
Similar Threads
Model Differences / Specifications youngsyr Lancer Chat 238 09-10-2019 21:15
Ross Sport - Used Parts Bargain Bonanza (updated regularly) Ross W Private Sales - Parts 146 11-01-2012 10:02
Brake and Clutch Lines By HEL Performance BHP MLR Group Buys 455 06-11-2011 05:47
Evo 5/6 Breaking parts full parts list itemsfrom £6 Xenonshop Private Sales - Parts 120 03-06-2011 11:06
US= Sport Compact Car - First Drive: Evo 9 Jakeg97 Lancer Chat 5 24-03-2005 08:29
