ACD lights - Corroded plugs in footwell - Page 4 - Mitsubishi Lancer Register Forum
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 12-03-2016, 10:37   #46
rutthenut
rutthenut's Avatar
Car: Boggo 260. Stratos Replica. V8 Grand Cherokee and now an Opel Manta V8 rally car
Originally Posted by tobys View Post
Could someone post (or PM me) where to buy the replacement plugs from please?
A pin in my 20pin one disintegrated when i took it apart, due to corrosion!
Thank a lot! Toby
Got some corrosion in mine too, so would like to replace with the correct plug rather than wire around it if possible. Any sources for that plug?
And how are you supposed to open it up to get the pins out of it?
Will of course need to sort out the damp tracking through the loom, as per Stevolution thread.
rutthenut is offline   Reply With Quote
Old 20-07-2017, 07:32   #47
Mattyra
Thanks for putting this up :-)
Had a problem with my Fuel pump it completely failed,
Cut a long story short the cable was corroded in the passenger footwell after a few days of fault finding (Richard from RGS said check the cable) he was spot on...
cut the cables that were corroded, and to my surprise some of the cables pulled straight out the block and were corroded so bad that the pin had gone....
I will be cutting all the cables there now and soldering up...
Defiantly worth checking ever so often, i should note check the back of the block not the front as that as where the water gets to....
Mattyra is offline   Reply With Quote
Old 20-07-2017, 08:54   #48
strange_days_uk
Simon - EVO V
strange_days_uk's Avatar
Car: EVO V
great thread
Most TME owners have never driven an evo, including their own.
strange_days_uk is offline   Reply With Quote
Similar Threads
Acd lights MR FQ300MR Technical Questions 12 02-01-2011 10:46
ABS / ACD - AYC lights code 11,13,14,82 rob2006 Gearbox / Clutch / Transmission 6 21-06-2009 18:45
ACD - all 3 lights on Bleesh Gearbox / Clutch / Transmission 0 19-06-2003 19:54
All 3 ACD lights On?!? Darkness Technical Questions 5 29-04-2003 18:26
Help! Acd showing 3 lights on my 7! chopper7 Technical Questions 2 13-01-2003 15:35
