4WD Request Service on EVO X SST? - Mitsubishi Lancer Register Forum
Old 07-12-2011, 17:43   #1
cooin
got car few days, then 4wd warning light on, said request service, then send to main dealer, they said both rear tyres to low cause AYC go wrong, then replace both rear tyers, but after that warning light come back again......anyone can help? thanks.
btw, my car is evo x sst, warning light come on every time after drive 3-4 miles...thx
cooin is offline   Reply With Quote
Old 07-12-2011, 18:58   #2
KenX
Car: Iveco Daily
Is it when you rag it? Could be over boosting if so.....
Why have 3 pedals when you've only got 2 feet............
KenX is offline   Reply With Quote
Old 07-12-2011, 19:14   #3
cooin
...totally stock car...could over boost? thx~~~
Old 07-12-2011, 20:41   #4
MotoIntrest
Car: Evo 4
did they not tell you the fault code that came out?
where about in the country are you? i would advise booking it into a dealer that knows about evos or one of the traders on here that knows evo X's.
Indigo GT boys are true gents
MotoIntrest is offline   Reply With Quote
Old 07-12-2011, 20:42   #5
MotoIntrest
Car: Evo 4
Oh, and have you let them know the fault is not fixed?
Old 07-12-2011, 20:50   #6
KenX
Car: Iveco Daily
Mine was totally stock when I bought it and was over boosting so bad the gearbox went into limp mode and opened the clutches
couldn't fix it, I was about to give the car back for refund and noticed a boost hose was split..........
Old 07-12-2011, 20:52   #7
cooin
thanks m8, im in essex, i ring them today, they said there is no faulty code on ecu, they will check the wirring on tomorrow, but they said may need replace the control unit on AYC? honstly , i really don't know what is the control unit...never heared before...is there any good dealer around colchester known about the EVO X....thanks for help~
Old 08-12-2011, 19:44   #8
cooin
update, main dealer call me said the AYC fuel pump gone.......2267.87 include vat plus labour to fix......
Old 08-12-2011, 20:01   #9
michty_me
michty_me's Avatar
Car: Forged Evo X CT-500
A few threads up over the past few months with regards to AYC pump failure on Evo X's.
Your best bet would be to remove the pump and get it to a specialist such as Harry Hockley, Rogerrally, FQ Performance (All on here I believe)
michty_me is offline   Reply With Quote
Old 08-12-2011, 20:18   #10
Sider
Sider's Avatar
As Mitchy me says, you may well be able to get it repaired a lot cheaper if the car is out of warranty
Sider is offline   Reply With Quote
Old 08-12-2011, 22:04   #11
cooin
thanks for the help~~~main dealer said may ask mitsubishi office to check, maybe could do it under the warranty, but actually my warranty is end of Oct...so fingercross~~~
Old 09-12-2011, 03:01   #12
michty_me
michty_me's Avatar
Here's hoping that they won't be a bunch of helmets and allow you to get it sorted under warranty as a good will gesture.
Old 09-12-2011, 09:54   #13
tflpunk
That sounds familiar! (my thread above "5k"). I'll check the hose for splits after work.
tflpunk is offline   Reply With Quote
Old 09-12-2011, 10:00   #14
Paul Ventress
Car: evo x sst. 440bhp and 423lbft
my nearest dealer quoted me £2,870 to supply and fit new ayc pump. then after several hours got a call from them that he could now do it for£1,350.
Paul Ventress is offline   Reply With Quote
Old 09-12-2011, 11:47   #15
Sider
Sider's Avatar
Was that as a good will gesture/contribution from Paul?
