New Evo IX Owner - Compression Test Results Not Good!!! - Page 4 - Mitsubishi Lancer Register Forum
Go Back   Mitsubishi Lancer Register Forum > General Stuff > Newbie
Old 18-11-2019, 16:05   #46
famz
I am not really shocked nor surprised at that 'comprehensive report'. Is now even a report on huge BHP and money instead.
The cost of purchasing an IX MR at that low mileage aint worth it if you are to overhaul the engine already. Unless you intended to do so from the onset regardless of current state. Refund is what I would be promptly demanding. No ifs no buts. Alternatively seller offsets costs to overhaul that engine to an acceptable state.
Was in this position at the end of last year and I even took pictures for reference.
Your compression figures are similar to my own wet test results and mine were after more than a decade of use.
I wouldn't trust them bore scope images as they tend to exaggerate the depth and size of small things (debris looked huge in them).
If those compression figures are wet test, then the dry ones are horrible. Mine were 90+2 across the four cylinders.
The car drove alright usually but lacked power. The BOV, that usual emphatic oomph was gone.
Oil consumption was 0.5 litre across a service cycle and the vibrations on high load were what made me overhaul it.
Well that and a grandpa in a skoda passing me and angrily gesturing at me to move over :-O
I got quoted for those silly amounts by almost all garages and they even lost interest when I said I am looking to return the engine to OEM spec.
Those amounts quoted, I considered these as cheaper and better options for me:-
- Import 2 clean engines from Japan
- Rebuild my current engine myself x4 attempts with the added bonus of owning engine building tools and valuable experience at the end
- Import another MR and get rid of the current one
- Start with option 2 and then if at least attempt 2 is successful then switch to a new block on attempt 3, new crankshaft, new pistons
Option 2 and 4 and I don't regret my choice so far.
In the end the engine was to my pleasant surprise still within spec and only these really needed to be addressed:-
- Carbon deposits on valves and seats (they were non existent)
- Worn out piston rings
- Slight glazing at the bottom(piston slap area)
famz is offline   Reply With Quote
Old 19-11-2019, 10:50   #47
Dave-Cee
Climate Changer
Dave-Cee's Avatar
Car: MAD forged 2.2 IX FQ 340 PLG Leccy Bloo
If you really love the car this is what you should do.
Purchase a decent usable ix motor a short engine will do to get you back on the road and run it as stock.
Put the other engine aside for now.
Enjoy your car, get some use out of it and then if you decide to go for the forged route etc, you have your original engine to build at leisure.
It's a win win situation.
Dave-Cee is offline   Reply With Quote
The Following User Says Thank You to Dave-Cee For This Useful Post:
Mita (19-11-2019)
Old 22-11-2019, 22:41   #48
Corsica13
Junior User
Car: Evo IX MR FQ-360
Thanks for all your replies, I appreciate all the feedback given.
In regards to purchasing another stock engine, I don't really have the knowledge to do the work myself or more importantly, the time, so most of those options aren't really feasible for me.
I went for a second opinion and had another leak down carried out, the result was very similar give or take.
Therefore the next stage is to strip the engine and as of now I'm working with the seller to have this work carried out, either the engine will be rebuilt and brought back to healthy "Stock" form or potentially forge the engine and upgrade some of the components.
I'll keep you guys posted on the outcome and developments.
Thanks again!
Corsica13 is offline   Reply With Quote
Old 23-11-2019, 07:11   #49
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
Was any attempt made during this second test to pinpoint whats'really causing the leakage ie valves, rings etc
But in general I think the course of action you are now following is the right one, and I very much hope you get a good outcome :-)
Phil
Old 23-11-2019, 08:33   #50
RaeTurbo
RaeTurbo's Avatar
Car: Evo2 mapped antilagged and LC by Mr Fox.
Indeed, makes me wonder why they’re not trying to find the answer, surely the more you know the better and if it is just a couple of valves need lapping in the engine can stay in the car.
Evo2, 12.1 113 mph. First try.
RaeTurbo is offline   Reply With Quote
The Following 2 Users Say Thank You to RaeTurbo For This Useful Post:
Mita (23-11-2019), plip1953 (23-11-2019)
Old 02-02-2020, 21:48   #51
flatlemon
User
Any update on this? I need to get my engine stripped too as compression is down.
Also, really sorry to hear of the issue you're having. Hopefully light at the end of the tunnel soon.
Sent from my Pixel XL using Tapatalk
flatlemon is offline   Reply With Quote
Old 02-02-2020, 21:49   #52
flatlemon
User
Did you do the engine overhaul yourself? Sounds like you got a good result in the end.
Old 14-02-2020, 17:40   #53
famz
Yes, I totally overhauled the engine myself. The engine is still running nicely several thousands of miles later. I am extremely happy with the results and the lessons learned.
