Sd wiring direct to ecu, evo 6.5 - Mitsubishi Lancer Register Forum
Old 29-04-2019, 10:12   #1
MHR Evolution
Car: Evo 6.5 TME Edition
Hi all, ive been looking into the sd wiring and cant seem to find a solid answer. Now wiring is really not my strong point so id liks to get this bang on correct before i start messing with the wires.
Yes i am aware you can buy a plug in adapter, but my sensors are in different places so it will not work on my setup
So 5 wires
Inlet air temp grey, air temp ecu pin 72
Inlet air temp black, earth pin 92 or chassis
Map sensor A ground, earth pin 92 or chassis
Map sensor B, barometric pin 85
Map sensor C, +5 volts power pin 81
Does this look correct?
Map and air temp sensors are gm parts
Sent from my D6503 using Tapatalk
MHR Evolution is offline   Reply With Quote
Old 24-06-2019, 20:09   #2
MHR Evolution
Anyone confirm? Its all secretive
Old 22-12-2019, 19:03   #3
MHR Evolution
Still need to know
Old 22-12-2019, 22:49   #4
ragz
Just buy the sd conversion loom from spoolin up
Job done
ragz is offline   Reply With Quote
Old 22-12-2019, 22:55   #5
MHR Evolution
As ive said my sensors are in different location so the loom will not work.
Old 22-12-2019, 23:05   #6
madspeed
madspeed is offline   Reply With Quote
Old 23-12-2019, 09:33   #7
madmatt
madmatt's Avatar
You don't want to use the MAF connector to connect your sensors?
Old 23-12-2019, 09:34   #8
MHR Evolution
No
I have hardwired to the ecu
Old 23-12-2019, 11:57   #9
ragz
There looms available with extra length on em but if you must hard wire then oh well
Wouldv saved alot of time and effort
Old 23-12-2019, 17:09   #10
nplatenkamp
SD Wiring
Hi, for Evo 5/6:
Map sensor B, barometric pin 75
Rico
nplatenkamp is offline   Reply With Quote
The Following 2 Users Say Thank You to nplatenkamp For This Useful Post:
Apajee Vilesh (21-05-2020), MHR Evolution (27-12-2019)
Old 27-12-2019, 14:09   #11
MHR Evolution
Thanks for those who sent me a link to a thread with the sd map. Which contains the sd wiring
Got there in the end.
Similar Threads
Lancer/Evo 8 ECU upgrade for 5G Mirages and Evo 4-6's AlchEm1st ECU / Mapping 3 20-12-2016 05:42
Sti or evo 6 Bakerboy Lancer Chat 42 12-08-2011 19:11
Evo 5/6 Breaking parts full parts list itemsfrom £6 Xenonshop Private Sales - Parts 120 03-06-2011 11:06
