Smoky Lancer 2.0 DiD - help and advice please? - Mitsubishi Lancer Register Forum
Old 16-08-2019, 12:07   #1
SuperJon
Hi there,
I've had this issue for a while now so hope that someone can shed some light on what I might do to fix the issue...here goes.
I own a 2010 Lancer Juro 2.0D - it's done 76k, has been serviced at all intervals. I purchased it about 2 years ago and it has ran beautifully for the initial year and a bit but, towards the end of last summer, I noticed that it ran fine but then started to stutter and emitted loads of smoke - and I mean clouds - from the exhaust. I had a check of all of the air intake pipes and decided after doing a few checks and research that I should also replace the MAF sensor which I did. It ran well for a while but, whilst on holiday in April, the symptoms started again so I took the connector off the MAF sensor and it has been running OK(apart from the expected engine light from not having the MAF sensor connected) - a bit sluggish than normal but certainly better than when it stutters and smokes like a Victorian Steam Train!
Over the summer I've re-checked the intake pipes and actually the whole air system for split pipes and even swapped out the MAF sensor for the old one I kept but to no avail.
I guess I could be really unlucky and have two faulty MAF sensors but my instinct tells me it is more than this and I just wanted to check if anyone out there has had similar issues like this and what they have done to fix it?
Thanks for your help.
SuperJon is offline   Reply With Quote
Old 16-08-2019, 12:50   #2
LEGNUMVR4
Why did you swap back to a maf you knew was faulty?
Get a known good unit and see how it runs then
LEGNUMVR4 is offline   Reply With Quote
Old 16-08-2019, 13:11   #3
SuperJon
Sorry - I didn't know for sure that the original MAF was faulty but swapping it out for a new one was one of the potential solutions that this forum suggested.
I have to presume that the new one is a good working unit and only changed it back to check that the outcome was the same - it was!
Old 16-08-2019, 14:33   #4
r3k1355
You need to read fault codes, on a diesel engine it could be a number of different things.
Don't just go swapping stuff out blindly.
Old 16-08-2019, 15:49   #5
SuperJon
Sorry, should have said, when it stutters and blows out smoke - it doesn't trigger a fault code. It only does this when I remove the MAF sensor plug.
With the greatest of respect - I was swapping things out blindly, I was trying to identify the problem.
Wow - they are a bit edgy on here - just looking for some friendly advice!
Old 16-08-2019, 16:11   #6
grants
grants's Avatar
Friendly advice was to read the fault codes with a code reader. It plugs into OBDII port
Or take it to a dealer
Old 16-08-2019, 16:21   #7
SuperJon
I've got an OBD reader but there wasn't any codes! That's my point really.
Seriously - if there are any helpful people out there who might know the cause of this then please reply but otherwise....
Old 17-08-2019, 15:31   #8
LEGNUMVR4
Have you tried the vw forums ?
If you have no code and the maf is causing differences then you should.....
If that doesn't work people seem to have problems with your vw engine to do with egr coolers/turbos .
Where did you get the new maf from?
Old 19-08-2019, 11:02   #9
r3k1355
Otherwise what exactly??
You're the one needing help here, no-one is under any kind of obligation to provide assistance so maybe wind back the attitude or you'll just get told to **** off.
A cheap ten quid ebay reader or a proper unit?? Cheap units can't read all codes, there could be several on there it just doesn't understand.
Can it read live data?
Can it see what each sensor is doing when the car starts to splutter?
Can it see what each sensor is displaying at idle, part load and engine off?
Old 19-08-2019, 11:14   #10
grants
grants's Avatar
May I add;
Reader needs to CAN compatible
