Ticking...... - Mitsubishi Lancer Register Forum
Old 18-08-2017, 07:11   #1
Kwakerswull
Kwakerswull's Avatar
Ticking......
I'm fairly certain my 8 has started to sound a bit "tappety" which I noticed the other day. At first I thought or should I say "hoping" it was something completely innocent that was loose and making the noise but I'm not so sure.
I thought I had solid lifters fitted but I'll need to check over the spec list to see, it may have been just a TI valve kit that was used.
Question is, what do you recommend to use? I see ND do lifters with 3mm oil holes that solve the ticking noise and then there's solid lifters at a much greater cost. The spec of the car is rod job with gsc stage 2 cams running roughly 550.
Also, is this an easy job to tackle or best left to the garage?
556bhp Norris design tuned Evo 8 (L2esk's old motor)
Kwakerswull is offline   Reply With Quote
Old 18-08-2017, 08:59   #2
Kwakerswull
First part is from a cold start, second part is after 10 short blips to 3k and the last part was after driving it 1 mile to work, oil temp was up @ 35 degrees, never took a note of the oil pressure and the water temp was rising up to its normal place.
I'm needing to go to Stirling later so I'm going to check it again when it's at normal running temp. Ironically enough I noticed the ticking the other day when I had drove to work so at that point in temp etc it obviously sounds bad, I wonder if it will get better.
Updated vid with engine up to full working temp, it definitely quietens down. Anything to worry about? Or should I change them sooner rather than later?
https://m.youtube.com/watch?v=fwfhjhbloyI
Old 22-08-2017, 02:00   #3
MR Bishi
Car: Evo VIII MR FQ 320
Ticking noises often have us thinking the worst.
Being honest its difficult to tell much from the video, However, in the section of the video when the car is up to temp its sounds more like an air leak. Have you looked and listened closely around both the inlet and exhaust manifold for anything?
MR Bishi is offline   Reply With Quote
The Following User Says Thank You to MR Bishi For This Useful Post:
Kwakerswull (22-08-2017)
Old 22-08-2017, 08:30   #4
zefal
zefal's Avatar
Car: EVO IX FQ340
Have you checked this part? Just to rule it out? https://www.lancerregister.com/showthread.php?t=538723
EVO 9 FQ-340
zefal is offline   Reply With Quote
The Following 2 Users Say Thank You to zefal For This Useful Post:
Kwakerswull (22-08-2017), MR Bishi (23-08-2017)
Old 22-08-2017, 18:33   #5
MHR Evolution
Car: Evo 6.5 TME Edition
3mm lifters don't cure lifter tick btw, I had the lifter tick with 3mm. Good clean with diesel sorts them, there's a how to on here somewhere.
MHR Evolution is offline   Reply With Quote
The Following 2 Users Say Thank You to MHR Evolution For This Useful Post:
foreskin fred (23-08-2017), Kwakerswull (22-08-2017)
Old 22-08-2017, 20:38   #6
Kwakerswull
That never crossed my mind, car runs spot on, boosts well. When you're standing there listening it does seem as if it's coming from the head.
Not checked anything, will do though. I'm a baw hair away from ordering the 3mm lifters and a tool for removing them. I've watched a few videos YouTube showing the process of cleaning the existing lifters but it's a lengthy process. I'd rather purchase the 3mm lifters, fit them then maybe see if I can salvage the oe lifters.
Old 22-08-2017, 20:43   #7
Ben_r1
Ben_r1's Avatar
Car: Audi RS6
Not a Mitsubishi socket under your rocker cover is it lol?
Ben_r1 is offline   Reply With Quote
The Following User Says Thank You to Ben_r1 For This Useful Post:
Old 22-08-2017, 21:01   #8
Kwakerswull
Haha I seen that post the day after I heard mine
Old 22-08-2017, 21:54   #9
kevy
kevy's Avatar
Car: evo 4 Rs
My special tool is a screw driver & hammer & a rag..........
Turn engine so the cam has no lift..........
Stick driver in & twist off the rocker & a rag to catch it.........
Pull out lifter............
"hammer to knock them in"
Easy wee job
kevy is offline   Reply With Quote
Old 22-08-2017, 22:12   #10
Kwakerswull
Easy wee job
I watched a video on YouTube where the fella done it that way, seems a bit dodgy if you ask me
Old 22-08-2017, 23:39   #11
kevy
kevy's Avatar
Car: evo 4 Rs
They don't call me dodgy for nowt haha
I will be doing a set next week I might do a wee vid
The Following User Says Thank You to kevy For This Useful Post:
Kwakerswull (23-08-2017)
Old 23-08-2017, 01:38   #12
MR Bishi
Aye mate, that's what I'm getting at. It will sound like the noise is coming from the head. A decent garage/workshop should have listening equipment which can help pin-point the noise. This could possibly help if you have somewhere local.
A small leak somewhere wouldn't cause loss of boost, in the same way as an intercooler pipe blowing off for example.
Think I'd definitely check that blanking plate in the link zefal posted. Good info there, think I'll even check mine considering the way that plate has deteriorated.
Good luck with it
Old 23-08-2017, 06:05   #13
Kwakerswull
One thing that's doing my head in though, when you've done sets before have you bled the lifters so you can still depress them when fitted or do you have them solid - you can't depress them by hand.
I've seen conflicting information both on forums and YouTube videos.
Old 23-08-2017, 07:59   #14
kevy
kevy's Avatar
Car: evo 4 Rs
When ive done them you can depress them or you cant get the rocker back in
Old 23-08-2017, 08:19   #15
Kwakerswull
And on first start up are they pretty loud until it settles down?
Apparently the proper method instructed by Mitsubishi states that they've to be solid but most folk say that's daft......
The Following User Says Thank You to Kwakerswull For This Useful Post:
Ads9 (23-08-2017)
