Evo VI Tommi Makinen Edition (TME) GSR, Scotia White - Mitsubishi Lancer Register Forum
Old 25-08-2013, 11:48   #1
White Lightning
White Lightning's Avatar
Car: Evo 6.5 TME
*** CAR IS NOW SOLD ***
YEAR: 2000 (W reg)
COLOUR: Scotia White
MILEAGE: 67,735 miles (ODO reads 100,853)
TAX: March 2014 (7 months)
M.O.T.: June 2014 (9 months)
PRICE: SOLD
I am offering up for sale my much loved Evo VI, Tommi Makinen Edition. After over 3 years ownership, a change in personal circumstances means it is time for me to move on. This is my first Evo, but I can honestly say it is the best car that I have ever owned.
The car is of GSR specification, which means it comes with the usual GSR refinements such as AYC and climate control. Being a GSR it had the Tommi Makinen stamped Recaro seats, Brembo brakes and Enkei alloys fitted at time of manufacture. The colour is Scotia White.
This TME was first registered (in Japan) in March 2000 and was imported into the UK in June 2009 by Quality Cars Direct in Swansea. It was then purchased by a fellow MLR member who owned it until May 2010 when I bought it. Here is the original advert from when I purchased the car: https://www.lancerregister.com/showthread.php?t=319688
The previous owner and I have both maintained this car to a very high standard and it has always been garaged. Both myself and the previous owner have, wherever possible, only ever used the car in dry weather and since owning it I have SORN'd it during the winter months to keep it away from the dreaded salt. The underside is in excellent condition and was undersealed with high quality Dinitrol products not long after my ownership started.
The engine is COMPLETELY UNMOLESTED and the ECU has never been remapped.
The car was checked over by Mark Shead, at M.A. Developments in October 2012 at which time all AYC fluids, gearbox oil, transfer box and diff oil were all changed. This was just 2000 miles ago. At the same time, a boost leak check was performed and the crank pulley and water pump pulleys were replaced along with a new alternator belt.
The timing belt, hydraulic tensioner, tensioner pulley, idler pulley, balance belt and balance belt tensioner were all replaced in April, less than 1000 miles ago. The work was done by Eurospec, Japanese performance specialists in Guildford.
The previous owner had a Sterling (Toad) Category 1 alarm and immobiliser professionally fitted in May 2009 and it comes with the certificate of installation and two fobs. He also had a new Helix organic clutch and Evo VII flywheel (which is lighter) fitted in October 2009, just 10,000 miles have been done since then.
Since I have owned the car I have added quite a few modifications which I feel have improved yet further what was already a fabulous example of a TME.
The brakes have been upgraded front and rear with Godspeed grooved discs and EBC Bluestuff NDX pads. I have also fitted HEL braided lines all round and use Motul RBF600 brake fluid.
The suspension has been lowered using to Tein S.Tech lowering springs and new front strut top mounts were fitted at the same time. The car now handles superbly and is still a reasonably comfy ride on the motorway.
The interior is in excellent condition. As I am so meticulous, I have actually replaced the front and rear seats with a mint set as the original driver seat had some bobbling starting on the bolster and the top of the rear bench was starting to fade. The replacement set are in excellent condition. I have also installed Defi amber/black gauges, in a gauge pod, new Ralliart mats and a Gizzmo shift light.
The wheels are the original Enkei items and are in very good condition. They currently have Goodyear Eagle F1 Asymmetric 2 225/45R17 94Y XL tyres fitted with good tread.
I have only ever used high quality products in my performance cars and this car is no exception. The engine oil is changed every 3,000 miles (or less) and the AYC fluid is changed every 3,000 miles (or less). The transfer box, rear diff and gearbox oils have all been changed recently too.
Engine Specifications:
- 4G63 in-line 4-cylinder, 16-valve DOHC, turbo with intercooler and twin-jet intercooler water spray
Engine Misc.:
- New battery fitted in April (Type 054 Varta Asia Car Battery 12V 40Ah)
- Fuchs Pro S 5w-40 Engine Oil (changed every 3000 miles, if not earlier)
- Evo VII Helix Stg. 1 Organic Clutch & Flywheel
- Metal Re-Circ Dump Valve from 8/8MR/9/9MR
- Spec-R Alloy Manifold Heat Shield
- Walbro 255lph fuel pump
- Ralliart 1.3bar radiator cap
Gearbox:
- 5 Speed Manual
Turbocharger & Induction:
- HKS Super Hybrid Panel Filter
Exhaust:
- HKS Silent HiPower
Drivetrain:
- 4WD
- Active Yaw Control (AYC)
- Transfer Box, Rear Diff & AYC all Amsoiled (ATF in AYC changed every 4500 miles, if not earlier)
Brakes:
- Godspeed Grooved Discs (all round)
- EBC Bluestuff NDX Pads (all round)
- HEL Braided Brake Lines (all round)
- Motul RBF600 High Performance Brake Fluid
Suspension, wheels & tyres:
- Tein S.Tech Lowering Springs
- Original Enkei TME Alloys
- Goodyear Eagle F1 Asymmetric 2 225/45R17 94Y XL Tyres
Interior:
- Gauge Pod (supplied by FCM Motorsport) - Note: this is only stuck to the dash using special adhesive strips, no holes were made in the dash.
- Defi Link Meter BF Boost, Oil Pressure and Oil Temperature Gauges and control unit
- Gizzmo Dual Stage Shift Light
- Panasonic CQ-C5303N WMA/MP3 CD Headunit
- Pioneer TS-E1702i speakers (front)
- Pioneer TS-E1702is speakers (rear)
- Ralliart Carpet Mats
Exterior:
- Scotia White coachwork
- AutoArt Clear Side Repeaters
- FQ Ralliart Polyurethane Mud Flaps
- Undersealed with high quality Dinitrol products
Other:
- PIAA High Tone Performance Sports Horns 500/600Hz
- Philips BlueVision ultra sidelight bulbs
I would dearly love this car to go to a fellow club member as I honestly believe it is an excellent example of a Tommi Makinen Edition.
Feel free to PM me with any questions you may have about the car.
White Lightning is offline   Reply With Quote
Old 25-08-2013, 12:02   #2
!Simon
!Simon's Avatar
Looks VERY tidy! GLWS
!Simon is offline   Reply With Quote
The Following User Says Thank You to !Simon For This Useful Post:
White Lightning (25-08-2013)
Old 25-08-2013, 12:22   #3
spirit
Car: prev: Evo 9 Wagon, Evo 8, 2 x VR-4 Type S
Having known this car for 3 years, I can vouch for the outstanding condition it's in and the way it's been meticulously maintained and loved.......and an added bonus of an unmolested engine !
I'm sure this will sell to the first person to view it. GLWTS mate, and I know you will sorely miss her.
spirit is offline   Reply With Quote
The Following User Says Thank You to spirit For This Useful Post:
Old 27-08-2013, 00:02   #4
whitti_uk
Car: C1-R built and sponsored Evo 6 TME, forged engine, JUN272's, 80 series... Pushing 450bhp / 460lb/ft
Gutted to see you are selling. Seen this in person (he had my mint seats) and the car is very well looked after and unabused. A great buy for someone who wants a genuine clean and well maintained Mak
whitti_uk is offline   Reply With Quote
The Following 2 Users Say Thank You to whitti_uk For This Useful Post:
rosco323 (01-09-2013), White Lightning (27-08-2013)
Old 29-08-2013, 12:14   #5
White Lightning
Car: Evo 6.5 TME
The price has been reduced to £7995 and at this price I would be very surprised if a better TME could be bought for this amount of money. I am going to start advertising it on main stream websites, like PistonHeads, from tonight so if any other MLR members are interested (I have had contact from one already) then now is the time to get in contact.
No dreamers or time-wasters please. Genuine enquiries only. I will also not even consider allowing a test drive without suitable proof of adequate insurance.
Old 29-08-2013, 20:15   #6
White Lightning
Car: Evo 6.5 TME
Now advertised on PistonHeads too:
http://www.pistonheads.com/classifie...n-tme/1659142#
Old 29-08-2013, 20:33   #7
DINGER 9
Car: white evo 6 gsr
looks lovely bud glws, going make nice car for lucky person
DINGER 9 is offline   Reply With Quote
The Following User Says Thank You to DINGER 9 For This Useful Post:
White Lightning (29-08-2013)
Old 29-08-2013, 20:55   #8
Paulj1
Paulj1's Avatar
This looks a really nice well maintained example and must stop looking at it.
Shouldn't need luck with the sale.
Paulj1 is offline   Reply With Quote
The Following User Says Thank You to Paulj1 For This Useful Post:
Old 30-08-2013, 03:00   #9
Rui Santos
Rui Santos's Avatar
Still for sale? Pls Pm details
Rui Santos is offline   Reply With Quote
Old 30-08-2013, 07:27   #10
chris g
Location: Skelmanthorpe via Otley, London, Lancs, Hamilton NZ and Glos
Car: prev MR2, VR-4 S Type, 323 GTR, ST3, VR-4 Estate, Airtrek and now Ralliart Sportback
PM details ...?
The comprehensive details are in the advert...!
chris g is offline   Reply With Quote
The Following User Says Thank You to chris g For This Useful Post:
White Lightning (30-08-2013)
Old 30-08-2013, 08:33   #11
White Lightning
Car: Evo 6.5 TME
Yes, the car is still for sale. What details do you need?
Edit: it looks like I cannot PM you as you are only a registered user (and not a full member).
Old 30-08-2013, 08:41   #12
KarlosDaJackal
Going faster than b4
KarlosDaJackal's Avatar
Location: Sold the house to live in an 8mile long tunnel....
Car: Audi S3 Quattro :D and fully forged 420/420 M.A.D UK WHITE TME
great advert.. nice clean tidy car too, in the best colour too.. GLWTS.
Built, Maintained and cared for by M.A.D.....
UK MINT MAK................
The UK TME rare List:https://lancerregister.com/showpost.p...&postcount=530
KarlosDaJackal is offline   Reply With Quote
The Following User Says Thank You to KarlosDaJackal For This Useful Post:
Old 30-08-2013, 16:18   #13
spirit
Wow ! Bargain price for such a great car
Old 01-09-2013, 16:38   #14
Rui Santos
Rui Santos's Avatar
Email sent.cheers.
Old 02-09-2013, 08:31   #15
White Lightning
Car: Evo 6.5 TME
Email sent.cheers.
Replied.
