Evo Rally Car for sale - Mitsubishi Lancer Register Forum
Old 14-07-2007, 00:30   #1
chunkymonkey
chunkymonkey's Avatar
Car: Audi A8 and Impreza Rally Car and Evo 4 Rally Car
Mitsubishi Evo Rally Car for Sale
Evo 2 Rally Car with competitive spec and large spares package.
Logbooked as an Evo 2 in 2005, although it appears from the engine designation that it may be a 1, but much the same car anyway. Only done 9 events since full rebuild – pictures available.
GEMS Ecu, with ant-lag system, jacked throttle and 34 mm turbo restrictor. Mapped by Pye Motorsport. Weld in T45 cage. OMP winged co-driver seat fitted. Driver’s seat is new Corbeau Sprint XL, but matching OMP seat available if preferred. Both on welded in seat rails. TRS Belts in date, plumbed in Lifeline fire extinguisher and hand held. Navigator light. Alloy footrests. Peltor intercom. Close ratio rs gearbox. Braided brake and fuel hoses with compression fittings. Alloy fuel tank. Aluminium radiator with integral oil cooler. WRC sump guard. Drummond Motorsport coilover suspension with forest springs. New head gasket and new timing belt 3 events ago. Upright WRC style hydraulic handbrake.
I have only done one full event since buying the car, which was this year’s Granite City rally, after the clutch failed on stage 1 of this year’s Snowman Rally. Since it came into my possession I have replaced the following items;-
New Helix Cerametallic Clutch, cover, plate and release bearing – only done 1 event
New thermostat – one event
New exhaust, so now within noise limits – one event, plus one stage
New alternator – one event
New Mintex brake pads all round – one event plus one stage
New spark plugs, oil, and brake fluid – one event plus one stage
Replaced Expansion bottle
New front brake calipers – no event use
New rear coilover inserts – no event use
The car is taxed til March 2008 and Mot’d til the end of August this year.
It is supplied with a large spares package which includes;-
Spare engine, 2 gearboxes, 2 transfer boxes, rear diff, front wishbones, rear arms, front and rear cradle, steering rack and column, propshaft, etc. Also one set of 15in OZ wheels with Yokohamas which have only done 25 stage miles. One set of Compomotive 15in wheels with Yokohamas which have only done 30 stage miles. One set of RC Advan 16 in wheels with as new Toyo T1-R tyres, which have had about 500 miles of road use. There are 3 other sets of 15in alloy wheels that fit the car that were bought for spares with ‘dead’ road tyres, that haven’t yet been used. There are 8 brand new Kumho R700 rally tyres not yet fitted to rims. There are 8 part worn rally tyres also included.
This is a highly competitive car in the right hands, just not in mine! It finished 16th on Grizedale 2006 and 10th on Malton Forest 2006 in the hands of its previous owner. Business commitments mean that I have limited opportunity to use the car, and talent deficit means that it really belongs in the hands of someone who can use it to its full advantage.
If you are looking for a cheap route into 4wd, with a competitive car and a large spares package then this is the car for you. Unused since this year’s Granite City Rally.
Priced to sell quickly at £8500 fixed. Car is located in Inverness and you would need a Transit sized van to remove the spares, wheels etc.
Call Don on 07850 749643 or email [email protected] for more pictures.
ambition > talent = accident
heading back from the dark side - bought another Evo!
chunkymonkey is offline   Reply With Quote
Old 14-07-2007, 01:03   #2
bloke101
bloke101's Avatar
Car: Evoless atm.
bttt.
cant see that being for sale long.
Someone who uses mental acuity, hypnosis and/or suggestion. ( also never believe sellers who put pics of the speedo mileage )
bloke101 is offline   Reply With Quote
