Help ! - Mitsubishi Lancer Register Forum
Old 04-11-2019, 19:28   #1
T_Selby94
User
Car: Evo 5 GSR
Help !
Looking for nuts for evo 5 turbo in need of turbo to elbow and turbo to manifold nuts, meassured the thread on the studs and if ive meassured correctly theyre m10 x 1mm thread stainless flange nuts, is this correct ? Or are they 1.25mm thread ? And are the elbow and mani nuts the same ?
Had turbo rebuilt and has been fitted with new studs all round so need 9 nuts, and dont fancy paying upto 8.94 each on ross sport for nuts ! And the old nuts and bolts are knackered !
Can anyone shed any light ? Thanks
T_Selby94 is offline   Reply With Quote
Old 05-11-2019, 10:46   #2
r3k1355
Check if Bresco have the right ones, you want the Tri-lock ones if possible.
Are they deffo M10x1.0?
https://www.bresco.com/acatalog/Exha..._Hardware.html
Old 06-11-2019, 21:12   #3
kins
Regional Organiser
kins's Avatar
Car: Evo VI RS
https://mitsubishi.epc-data.com/lanc...aust-manifold/
Exhaust manifold washers are MD050076
Exhaust manifold nuts are MR224500
https://mitsubishi.epc-data.com/lanc...charger/22746/
O2 housing nuts are MD050073
O2 housing washers are MD132933
O2 housing bolt is MD062961
Probably worth a call to Ross Sport to confirm quantities if you want to order through them.
Old 07-11-2019, 18:35   #4
T_Selby94
User
Car: Evo 5 GSR
Thanks, i already have the part numbers from looking on ross sport website, im trying to confirm what the thread is for them so i can get nuts from elsewhere
Old 07-11-2019, 19:43   #5
kins
Regional Organiser
kins's Avatar
Car: Evo VI RS
On the exhaust manifold there are 2x m10x1.25mm pitch nuts and 7x m8x1.25mm pitch.
The turbo to turbo elbow nuts are m10x1.25.
Sent from my SM-N9600 using Tapatalk
Old 07-11-2019, 22:16   #6
T_Selby94
User
Car: Evo 5 GSR
Lovely, thank you
