#1 |
www.autotorque.net
High Torque starter motors Evo 4-9 From Auto Torque
Auto Torque are pleased to offer there New High Torque starter motors.
These power full units are great as a standard replacement or as a up grade to any race engine. They are slightly larger than the standard units and do run close to the down pipe and J pipe if you have larger than standard piping/exhaust down pipe. AT high performance gear reduction starter motors are ideal for tunes race or road engines with higher compression ratios or just as an upgrade from the standard starter motor. Designed to withstand harsh motorsport environments, all AT starters are 100% new and manufactured in the UK, to the highest standards. Most AT starters are based around Denso high torque units for superb reliability. Any starter referred to as 'PMGR' are produced and supplied with lightweight magnetic field coils and planetary gear reduction. Planetary gear reduction units have an ‘inline’ gear reduction unit with sun and planet gears. Most AT starter motors have a circular stepped register which enables the motors to be rotated through 360 degrees on the mounting enabling the perfect mounting position to be obtained. (applies to Denso units only). £395 + VAT RRP £335 + VAT MLR price £15 P&P to UK main land ![]() ![]() ![]() ![]() |
Sponsored Links | |||
Advertisement |
#2 |
White FQ400
Hi Chris,
You still got these starter motors? Cheers, Steve |
#3 |
www.autotorque.net
Hi Steve,
Sold out of there and now just making to order. Would you like to place a order. Chris |
Advertisement |
#4 | |
White FQ400
Yes i will take one please. How long do you think it will take? Need it asap. PM me and i can send payment. Cheers, Steve ![]() |
#5 |
www.autotorque.net
Back in stock with a new design for 2017.
The Following User Says Thank You to [email protected] Torque For This Useful Post: | katadikos (07-09-2017) |
Advertisement |
Thread Tools | |
