Conrod Weights - Information Thread - Page 4 - Mitsubishi Lancer Register Forum
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 13-11-2010, 00:25   #46
Conrad
#armchairtuner
Car: AE86 & EvoGTR project
Send a message via Skype™ to Conrad
If you know the power ratings of each rod speak up and I will update the first post.
Conrad is offline   Reply With Quote
Old 13-11-2010, 00:45   #47
leecavturbo
leecavturbo's Avatar
Car: Evo8 MG Full Cosworth 2.2L/r stroker,Blouch xtr760,syvecs 9.8sec 30-130
your either up early or up very late. hmmm friday night let me think which
leecavturbo is offline   Reply With Quote
Old 13-11-2010, 01:15   #48
GUM EVO
GUM EVO's Avatar
Car: 2008 EVO X & 2008 EVO IX
I will add the info on the ones I know later today.
Regards,
GUM
2011 CLASS A MLRSS WINNER
GUM EVO is offline   Reply With Quote
Old 13-11-2010, 05:40   #49
Conrad
#armchairtuner
Lee, you forget I am in Singapore, 8 hours in front of you
Old 13-11-2010, 10:20   #50
leecavturbo
no that i knew, thats what i meant
Old 13-11-2010, 14:25   #51
GUM EVO
GUM EVO's Avatar
CARRILLO PRO-H BEAM 4G63 150MM CONROD (3/8 CARR BOLT):
WEIGHT: 567 GRAMS
POWER RATING: UNLIMITED POWER RATING* EXTREME DUTY ROD 250HP+
CARILLO PRO-H BEAM 4G63 1500MM CONROD (3/8 WMC BOLT):
WEIGHT: 566 GRAMS
POWER RATING: 250HP PER ROD ETREME DUTY
CARRILLO PRO-SA 150MM CONROD (3/8 WMC BOLT):
WEIGHT: 531 GRAMS
POWER RATING: 200HP PER ROD.
CARRILLO PRO-A 150MM CONROD (3/8 WMC BOLT):
WEIGHT: 509 GRAMS
POWER RATING: 100HP PER ROD
From the above the PRO-SA can handle upto 800hp and only weighs 531grams so if I was 600-800hp level I would probably go for something like them
Old 13-11-2010, 14:49   #52
GUM EVO
GUM EVO's Avatar
manley h-beam 4g63 conrod (3/8 arp2000 bolt):
Weight: 554 grams
power rating: 600hp set of four
manley h-beam+ 4g63 conrod (3/8 custom age 625+ bolt):
Weight:575 grams
power rating: 800hp set of four
manley i-beam turbo tuff 4g63 conrod (3/8 arp 2000 bolt)
weight: 675 grams
power rating: 1000hp set of four
COLOR="navy"]manley i-beam turbo tuff [/COLOR]4g63 conrod (3/8 arp new age 625+)
weight: unknown
power rating: 1300hp set of four
manley 300 m alloy 4g63 conrod (3/8 arp 2000bolt):
Weight: 685 grams
manley 300 m alloy 4g63 conrod (3/8 custom age 625+ bolt)
weight: Unknown
power rating: 1500hp set of four
Old 14-11-2010, 21:07   #53
anttist
Car: Evo 5 RS
Just checked set of Eagle CRS5900MB3D H-beam rods and all of them were 570 g including the ARP 2000 bolts and plastic bags where the rods are individually packed. My digital kitchen scale displays +/-2 g, not sure about the accuracy.
anttist is offline   Reply With Quote
Old 16-11-2010, 07:12   #54
Conrad
#armchairtuner
The data has now been collated and now lives in the PDF that is attached rather than all unformatted in the first post (it was bugging me as it was formatted when I edited it )
Still need lots of rod weights and HP per Rod weighting
Old 16-11-2010, 20:59   #55
GUM EVO
GUM EVO's Avatar
nice work dude now thats some way to spend your birthday, a proper car nut.
Old 16-11-2010, 23:15   #56
Conrad
#armchairtuner
Sad arent I?
Old 22-11-2010, 06:01   #57
Conrad
#armchairtuner
Come on people lets have some more weights or HP ratings to fill in the blanks
Old 26-12-2010, 12:18   #58
Sider
Sider's Avatar
Conrad, from my little bit of research, Cosworth dont/wont give power/torque ratings on their rods for the X. They reckon they weigh 556g (average target weight I would guess) The length is 142.72mm c/c. They come standard with "H11 tool steel rod bolts (260,000psi)" (whatever that means )
Sider is offline   Reply With Quote
Old 26-12-2010, 12:22   #59
Sider
Sider's Avatar
Old 26-12-2010, 12:45   #60
Sider
Sider's Avatar
The above info is relevant the 94mm stroker application (2.2L) Whilst the big end bore remains at a standard 55.01mm the PE bore for that is reduced from 23.03 to 21.03mm
For the standard crank (86mm) the c/c length of the cosworth rods is 143.74mm and the weight is a nominal 565g.
Similar Threads
Post a random thread thread Razor Non-Lancer Chat 2 18-12-2006 00:03
B&M Short Shift Thread Size VodkaPete Technical Questions 5 30-09-2003 19:21
