4g69 build. - Mitsubishi Lancer Register Forum
Old 24-10-2020, 20:13   #1
evo5d
evo5d's Avatar
Car: Evo 5 Tomei forged, Cage, Autronics,VolkSE-37's,Apexi,RS diff,Damd bumper,Varis kit,Ralliart
4g69 build.
I've a 4G69 87mm bore block with 100mm standard crank. Has anyone on here built one? Are parts readily available if I build it?
evo5d is offline   Reply With Quote
Old 25-10-2020, 18:01   #2
TimC
TimC's Avatar
Car: Evo IX GT
There are two ways to look at this IMO from a bottom end point of view. A 4G69 is:
A 4G63 block with 100mm "stroker" crank and bored out to 87mm
or
A 4G64 bottom end but with 6mm shorter deck height and 150mm rods
Its kind of the worst of both aspects as you have narrower cylinder walls due to 87mm bore (weaker) and don't have the extra deck height so its a bit pointless really..
Tim
TimC is offline   Reply With Quote
The Following User Says Thank You to TimC For This Useful Post:
evo5d (25-10-2020)
Old 25-10-2020, 18:12   #3
kikiturbo
Car: EVO 9 GSR
it is also more "open" on top deck and has the lightest 100 mm crank. There was a build on evom. With 87 mm bore i think boring is out of the question... Might be a interesting way to a cheap 2.3 for those that are not too power hungry.. although there are better cheap block options out there..
ACD/AYC pump repair video
Old 25-10-2020, 22:35   #4
evo5d
evo5d's Avatar
This was very cheap. What other block options are there other than 63 or 64? It's supposed to be a cheap build so I will try anything really
Old 25-10-2020, 22:44   #5
Mita
No such thing as a cheap build
Pushpex (28-10-2020)
Old 25-10-2020, 23:00   #6
evo5d
evo5d's Avatar
I knew that would be the first response It's nice to think of them that way at the beginning, and then just forget what they cost as the build continues.
The Following User Says Thank You to evo5d For This Useful Post:
Mita (26-10-2020)
Old 26-10-2020, 07:38   #7
kikiturbo
Car: EVO 9 GSR
if you want cheap 2.3 then yes, g69 or g64. Other options are not so affordable..
Old 26-10-2020, 12:11   #8
Mita
Iíve been told numerous times, think of a price and double it
Old 26-10-2020, 13:43   #9
richyx
the 4g64 block was also used in other makes of car not just mitsubishi
you just have to keep searching for one, they will be cheap enough if you find someone breaking the car they came out of
my resto thread
richyx is offline   Reply With Quote
Old 26-10-2020, 13:58   #10
leeslancer8
leeslancer8's Avatar
Car: EVO 8 260 - EVO 7 RSII - EVO 8 FQ320 MR - EVO 4 GSR
It would be nice to know what was considered a reasonable price nowadays for a decent spec’d engine. I had a 2.3 built years ago by a reputable tuner and was pretty dear but great quality and that was using a new oem crank. And me suppling a full 8 long engine
leeslancer8 is offline   Reply With Quote
Old 26-10-2020, 17:34   #11
kikiturbo
Car: EVO 9 GSR
I bought a complete g64 for 150 eur. A complete outlander g63 dohc NA engine, which is a nice bassis for converting to evo 8 engine (with aftermarket crank and some headwork) is about 700 to 1000....
g69 was used in some citroens, like ccrosser, but those are hard to find in petrol version.. LOL
Old 26-10-2020, 17:38   #12
kikiturbo
Car: EVO 9 GSR
I recently finished a engine forge and complete body strip and overhaul on a friends 9, with numerous mods... As that project dragged on, I never made a sum of all costs, nor did I put the price on my labour.... However, I recently had to do so because someone asked how much it would cost on his car, and frankly speaking I was shocked.. hahahaha
The Following 2 Users Say Thank You to kikiturbo For This Useful Post:
evo5d (26-10-2020), Mita (26-10-2020)
