Forged Engine Run In - Mitsubishi Lancer Register Forum
Old 14-08-2020, 18:51   #1
OllieT&E24
Hi there all, hope you're all well.
So, I'm getting ready in the next few days or so to drop my freshly rebuilt, forged engine back in the car and this is a pretty big question I need to know the answer to.
Now, the car previously has two maps. One at 1.3 and one at 1.55 bar of boost on the stock Evo 5 turbo. The high boost map made 360hp and made that with a 3" elbow, 3" downpipe, blitz nurspec, drop in pump, JMF manifold and cosworth panel filter.
The setup now is completely different. It's a 2.0 long rod with Kelford 272's, ported and polished head, port matched manifold with 70mm throttle body, Manley springs and retainers, Asnu 1050cc injectors, 2.5" intercooler piping, ETS 4" Evo 8 intercooler, and a plethora of other parts including that JMF manifold and a Evo 9 80 series with a 20g wheel conversion.
I'm not sure if anything else would play a part but how am I going to run the engine in? Everything is going to be so far out haha.
I'm planning to stay stock ECU and go speed density as I really don't have the money right now for a Link. So figured, stay stock and keep it conservative for now. But is there a way to flash like a base map on to it so I can drive it around "safely" for the run in period etc?
Any help on this issue would be much appreciated thanks!
OllieT&E24 is offline   Reply With Quote
Old 14-08-2020, 19:59   #2
Mita
Just wondering... but why don’t you get the advice off the person who built it?
The Following 2 Users Say Thank You to Mita For This Useful Post:
Humps85 (14-08-2020), OllieT&E24 (14-08-2020)
Old 14-08-2020, 22:49   #3
j dog
Car: 2007 evo 9 340
Originally Posted by Mita View Post
Just wondering... but why donít you get the advice off the person who built it?
I'm guessing that looking at his previous posts, he's built it himself.
j dog is offline   Reply With Quote
The Following User Says Thank You to j dog For This Useful Post:
Old 14-08-2020, 22:56   #4
Mita
Well then he should know the answer
Old 15-08-2020, 20:23   #5
OllieT&E24
Yeah, I built it but I was thinking monitor AFR's and stay with standard injectors and if it runs well enough, drive it about a bit and run it in but I don't know how safe that'll be. Ideally want to base map flash the my ECU so it's safe
Old 15-08-2020, 20:32   #6
grants
grants's Avatar
Pay a competent mapper
some are not .
Old 15-08-2020, 22:24   #7
Arronevo8
Don't over think it just drive it. I used Millar running in oil twice and then Fuchs Titan 10/50 and give it some.
The Following User Says Thank You to Arronevo8 For This Useful Post:
OllieT&E24 (20-08-2020)
Old 16-08-2020, 09:26   #8
tracker
As above, just drive it, couple of oil changes. Just don’t go mad on the boost
tracker is offline   Reply With Quote
The Following User Says Thank You to tracker For This Useful Post:
Old 17-08-2020, 04:29   #9
Beef Curtains
Run it on the dyno while mapping. Use mineral oil for the first couple of oil changes, then synthetic oil when run in.
Put car on dyno, drive gently, varying load/revs for 30 miles or so, off boost.
Change oil and filter, cut old filter open to look for any debris/metal.
Put car back on dyno and run with more load/revs/mild boost for another 30 miles or so.
Change oil, then put back on dyno and work up to max load/revs/boost for another 30 miles.
Change mineral oil for synthetic oil, and fit new filter. Cut old filter open to look for debris/metal. Finished.
Youíll have it done in a day. Thereís no need to run it in for 1000 miles, or even 500 miles, or any of that nonsense.
Go and kick its head in.
Beef Curtains is offline   Reply With Quote
The Following User Says Thank You to Beef Curtains For This Useful Post:
Old 17-08-2020, 08:12   #10
Rampant
Profound thinker
Rampant's Avatar
Car: Evo VI GSR Import (& '16 WRX STI & gen1.5 997 Turbo)
Think about it logically...
What controls AFR and what controls boost?
If your boost control setup hasn't changed from before, then the boost ought to still be controlled within reason. (If you've changed from standard 2 port boost control to an aftermarket 3 port, then some significant changes will need to be made...)
If you'll be using EvoScan and EcuFlash to tne the ECU, then the one thing that probably needs changing is the injector size in the mapping.
You're not going to be putting any real stress on the engine to begin with, so the existing timing map ought to run the car OK.
You may need to tweak the idle settings so the car runs and doesn't cut out at idle. (It's been such a long time since I've looked at EcuFlash, I can't remember what idle inputs can be changed, lol?)
With those minimal things done in the old map, what are people's thoughts on running the car in, on the road, on light throttle and varying low loads? (A self-builder probably hasn't got easy access to a dyno?)
Je cherche l'orgasme d'auto
J'ai trouve l'orgasme d'auto
The Following User Says Thank You to Rampant For This Useful Post:
Old 20-08-2020, 22:17   #11
OllieT&E24
This was sort of the way I was leaning towards doing it. However, after speaking to Norris Designs, they don't really bother doing this for people as it isn't really worth their time. Norris's run in period for road run in is more or less what you said above but without the dyno
It'll still have all the previous boost controllers and original setup on it. I am probably going to throw in some standard 560cc injectors which is what it was mapped on before and it should run and drive well enough for the run in period.
Thanks all for the responses. If anyone else has any input, please post up!
Old 22-08-2020, 03:42   #12
TimC
TimC's Avatar
Car: Evo IX GT
The only change to what Beef Curtains has said that I would do is use a specific break in oil rather than mineral. Something from Driven would be my preference.
Tim
TimC is offline   Reply With Quote
The Following User Says Thank You to TimC For This Useful Post:
OllieT&E24 (24-08-2020)
Old 22-08-2020, 10:14   #13
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
Initially my engine builder would drive the car at a pretty much constant speed of around 60mph for an hour or so - in 5th gear. That was using mineral oil. Then change for fresh mineral oil and start to introduce speed and load variation for another amount of mileage (can't recall how many). Then on to regular oil and potentially full beans thereafter.
Phil
Old 22-08-2020, 19:24   #14
evo-fruitcake
drive up a hill or slope and rev to 40-50 mph and D accelerate not touching gas pedal ? helps sealing piston rings
evo-fruitcake is offline   Reply With Quote
The Following User Says Thank You to evo-fruitcake For This Useful Post:
