Monster Sport water pump pulley - Mitsubishi Lancer Register Forum
Old 24-12-2019, 17:25   #1
EVO8ARD
Hi from France,
I'm building a high spec street/rally car Evo 8/9 and I'm hesitating to fit an aluminium oversize water pump pulley from Monster sport
https://www.nengun.com/monster-sport/water-pump-pulley
Engine is fully build and balanced and I use a Fluidampr crank pulley. Max Rpm of the engine is 8500Rpm, it has a PWR oversize radiator, power steering and Air conditioning compressor.
Do you think it's good idea to increase water pump rotation ? The car is not a full race car, it's drive on mountain pass and run in traffic usually, and can be stuck in traffic jam at idle at 40░C exterior temp at summer.
What about the wear with aluminium compare to OEM ? (Monster sport product are top quality materials, not crap Ebay pulley...)
What about the balancing of the water pump unit compare to OEM ?
Thanks for your feedbacks
EVO8ARD is offline   Reply With Quote
Old 24-12-2019, 19:38   #2
Sparksgsr
Sparksgsr's Avatar
Car: viii fq320 & vi gsr
Interested in the replays to this. I would think this is expensive for what it is
Sent from my SM-G960F using Tapatalk
VIII GSR - MEDIUM PURPLE PEARL
VI GSR - RED +
STICKERS
Sparksgsr is offline   Reply With Quote
Old 25-12-2019, 07:29   #3
Beef Curtains
Why would you want to affect the engine cooling in that way?
If the water is being pumped round the engine quicker, it is spending less time in the radiator. Less time spent in the radiator, means less cooling time.
Beef Curtains is offline   Reply With Quote
Old 25-12-2019, 14:51   #4
kikiturbo
Car: EVO 9 GSR
Actually, this is an underdrive pulley... i.e. it will spin the water pump slower than OE... The idea being less cavitation and losses at high RPM...
ACD/AYC pump repair video
Old 25-12-2019, 16:24   #5
EVO8ARD
Exactly, the main idea is less cavitation and reduce weight, for higher rev's.
Do you think it's a bad idea to use it ?
https://www.monster-sport.com/produc...ley/index.html
Old 27-12-2019, 13:58   #6
TimC
TimC's Avatar
Car: Evo IX GT
You would only get cavitation if you have a restriction of water flow going into the pump.
Personally I would not want to slow the pump down, by doing so you would be decreasing flow and system pressure. You want the pressure as it raises the boiling point of the coolant and will also decrease the chances of hot spots forming.
Tim
TimC is offline   Reply With Quote
The Following User Says Thank You to TimC For This Useful Post:
Sparksgsr (28-12-2019)
Old 28-12-2019, 21:18   #7
Andrew B
Andrew B's Avatar
Car: IX MR360
Evo spec sell them
Very popular
No cooling issues even 1000 bhp north
I use one also
Andrew B is offline   Reply With Quote
Old 29-12-2019, 01:16   #8
Lolo la Torche
Senior French User
Lolo la Torche's Avatar
Car: Full Black Evo IX 600HP+
Salut compatriote!
Why do you think you will have cooling problems? Do you already have issues to fix?
Lolo la Torche is offline   Reply With Quote
Old 01-01-2020, 13:52   #9
EVO8ARD
Hello Mr Lolo, southern neighbor
It was just to check if if add a cooling benefits
Thanks everyone for your feedbacks
Old 01-01-2020, 20:07   #10
Lolo la Torche
Senior French User
Where are you from? Do you know there is an interessant community of Evos owner in France?
Old 01-01-2020, 20:34   #11
EVO8ARD
Salut Laurent, c'est Victor de Frejus (Vic Tory sur FB)
