What fuel set up is needed for 600-700hp? - Mitsubishi Lancer Register Forum
Old 29-03-2014, 01:10   #1
Chappers23
As above what fuel set up for 600-700hp currently running id1000 injectors 2 aeromotive 340lph fuel pumps -8 feed line aeromotive fuel rail and reg.
When is a external 044 required
Currently running 605hp but going for more and going to do some track days so not sure if the current spec will be ok
Chappers23 is offline   Reply With Quote
Old 29-03-2014, 21:50   #2
Chappers23
Anyone?
Old 29-03-2014, 22:04   #3
the hunter
senior stroker
the hunter's Avatar
Car: 2.4 Stroker EFR 8374 2.6bar 730ftlb/730Hp New drawers may be required!!!!!!!!!
You may have headroom yet .
I have just one bosch 044 but fed from a fuel cell and were looking about 700-750 hp
Oh and I have id 2000 cc injectors .
Sent from my GT-I9300 using Tapatalk
the hunter is offline   Reply With Quote
Old 29-03-2014, 22:08   #4
Chappers23
Ok thanks have seen on here there have been a few probs with aeromotive pumps. Think a 044 may be a option purely for piece of mind tbh.
Will I require a swirl pot for 044 external pump?
Old 30-03-2014, 08:54   #5
Mark Shead
Car: Evo 6 under construction
One Bosch is not enough for 700hp.
Mark
Mark Shead is offline   Reply With Quote
The Following User Says Thank You to Mark Shead For This Useful Post:
jonnyc (30-03-2014)
Old 30-03-2014, 09:00   #6
the hunter
senior stroker
the hunter's Avatar
My mistake mark I have 2 x 044 bosch .
Old 30-03-2014, 09:50   #7
si2000
Car: Ex Evo 9GT in white, now evo 6RS
Use a walbro or equivalent lift pump and put an 044 in-line that should be plenty
si2000 is offline   Reply With Quote
Old 30-03-2014, 10:11   #8
the hunter
senior stroker
the hunter's Avatar
no chance mate that will max out early.
thats the set up i had @ 550 hp
Old 30-03-2014, 19:26   #9
si2000
Are you sure, a walbro on its own is good for just over 500 so adding the bosch should create a fair bit on top.
Old 30-03-2014, 19:35   #10
the hunter
senior stroker
the hunter's Avatar
Fair enough its your engine.
Old 30-03-2014, 19:39   #11
the hunter
senior stroker
the hunter's Avatar
This is what I have .Atec mount with a pair of bosch 044 and a filter up top.
Dash 8 feed line and a dash 6 return.
All pushing to ID 2000cc injectors .
The Following User Says Thank You to the hunter For This Useful Post:
Chappers23 (30-03-2014)
