Shorted out at radio: Fuse??? Evo7 - Mitsubishi Lancer Register Forum
Old 24-05-2020, 00:16   #1
Stofff
Exclamation Shorted out at radio: Fuse??? Evo7
Hoping someone can help me here...
Evo 7 GSR
I Was swapping my radio and a wire shorted. I presumed blowing a fuse but I am unable to find anything blown.
The interior light, stereo, clock, central locking, elec mirrors, rear wiper and washer have stopped working properly.
It appears a Permanent Live connection/fuse has gone as when the ignition is off i am unable to use central locking, trip counter zero’s and the clock goes back to 1:00.
Really appreciate any info someone can give me!!!
Stofff is offline   Reply With Quote
Old 24-05-2020, 08:38   #2
jhfozzy
S.Wales R.O./Electrician
jhfozzy's Avatar
Car: Evo VI
It'll be the fuse, there are two for the radio, one perm and one ignition.
Remove and check continuity.
John
jhfozzy is offline   Reply With Quote
Old 24-05-2020, 14:20   #3
Stofff
Which fuse and where is it located?
Old 24-05-2020, 16:02   #4
TrickyDick
Very Senior User
TrickyDick's Avatar
Car: VII FQ-300x2
Check dedicated fuses 15,17 & 18 in the main fuse box under bonnet.
TrickyDick is offline   Reply With Quote
Old 24-05-2020, 16:12   #5
TrickyDick
Very Senior User
TrickyDick's Avatar
Car: VII FQ-300x2
There are also a couple of related fuses in the J/B that is inside down below the steering wheel.
Old 24-05-2020, 19:16   #6
jhfozzy
jhfozzy's Avatar
Car: Evo VI
In the fusebox under the bonnet.
Fuse 15 (7.5A), red circle, is for the side lights including the stereo.
Fuse 17 (10A), blue circle, is the ignition feed to the stereo.
Fuse 18 (10A), green circle, is the permanent live to the stereo.
John
Old 25-05-2020, 20:57   #7
Stofff
Thanks for the reply guys. This appears to be the wiring diagram that I keep reading about but it does not match My fuse box. See attached pic:
Note NO FUSE 17 - 18
Old 25-05-2020, 20:59   #8
jhfozzy
jhfozzy's Avatar
Car: Evo VI
Your fusebox matches that diagram?
Are there terminals in position 17 & 18?
John
Old 25-05-2020, 21:04   #9
jhfozzy
jhfozzy's Avatar
Car: Evo VI
I was looking for a picture of the fusebox and this thread came up.
https://www.evolutionm.net/forums/la...working-2.html
John
Old 25-05-2020, 23:10   #10
Stofff
All the threads and posts I have found speak of this yellow box with 2 10a fuses in it and peoples struggle at removing them. This fuse holder and fuses are not in my fuse box I.e fuses 17 - 18 they have never been there. Compare this fuse box with the previous one. This is a strange one. Thanks for your time and help looking at this.
Old 25-05-2020, 23:44   #11
jhfozzy
jhfozzy's Avatar
Car: Evo VI
Have you got a close-up of the slot on your fusebox where the yellow bit should be?
Maybe someone lost the yellow part and bypassed it?
John
Old 26-05-2020, 15:41   #12
grants
grants's Avatar
I have an E8 FQ300 loom and there are no fuses in locations 17/18
What happens in ETACS; i don't want to know !!
The Following User Says Thank You to grants For This Useful Post:
jhfozzy (26-05-2020)
