Evo 5 Sprint Car - Underside Restoration - Page 8 - Mitsubishi Lancer Register Forum
Old 03-12-2018, 14:42   #106
Cardsharky
Regional Organiser
Cardsharky's Avatar
Stunning, love the attention to detail on this V, what a weapon.
Cardsharky is offline   Reply With Quote
The Following User Says Thank You to Cardsharky For This Useful Post:
Greeny-o (03-12-2018)
Old 03-12-2018, 14:54   #107
Greeny-o
Greeny-o's Avatar
Car: NR Autosport Forged Evo 5 - 520 Bhp
Originally Posted by Adz_306 View Post
Fantastic job there .
Bet you can’t wait to enjoy all the hard work you’ve put in
Hoping to get out before Xmas, video to follow!
"Sometimes in life you're ahead, sometimes you're behind. The race is long, and in the end, it's only ever with yourself"
MLRSS 2015 Class A - Champion
MLRSS 2016 Class B - 2nd
Greeny-o is offline   Reply With Quote
Old 03-12-2018, 15:03   #108
Greeny-o
Greeny-o's Avatar
Cheers buddy, not sure if I dare drive it like I used to
Old 03-12-2018, 15:48   #109
Mita
Great work mate
Old 03-12-2018, 18:51   #110
JasonL91
JasonL91's Avatar
Car: Evo 9 GT Ruri Blue
Absolutely amazing. What a car!! The lads at MG really know their stuff. Hats off to you sir..
JasonL91 is offline   Reply With Quote
The Following User Says Thank You to JasonL91 For This Useful Post:
Old 04-12-2018, 21:40   #111
gordonm
Regional Organiser
Car: Voltex 9 GT
Wow! that looks terrific.
gordonm is offline   Reply With Quote
The Following User Says Thank You to gordonm For This Useful Post:
Greeny-o (05-12-2018)
Old 15-11-2019, 18:51   #112
Greeny-o
Greeny-o's Avatar
So it’s been quite a few months since I updated this thread, unfortunately I had a bit of a nightmare on my 1st track day out at Blyton Park last December, we are not 100% sure what happened but I spun a bearing and we lost the engine Given the work involved to get it to this point I was gutted to say the least! In fairness the engine had performed well over a number of hard seasons with both myself and the previous owner really giving it some hammer on trackdays, sprints and on the hills.
I took the decision to rebuild the engine to a higher standard, hopefully meaning it would be done right and done once. I chatted with Nigel Barker at Fenton Motorsport in Leeds, a good friend of mine who is ideally located only 15 minutes from my house so we discussed spec and we decided with a 2.3 stroker engine with some headwork to complement the Blouch GT30 turbo I already had, with a Norris Design's v4 dry sump kit to ensure no more oil starvation issues.
The build took about 5 months in total to complete including deciding on the spec as well as build and mapping. I was really pleased to be able to tempt Nick Rowntree (previously of NR Autosport) out of retirement and we ‘live’ mapped the car with low and high boost settings on the roads of Lincoln which was a hairy experience to say the least. The last 3 months have involved getting some seat time and getting the geo dialled in which was initially way out resulting in some ‘usual’ handling on my 1st sprint out at Croft. After another day at Oulton and a track day at Blyton I can finally say I am happy with the set-up, it absolutely fly’s.
I have included most of the build spec below and will add some extra posts with pics from the track days in due course, fingers crossed for a good season next year.
It’s never a dull moment with Evo’s
Engine Build Spec
Blouch GT30 Turbo with Race-tech manifold
ND 2.3 Stroker Kit (1000bhp rated)
ND forged steel 100mm crankshaft (fully balanced)
Manley 150mm I beam turbotuff rods
ND spec JE piston (85.5mm) and ring set and a full set of bottom end bearings
Fenton Motorsport/Norris Stage 5 - Headwork
Ported, polished
Modify combustion chambers
Fully de-burred
Skimmed surface
Parts included with head build;
- ND valve spring kit
- Tomei 280 Cams
- ND shim set
- ND Ti retainers
- ND 1mm oversize inlet valves
- New larger inlet valve seats
- ND 2mm oversize inconnel exhaust valves
- ND bronze valve guides
- ND solid lifter camshafts
- ND solid lifter set
Norris Designs V4 - Dry Sump Kit
ND Evo 4-6 Special Dry Sump Special Tank (Offside Inner Wing)
All new oil pump from AUTO VERDI, best oil pump in the market! Used by most current World Rx cars!
New oil pump bracket for the above oil pump, new belt and adjustable oil pump pulley offset
Reverted sump scavenge and filter design back to V1, 2 and 3! V3+ wasn't so easy to service and fit
Pump crank drive sprocket now bolts on via the four crank pulley bolts NOT via main through bolt
Two piece crank drive pulley
More durable Steel Scavenge tubes and fittings
Standardised ½” BSP thread in various areas
Slightly faster pump speed for improved efficiency
High power HTD belt supplied instead of std strength
50% thicker crank baffle plate
Shorted scavenge tube routing
More durable and compact metal scavenge pipework rather than AN fittings and hose
Larger dash 10 turbo oil drain
Various aluminium AN fittings changed to steel to be more durable
25 row oil cooler
20190218_094156 by Nicholas Greenwood, on Flickr
20190218_094128 by Nicholas Greenwood, on Flickr
20190218_094019 by Nicholas Greenwood, on Flickr
20190218_093513 by Nicholas Greenwood, on Flickr
received_332731690781871 by Nicholas Greenwood, on Flickr
20190503_092631 by Nicholas Greenwood, on Flickr
20190218_093959 by Nicholas Greenwood, on Flickr
20190218_093954 by Nicholas Greenwood, on Flickr
20190218_094814 by Nicholas Greenwood, on Flickr
20190309_085044 by Nicholas Greenwood, on Flickr
20190309_083631 by Nicholas Greenwood, on Flickr
20190406_083505 by Nicholas Greenwood, on Flickr
received_2067627800022415 by Nicholas Greenwood, on Flickr
received_417118195739041 by Nicholas Greenwood, on Flickr
received_314090642590873 by Nicholas Greenwood, on Flickr
received_432766454201313 by Nicholas Greenwood, on Flickr
received_597308277383531 by Nicholas Greenwood, on Flickr
20190618_134718 by Nicholas Greenwood, on Flickr
20190618_133549 by Nicholas Greenwood, on Flickr
The Following 4 Users Say Thank You to Greeny-o For This Useful Post:
Adz_306 (16-11-2019), dreMR (16-11-2019), kins (15-11-2019), peeler (28-11-2019)
Old 15-11-2019, 19:09   #113
Greeny-o
Greeny-o's Avatar
Following the rebuild, I decided to add some colour to the car to brighten it up a little and as a bit of a PR exercise for an event we were having at work
FB_IMG_1555446756394 by Nicholas Greenwood, on Flickr
FB_IMG_1555446764616 by Nicholas Greenwood, on Flickr
FB_IMG_1555446770538 by Nicholas Greenwood, on Flickr
FB_IMG_1555446774986 by Nicholas Greenwood, on Flickr
FB_IMG_1555446796824 by Nicholas Greenwood, on Flickr
FB_IMG_1555446808452 by Nicholas Greenwood, on Flickr
The Following 7 Users Say Thank You to Greeny-o For This Useful Post:
Adz_306 (16-11-2019), david_smith_909 (15-11-2019), dreMR (16-11-2019), kins (15-11-2019), leeslancer8 (15-11-2019), Tom Dick (15-11-2019), willox (16-11-2019)
Old 15-11-2019, 20:26   #114
Mita
Nice work Nick, car looks great mate . Sorry about the issues , but now it’s all fresh and ready for more! Nick NR is a top bloke , nice one
Greeny-o (15-11-2019)
Old 15-11-2019, 20:34   #115
kins
Regional Organiser
kins's Avatar
Car: Evo VI RS
Looks really good Nick. What are your plans for next year mate?
Sent from my SM-N9600 using Tapatalk
The Following User Says Thank You to kins For This Useful Post:
Old 15-11-2019, 22:03   #116
Greeny-o
Greeny-o's Avatar
Thanks buddy, its taken me this long to get over losing the engine
The Following User Says Thank You to Greeny-o For This Useful Post:
Mita (15-11-2019)
Old 15-11-2019, 22:04   #117
Greeny-o
Greeny-o's Avatar
Not sure Kins, probably a mix of sprinting and a couple of Time Attack rounds as I still have a credit from this year I never got to use, what about yourself?
Old 27-11-2019, 22:13   #118
Thebooosh
Car: Scotia White 5 GSR
Is that safety devices cage a new design? I only remember them having a single door bar... or is this is a custom setup?
Thebooosh is offline   Reply With Quote
Old 27-11-2019, 22:40   #119
leeslancer8
leeslancer8's Avatar
Car: EVO 8 260 - EVO 7 RSII - EVO 8 FQ320 MR - EVO 4 GSR
Nick what make are the windows they look new? Mine have seen better days now
leeslancer8 is offline   Reply With Quote
Old 28-11-2019, 07:36   #120
super rover
acting daft since 1969
super rover's Avatar
Car: E7 RS RALLY CAR
you used to be able to spec single bars when new some track stuff was OK with single but now double is the norm
