Evo 4 clutch best clutch to use or can I switch to Evo 8 flywheel and clutch - Mitsubishi Lancer Register Forum
Old 01-03-2016, 20:34   #1
ML96EVO
Car: 96 EVO
So my Evo 4 clutch can't handle the power and is slipping in higher rpm, looking to replace my clutch with something a little bit better nothing crazy but something in the 400 hp range. Was told Evo 8 clutch will work with Evo 8 flywheel on Evo 4 not sure though. I heard they changed from 6 bolt to 7 somewhere along the line so any Any advise will help. Thanks
ML96EVO is offline   Reply With Quote
Old 01-03-2016, 21:34   #2
will2
Regional Organiser
will2's Avatar
I know you can certainly use a VII clutch/flywheel on a IV ....
Old 01-03-2016, 21:49   #3
todd-w
todd-w's Avatar
Car: Evo5 Mivec Turbo
you can use evo 7/8/9 clutch and fly all 7 bolt
todd-w is offline   Reply With Quote
The Following 2 Users Say Thank You to todd-w For This Useful Post:
ML96EVO (01-03-2016), will2 (01-03-2016)
Old 01-03-2016, 21:52   #4
ML96EVO
Car: 96 EVO
And the Evo 4 is a 7 bolt as well
Old 01-03-2016, 22:01   #5
todd-w
todd-w's Avatar
yes
The Following User Says Thank You to todd-w For This Useful Post:
Old 02-03-2016, 08:07   #6
super rover
acting daft since 1969
super rover's Avatar
Car: E7 RS RALLY CAR
there may be a dowl pin in the end of the 4 crank if so this can be whizzed of with a grinder ,i used a later clutch on my 4 worked perfect
