BOV has started fluttering - Mitsubishi Lancer Register Forum
Old 31-10-2015, 10:16   #1
Coops93
Car: Evo viii MR FQ340
i replaced my Rad yesterday, in the process i had to take the inlet hardpipe out, i disconnected all four hoses from it, i also cleaned the mushroom filter. As far as i know i have put it all back correctly. When everything was back together and i took it for a test drive i noticed the BOV was fluttering and i think the car is down on power
Any ideas on what I've done wrong or whats causing the fluttering valve ??
Cheers,
Coops93 is offline   Reply With Quote
Old 31-10-2015, 10:26   #2
ragz
Double check your vac pipe ontop of the bov, sounds like its not activating
ragz is offline   Reply With Quote
Old 31-10-2015, 10:38   #3
EVO VI
EVO VI's Avatar
Car: EVO VI GSR
Yes, either that or you fitted the BOV the wrong way round.
Shouldn't be down on power though!
You have the right to remain silent. Anything you say will be misquoted, then used against you.
EVO VI is offline   Reply With Quote
Old 31-10-2015, 10:52   #4
Coops93
The way i had put it back in had kinked the vac line,
Thanks for the help
