Miles to Km? - Mitsubishi Lancer Register Forum
Old 19-05-2015, 09:03   #1
beliblisk
Miles to Km?
Hi.
I know you guys do it the other way around but i have USDM speedo and i want odometer to measure in Kilometers.
As my Evo is full custom built from the shell up,is it any way to set odo to exact number of kms that she did,not what donor gauge did.
How can i do the above?
Best regards,
Matija
beliblisk is offline   Reply With Quote
Old 19-05-2015, 09:21   #2
MMV
You can modify your speedo to have the exact miles (equivalence of Klm) but i think you cannot change from Miles to Km.
I have my Spanish X with an EEUU speedo in miles.
The bodyshop who fixed my speedo to have the correct miles of my car told me the conversion to klm was not possible.
(Perhaps they didn't know how to do it but it would be strange because their business is modifying all kind of speedometers).
MMV is offline   Reply With Quote
Old 19-05-2015, 09:40   #3
beliblisk
Hi.
I only need to modify odo not speedo (in speedo ill just change dials backing plates to show km/hs only as now i do have both scales).
Old 19-05-2015, 10:20   #4
Dave-Cee
Climate Changer
Dave-Cee's Avatar
Car: MAD forged 2.2 IX FQ 340 PLG Leccy Bloo
I might be able to help you.
First of all, do you have a speedo converter on your gearbox? see pic.
The cluster you have at the moment reads MPH on the dials and clocks up miles on the odometer?
I have software and hardware that can change the hex code in the EEPROM chip, and have found the code that changes it from miles to km's
Dave-Cee is offline   Reply With Quote
Old 19-05-2015, 12:41   #5
beliblisk
Hi.
I dont know if i have any speedo converter on the box.It is OEM one i guess.
Yes cluster reads mph and kmh (kmh on the smaller inside scale) and clocks up miles on odo.I just need that odo to count kms
Can this be done by my self or i need electric expert?
Old 19-05-2015, 12:58   #6
Dave-Cee
Climate Changer
Dave-Cee's Avatar
Originally Posted by beliblisk View Post
Hi.
It is important to know whether you have one on the gearbox.
Without this I can't tell what needs doing.
Changing the odometer to clock up kms instead of miles requires writing hex code to the EEPROM chip that is stored on the cluster circuit board.
The best way to do this is desolder the 8 pin chip and place it in a EEPROM chip reader. You will then be able to edit the chip to change your mileage, and, change some digits for it to read kms.
If you have anyone that knows how to do this I can supply you with the hex codes you will need.
Failing that, send me your cluster and I will do it for you. Just cover the postage, don't know where you are?
Need to know about the speed converter first though,it will be sat on top of the box and will look just like the pic.
The Following User Says Thank You to Dave-Cee For This Useful Post:
Ads9 (14-12-2015)
Old 19-05-2015, 13:03   #7
beliblisk
Hi.
Ill check and let you know. Thanks a lot for your help
Old 19-05-2015, 13:15   #8
Dave-Cee
Climate Changer
Dave-Cee's Avatar
Hi.
You are welcome.
See this pic of my box. Circled in red is the speed sensor.
If it doesn't have a speedo converter it will look just like the pic. If it does, it will simply have that gadget ( first pic ) plugged on top of it.
Old 16-11-2015, 17:45   #9
piuma85
Hi. Does any one knows from where i can purchase one of those speedo convertors for my EVO8 FQ300. I had one but got smashed while changing the clutch kit. Thanks
piuma85 is offline   Reply With Quote
Old 20-11-2015, 07:54   #10
Ritchma
Hello guys. Before I start new topic... I'm in AUS and we use Km but I want to convert it to mph so I can use 300kmh dials instead. What kind of converter do I need and where can I buy it? It's for evo 6. Thanks a lot
Ritchma is offline   Reply With Quote
Old 20-11-2015, 12:40   #11
beliblisk
Why would you like to convert it to mph and use 300 km/h scale? I just dont understand what is your intention here.
Old 20-11-2015, 20:57   #12
Ritchma
Easy. 180mph is around 290kmh. All I need is cluster what shows speed in MPH and change the dials. Something like this http://moman.pl/eu/gfx/big/1380197055.9219.jpg
Old 20-11-2015, 22:50   #13
beliblisk
I see. Om my IX i did the same (but it was reading mph as it is USDM cluster)......i forgot OEM km/h scale is bigger.
Old 14-12-2015, 21:52   #14
crazytony
crazytony's Avatar
can you change kms to miles in odometer
hi dave-cee just after abit of info as im new to this forum and the brand.im due to be collecting my import evo6 tme on 19/12/15 and have been told the dials have been changed to read in mph which is fine and its now going to be counting up in miles,can the kms be wound or set back to the equivilant in miles or not ? thanks for any advice,tony
crazytony is offline   Reply With Quote
Old 15-12-2015, 00:34   #15
Dave-Cee
Climate Changer
Dave-Cee's Avatar
Not sure with the earlier cars but would think so yes.
Will look into it.
