Evo 6 Gear stick cable bracket on Gearbox ASAP - Mitsubishi Lancer Register Forum
Go Back   Mitsubishi Lancer Register Forum > Marketplace > Wanted
Old 19-05-2014, 16:40   #1
JAB1a
Hi All,
I have fallen foul of the Evo 4 gear stick cable bracket coming apart that is fitted to the gearbox, the rubber has perished. I see that this is quite common and the best replacement is the Evo 6 cable mount as it is already welded.
mine as the same issue as the ones in the photos half way down this thread...the bonded rubber has just come away...
https://www.lancerregister.com/showthread.php?t=162850
I need this ASAP as I live in the sticks and the car is essential
Thank you all for your time and effort
EvoIV [email protected]
JAB1a is offline   Reply With Quote
Old 19-05-2014, 18:47   #2
super rover
acting daft since 1969
super rover's Avatar
Car: E7 RS RALLY CAR
the 4 cable ends are differant youll need to weld the bits back on your 4 mounting bracket
The Following User Says Thank You to super rover For This Useful Post:
JAB1a (19-05-2014)
Old 19-05-2014, 19:10   #3
MarkIV
Car: White IV GSR, with VII engine
Just weld it. I put a few bits of metal snot on mine, no problems
MarkIV is offline   Reply With Quote
The Following User Says Thank You to MarkIV For This Useful Post:
JAB1a (19-05-2014)
Old 19-05-2014, 19:56   #4
JAB1a
so just checking that you are saying a direct swap for the mount/bracket which is bolted to the gearbox between a Evo 4 and Evo 6 would not be possible due to the cable being attached to the Evo 4 mount meaning I would have to swap the whole cable system as well for an Evo 6 one?
The reason I ask is because I was reading in other threads you could just swap the mount/bracket with the Evo 6 as its already welded but same fixing
Well if that's confirmed above then I will get it off and welded tomorrow instead
Thank you both for your quick replies
Old 20-05-2014, 22:18   #5
JAB1a
Ok panic over, thank you both for your help and advice.
