Evo IX no heat. - Mitsubishi Lancer Register Forum
Old 04-09-2013, 09:52   #1
Big Ells
Car: Evolution IX FQ320
Send a message via MSN to Big Ells
Evo IX no heat.
My evo IX doesn't produce any hot air. The air con works fine and blows cool, but when I turn the heat up nothing changes.
Is this going to be the controls or the actual heater?
PSN - Zeemax
Big Ells is offline   Reply With Quote
Old 04-09-2013, 11:47   #2
cossieboy450
Car: evo 9 fq340
Mine was the same. It was just sticking at the back of the control. Gave it a move abour an now its fine
cossieboy450 is offline   Reply With Quote
Old 04-09-2013, 16:18   #3
Big Ells
So just take the controls off? Or the nob?
PSN - Zeemax
Old 04-09-2013, 17:19   #4
J15OME
J15OME's Avatar
I had this same problem on my 9 I think you will find its a little rid that comes off down in the drivers foot well to the left of the clutch pedal. If you turn the heat knob you should see the little motor pulling a plastic arm this little arm pops off hope this helps
James
Horsepower is like **** buddies.. you want as many as possible, for as cheap as possible, with very few people knowing how many you actually have.
J15OME is offline   Reply With Quote
Old 04-09-2013, 17:51   #5
gpowerfq400
gpowerfq400's Avatar
Car: fq 340
Matrix mate look for water in footwell
HERE FOR A GOOD TIME NOT A LONG TIME
gpowerfq400 is offline   Reply With Quote
Old 05-09-2013, 09:21   #6
Big Ells
James
Thanks fella. It's the white hammer type part, its sticking, once you give it a nudge it moves fine. Going to lube it up and see if that works.
PSN - Zeemax
Old 07-10-2013, 03:21   #7
d_kong0719
Hi guys, i have the same problem, which Rich at RG helped me with before and fixed it but now theres no heating again.
Can anyone circle which bit im meant to give a nudge?
It moves when i turn the heater control knob (how i'd like it to blow lol)
But not when i turn the heating one from cold to hot!
d_kong0719 is offline   Reply With Quote
Old 07-10-2013, 08:21   #8
Richard G
Car: Lexarse! Now with added turbo power!
Its the part further down and to the right, a bit 'T' shaped white bit of plastic, along side the clutch pedal. That's the one that was sticking before.
Richard G is offline   Reply With Quote
Old 07-10-2013, 15:22   #9
d_kong0719
Thanks Rich
So its not in the picture?
Should i do it engine off or doesnt it matter?
Danny
Old 07-10-2013, 15:31   #10
Richard G
Not in that pic no, its just down and to the right of what you've pictured, doesn't matter if the engine is on or off mate
Old 11-10-2013, 04:18   #11
d_kong0719
Found it and all sorted again!
Thanks Rich!
Old 02-11-2018, 17:55   #12
EDK
User
EDK's Avatar
Car: CT9W
Hope the necro bump is ok, but having trouble finding the plastic arm talked about here. I've got a Jap import IX, would this be any different?
EDK is offline   Reply With Quote
Old 02-11-2018, 18:09   #13
EDK
User
EDK's Avatar
Car: CT9W
Update! Continued to search and this little video helped to pin point what the mechanism is and how it works I'll post here as it may be useful to other in future.
Old 02-11-2018, 20:55   #14
will2
Regional Organiser
will2's Avatar
https://www.youtube.com/watch?v=ne67Ct-JNqM
Had heater issue about a year or two ago also , it was this control arm sticking/skipping on the cog wheel that opens the blend door no doubt
I replaced with another arm but didnt change until i manipulated it ...
same problem returned again few months back and i tried a replacement heater control unit but still hit n miss with hot and cold selection ...
Only this last week i sorted it with finding its the control arm again the issue ....DIY bodge sorted it
The Following User Says Thank You to will2 For This Useful Post:
EDK (04-11-2018)
