Motec M800 OEM ECU - Mitsubishi Lancer Register Forum
Old 07-11-2006, 17:37   #1
JamieB
Car: EVO 6 RS II
Motec M800 OEM ECU
Can anyone explain the benefits of fitting the motec and remapping over the ralliart ecu currently in my e6.
I'm new to Evo ownership and have been recommended the upgrade.
Also what would the ralliart fetch 2nd hand? Would I ditch the boost controller with the motec?
JamieB is offline   Reply With Quote
Old 07-11-2006, 19:39   #2
ON-UJAH
Car: EVO V GSR
You can continue to use your Boost controller with any ECU.
The main reason of swapping to Motec etc. is to lose the MAF sensor, and to swap to a MAP sensor (like a Cossie uses) - this alows the mapper to map to high boost levels.
Also they are faster with more resolution, and come with other features like traction control and ALS.
There's nothing wring with the RA ECU, if you don't want to run more than about 1.6bar on the standard turbo - however if you want to swap turbo, it won't be up to the job any more, as it will no longer be mapped to that particular airflow.
A RA ECU is worth 400 GBP minimum on the secon hand market.
ON-UJAH is offline   Reply With Quote
Old 08-11-2006, 15:21   #3
evo400
Car: Trabant race car !!! Cardboard contruction the original Carbon !!!!
There is a lot of confusion about what ecu is best and what ecu is more suited to a certain car or individual. Mapping the car or reflashing the standard ecu will vary from 250-25000+ so we kind of need to draw a line some where.
I am going to divide the topic into two categories
1- EcuTek which provides the technology to remap the existing standard car’s ECUs this is commonly known as ECUTEK reflash/remap. Ecutek have been in the market for many years and their customer support as a company is next to none in the industry.
The main benefits of the using the Ecutek technology is that
• the whole process is done through the standard diagnostic connectors of the car. No direct access to the ECU is required, and there's no soldering, wire cutting or vehicle disassembly required. Reprogramming of the ECU can be performed in less than 2 minutes. No workshop is required. The entire process may be performed from the driver's seat of the car.
• All factory parameters are left intact, which means the car will pass mot, run even better fuel economy after the remap. Idle, cold start etc is all there. All we alter is the parameters that we need to alter to get to run more power. This method has a huge safety margin in it. And also is very quick.
• basically all the benefits of the standard ecu but with more power. So it is a win win situation.
There is however some limitations to running such a system.
1- this system cant be mapped live, what that means is having heavily modified engines mapped with such a system will take 4-5x the amount of time needed to do the job with an aftermarket ecu.
2- This system is MAF based which also means that the limit of this ecu is same as the limit of the maf sensor. There is boxes that will convert a map single to maf but then again, best solution will be to get something that has been designed to work with a map sensor in the first place.
3- the standard ecu has been designed with safety in mind which means it will not have some of the features needed for motor sport use. Such as antilag, some ecus have launch control but this is very basic.
4- Again since this is not a motor sport ecu, it will not have any free outputs that can be used to run additional systems, like switchable maps, wi, NOS etc although a boost switch is available on some Subaru’s.
I normally recommend this system to any car running basic mods, such as exhaust, filters, induction kits, and mild cams. However if you wanting to run a modified bottom, top end with large duration and lift cams, and large turbos then this is not the ecu for you!!
2- aftermarket ecus, a quick glance at the customers cars and you will see that we can map most ecus with good results with them all. Personally I prefer the Motec system. It is the only aftermarket ecu for reasonable price that I have come across that offers two year warranty, and also run as close if not better than a standard ecu for day to day running. The on/off throttle response is certainly improved over the standard ecu. It will also allow you to run your choice of dump valves. Cams, turbos, engine configuration etc. This is a MAP based system unlike the standard ECU which is MAF.
The benefits of this ecu can be summarized in
• it will run all the factory sensors, so no need for cutting or soldering.
• Better off throttle and on throttle response
• Can deal with pretty much anything, we are running our 1000bhp drag car on a oem pnp M800 board!! So it works.
• It has good boost control especially when combined with an uprated boost control solenoid. Again we are running this on our drag car, with in gear boost profile and 4D boost mapping etc
• This can be mapped live which makes mapping complex engines much easier
• This will run closed loop lambda on part throttle and over run which means fuel economy will be as good if not better than standard ecu. With a cat in the system the car will pass MOT tests just like a standard ecu
• The M800 has been used in production road cars such as the the FQ400 so it can be mapped to be very civilized.
The main disadvantage of this system is obviously cost, it is 4x more expensive than a reflash.
I normally recommend an aftermarket ecu to all my customers that one a little bit more out of their cars. Or have plans of taking their car beyond the basic mods of exhaust, filter and boost controller. If you want to modify your car in stages over a period of time, going the aftermarket ecu route will save you a lot of time and effort and will guarantee future results.
I hope this helps
evo400 is offline   Reply With Quote
