Which EVO7 ECU to buy for Evo6 GSR - Mitsubishi Lancer Register Forum
Old 02-08-2017, 13:03   #1
locost33
Junior User
Car: Evo6, Exhaust, HKS hardpipe. HKS boost controller, Apex Susp, Evo8 rrdiff
Hi, relatively new here. Got a question which should be easy for those in know. Which of the Evo7 ECU's would be suitable for install into my Evo6 so that I can map and datalog it.
As far as I can see there are 2 off ECU's suitable: the MR560648 and the MN132623.
And a couple of part numbers/ID's that are not: Auto MR985180 and 8631A130
Which one should I get?
locost33 is offline   Reply With Quote
Old 02-08-2017, 13:12   #2
Lee5
Moderator
Lee5's Avatar
Car: Range Rover Sport~Porsche 911
Why not just use the 6 ecu ?
Sent from my SM-G920F using Tapatalk
1st 500BHP E5 in the UK Running on Speed Density on Stock H8 Ecu
MLR Sprint Scrutineer
E5/6 Ecu SD Mapping Info Here & HERE
Lee5 is offline   Reply With Quote
The Following User Says Thank You to Lee5 For This Useful Post:
Stallion (02-08-2017)
Old 02-08-2017, 14:12   #3
locost33
Junior User
Would love to stick with what I have. I had logged it when I first bought the car and signals got truncated.
Can it be reflashed and with what? It was previously mapped (before I bought it) in Ireland via ecutek. I need to re characterise the injectors etc + have bought an IX Turbo to fit alongside going to 2.1 lt
Old 09-08-2017, 06:48   #4
pmugabi
Car: Evo 4 with E8 ECU, XS Engineering 272 cams, 80 series turbo
It should be able to reflashed. If you can't get into it because the init code was changed, download and run EcuUnlocker from AktiveMatrix before starting Ecuflash and you will be able to read it.
pmugabi is offline   Reply With Quote
Old 09-08-2017, 08:51   #5
evobull
You'll Never Walk Alone!
evobull's Avatar
Car: Very black EVO VIII (Baby Darth!!)
I've got a 4 plug ecu from an Evo 8 260, mapped to roughly 390/380. Let me know if your intetested
Sent from my SM-G930F using Tapatalk
Mitsubishi Evolution VIII with an ASBO
evobull is offline   Reply With Quote
The Following User Says Thank You to evobull For This Useful Post:
Stallion (09-08-2017)
