need help evo 8 running rich - Mitsubishi Lancer Register Forum
Old 03-05-2017, 08:10   #1
bluedemon199
i have a evo 8 fully built with 2150cc injectors and on speed density
i am running rich at idle but am good under WOT any advice would be amazing!!
evoscan log in website. https://www.evolutionm.net/forums/ec...lp-please.html
bluedemon199 is offline   Reply With Quote
Old 03-05-2017, 08:13   #2
Lee5
Moderator
Lee5's Avatar
Car: Range Rover Sport~Porsche 911
Adjust the low end VE map this should sort out the afr at idle
Sent from my SM-G920F using Tapatalk
1st 500BHP E5 in the UK Running on Speed Density on Stock H8 Ecu
MLR Sprint Scrutineer
E5/6 Ecu SD Mapping Info Here & HERE
Lee5 is offline   Reply With Quote
The Following 2 Users Say Thank You to Lee5 For This Useful Post:
bluedemon199 (03-05-2017), sbn1979 (03-05-2017)
Old 03-05-2017, 08:17   #3
bluedemon199
you are referring to my SD RPM VE setting correct? btw i am runnning 94170715 rom
Old 03-05-2017, 08:29   #4
Lee5
Moderator
Lee5's Avatar
Yes, pull the numbers down this will reduce the afr.
Also if you are running a coil on plug kit make sure the dwell times are correct as this also messes up the idle afr
The Following User Says Thank You to Lee5 For This Useful Post:
Old 03-05-2017, 08:40   #5
bluedemon199
illl give that a try! thanks so mcuh if this doesnt fix it do yo mind if i send you a private message? and dwell time? i have sparktech cop. i have had a tuner tune my car, However when he tuned it my thorttle postion was off so it wasnt going into idle correctly so that is why it is off. where would i find dwell time at?
Old 03-05-2017, 08:46   #6
bluedemon199
dont know if it is worth mentioning but. as the car warms up is when it seems to do worse at idle. i start with around -8 vacuum and and up around -11,-12 and thats when the idle goes rich
Old 03-05-2017, 08:53   #7
kikiturbo
Car: EVO 9 GSR
are you running closed loop lambda?
Old 03-05-2017, 08:58   #8
bluedemon199
i am unsure i am willing to email my ecuflash file if that helps?
Old 06-05-2017, 09:22   #9
foreskin fred
You'll be outflowing the FPR.
You'll know this once you measure fuel pressure.
It's a universal problem with bigger pumps and injectors.
But it won't be the only problem, it never is.
Just tell yourself over and over again "I've been conned".
Eventually it'll sink in.
foreskin fred is offline   Reply With Quote
