List your MAX bhp/torque running on standard blocks here - Page 4 - Mitsubishi Lancer Register Forum
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 01-09-2010, 15:22   #46
scubaladdie
Car: Evo VI GSR, Compomotives,Teins,Carbon Twin-Plate,HKS Cams 396/400
Anyone remember Dave Gammons VI ? Can't remember BHP, but 488 lb torque on stock VI internals for 7 years and around 40k miles inc several trackdays, 2.2 bar boost iirc before he sold it on...
scubaladdie is offline   Reply With Quote
Old 01-09-2010, 17:42   #47
andyevoiv
Car: RS6 C6 Avant
Good god, that is
More to go in mine yet then
andyevoiv is offline   Reply With Quote
Old 01-09-2010, 19:00   #48
scubaladdie
Originally Posted by andyevoiv View Post
Good god, that is
Power was a good bit less than torque... 440ish i think. Some Evo400 hybrid turbo, Piper cams, Gems ECU. Stock head, internals etc and last I heard still going strong
Old 01-09-2010, 19:30   #49
DA VINCI
Car: Old school beasts
Your dyno graph is dated 14/11/2008, has your car been running that much power and torque since then till now (today)??
He is safe. His torque is reasonable.
DA VINCI is offline   Reply With Quote
Old 02-09-2010, 12:30   #50
andyevoiv
Car: RS6 C6 Avant
Does anyone else agree with this quote??
Is there anyone in the UK running 500bhp on a stock block evo??
Old 02-09-2010, 12:40   #51
DA VINCI
You!. 500 is only 5% percent over your 474Hp. It is the same.
Pistons and cilinders are safe at this level. Good tunners offer the rod conversion up to 550HP (pistons really stand more) because at this level the car is supossed to achieve big torque. Rods are safe, too, if you keep the torque reasonable. But if you want 500/500, you'll probably go into problems.
500/500-> problem
450-500/400-> OK (good map of course, AFR, EGT, detonation at correct values)
Old 02-09-2010, 14:07   #52
andyevoiv
Car: RS6 C6 Avant
500/500-> problem
I know me and you!! but i want other peoples input also, hence the thread in the first place
Old 02-09-2010, 15:46   #53
DA VINCI
There are a lot of people with lots of abuse in the 450Hp range.
If I'm right, I think Knoxville, with his evogrened V was at 440HP/450lb-ft?
480Hp over 450HP is only a 6,6% more.
Old 05-09-2010, 16:25   #54
tweaks
Car: ralli art 6 reims blue
i like the sound of this is there anymore with power/torque like that ??
Tim
tweaks is offline   Reply With Quote
Old 06-09-2010, 19:30   #55
spen123
Car: evo 8 MR
410/410 stock block 8 MR
Boost controller
3" elbow exhaust
re-map
fuel pump...
spen123 is offline   Reply With Quote
Old 16-09-2010, 21:07   #56
andyevoiv
Car: RS6 C6 Avant
Time to bump this one up guys/gals, any more figures out there please??
Kind regards Andy
Old 17-09-2010, 05:01   #57
deej1
420 lbft and 440 hp
hks gtII 7460 turbo
hks cams
+ usual mods
1.7 bar
next tank of fuel I'm gonna map for e85, keeping torque the same but increase hp. Basically hold the same torque for longer and higher rpms
deej1 is offline   Reply With Quote
Old 14-09-2011, 20:26   #58
markp1983
Car: Evo VIII 260, don't look or go like one tho.. ;) 340 ATW & 420lbft tee hee!
Thought I might bump this old thread up to see fresh thoughts...
So keep the torque around the 400ft/lb mark and you're pretty much safe it seems, hopefully?!
markp1983 is offline   Reply With Quote
Old 14-09-2011, 20:40   #59
cheeseface
Car: tommi makinen evo 6
surely some of these engines are on a wing and a prayer with some of these figures
cheeseface is offline   Reply With Quote
Old 14-09-2011, 21:07   #60
markp1983
A stroker's not exactly standard bottom end tho is it!!
Similar Threads
max boost for standard ecu with avc-r prova355 Engine / Turbo 3 24-07-2004 14:41
whats the max bhp u can get with standard evo 6 injectors moses Engine / Turbo 10 22-11-2002 08:26
What's the standard max turbo boost pressure for an evo1 Roger C Technical Questions 3 13-07-2002 21:46
Max Boost with standard turbo Chuck Technical Questions 12 23-08-2001 19:59
Max Power emails Heave Ho Six Lancer Chat 1 22-01-2001 22:34
