#16 | |
acting daft since 1969
Sponsored Links | |||
Advertisement |
#17 |
rally cars tend to drop of edges of roads and gravel track and the like can soon remove the bolts hanging down ,while it may just be coinsidence it could have been considered as lets face it the evo was made as a cometition car ,but i think it was also down to hub flex ,whey they went back to the 5 design
#18 |
![]() Join Date: Oct 2016
I've measured the ball joints diameter where they sit in the arm. The factory one is 39.95mm, and the ebay one 40.15mm.
Advertisement |
#19 | |
What I meant was lower pivot point relative to the hub, doh! which would raise the roll centre and as you say is advantagous, however having looked more closely, it appears that the pivot point is the same on both arms. |
#20 | |
IIRC, the TME was a tarmac spec 6 and the standard 6 was gravel spec, so it would follow that lighter (cheaper) arms would be acceptable as opposed to the stonger arms required for a gravel. |
#21 |
#22 |
Since the seller doesn't want to refund me despite the fact he sold me ball joints that don't fit, I advise people to avoid him. His name on ebay is ziggy-a2z.
![]() Also putting them in freezer and oven won't solve the 0.2mm difference, no need to even try. |
#23 |
Maybe you can turn them a bit down on a lathe ?
#24 |
For sure I could, except now that I've tried to press them into the arm, one ball joint is stiff, not useable anymore (the outer part compresses now the ball joint because it was "crunched" a bit upon fitting). So its just gonna go to the bin.
The most annoying part for me is that the ball joints I wanted to replace were fine. I changed all rears so I thought I would change the fronts as well. "If it works fine, don't mess with it" they say. |
#25 |
eBay can be great but also your worst enemy . Beware .....
Advertisement |
Thread Tools | |
